#11
I think the rope is 3/8 polypropylene. The rope strength is within FAA
requirements for the gliders we tow. We use a weak link with a tost ring, but not with the Schweizer. There's a Schweizer release on the tug. "GARY BOGGS" wrote in message ... What size rope were you using? Was there an weak link? Boggs |
I have been a bit concerned with the ropes some places use.
http://www.engineeringtoolbox.com/po...th-d_1516.html shows the following minimum breaking strength 1/4 1125 lbf 80%= 900 lb minimum glider weight 5/16 1710 lbf 80%= 1368 lb minimum glider weight 3/8 2430 lbf 80%= 1944 lb minimum glider weight I prefer towing behind 1/4" rope I have seen a few rope breaks with 1/4" all seemed warranted with a rope in good condition. It seem to me that unless you are towing a fully loaded ASG29 or a two place that 1/4 rope is probably what should be used unless of course a weak link is used. And even then 1/4" rope should be adequate at the 200% rating or less. Am I missing something? Brian |
Wear on the runway, UV degradation.
"Brian" wrote in message ... I have been a bit concerned with the ropes some places use. http://www.engineeringtoolbox.com/po...th-d_1516.html shows the following minimum breaking strength 1/4 1125 lbf 80%= 900 lb minimum glider weight 5/16 1710 lbf 80%= 1368 lb minimum glider weight 3/8 2430 lbf 80%= 1944 lb minimum glider weight I prefer towing behind 1/4" rope I have seen a few rope breaks with 1/4" all seemed warranted with a rope in good condition. It seem to me that unless you are towing a fully loaded ASG29 or a two place that 1/4 rope is probably what should be used unless of course a weak link is used. And even then 1/4" rope should be adequate at the 200% rating or less. Am I missing something? Brian |
Rough Landings on Ice | C J Campbell[_1_] | Piloting | 1 | March 8th 08 07:30 PM |
rough running C-182 | R&A Kyle | Owning | 10 | November 16th 04 11:45 PM |
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) | Kyler Laird | General Aviation | 0 | March 1st 04 12:11 AM |
Rough Engine, please help | John Clonts | Owning | 14 | February 26th 04 12:09 AM |
HELP! To buy or not...rough 63 aztec for $25,000 | david | Owning | 27 | January 15th 04 01:06 AM |
