Where to get Winched?
Old June 7th 12, 03:37 PM posted to rec.aviation.soaring
Bill D
Default Where to get Winched?
If you're only getting 33% of the rope length, yours is a low
performance winch operation. If you optimize it, 45% or so is
achievable in no-wind conditions. A 10 knot wind can boost that over
50%. Again, I'm saying this is for gliders with better than 30:1 and
rope tensions equal to the weight of the glider. Below 30:1, achieved
height falls off a lot.
On Jun 7, 7:51*am, GC wrote:
On 7/06/2012 02:45, Chris wrote:
We in europe do winch launching as the standard procedure. Our airfield has
1200m (~4000 feet) paid out cable and we get release height of about 400m
(~1300 feet). With strong headwind we even get 600m, sometimes more. Our
club charges 4,- ? for a launch.
Yes. *Bill Daniels seems optimistic to me. *1 for 3 is about what I'd
expect with a nil to light wind.
It depends on lots of factors: engine power, pilot skills, wind direction
and strength, cable (steel or dyneema), lenght of cable, glider type... and
certainly more. The above numbers are for a double seater like ASK21, steel
cable and moderate headwind.
There have been launches with dyneema cable of 3000m length and release
heights of 1200m. This is a really cost effective way to do aerobatics.
To answer your question: I would think 3000 feet is the minimun for a
reasonable winch operation. However, I have seen fields with only 2000 feet.
The length you need is wire length - not runway length. *The ground run
for a launch is barely 100 yards. *Any more is for landing, launch
emergencies, etc. *Winches are also commonly sited well beyond the
upwind runway threshold. *It's a very flexible launching system.
GC
Chris
Old June 7th 12, 03:47 PM posted to rec.aviation.soaring
Bill D
GC
Chris
100 yards for acceleration is way too long. A 1G acceleration will
get a glider to 40 knots liftoff speed in 71 feet.
Old June 7th 12, 04:21 PM posted to rec.aviation.soaring
Marc
On Jun 7, 5:05*am, toad wrote:
The only place that I have ever found advertising an endorsement
training was a soaring club in Houston. *If there are any other
operations that will train a new pilot to winch launch, I have not yet
found them. *They may exist, but they don't advertise.
AGCSC down in southern California runs periodic weekend winch launch
training sessions:
http://www.agcsc.org/
We're putting the finishing touches on a winch that will be used for
training at Crazy Creek in northern California...
Marc
Old June 7th 12, 05:26 PM posted to rec.aviation.soaring
soartech[_2_]
I have read that the insurance is much higher for winch operations.
Anyone have a comment or tips on reducing this?
Old June 7th 12, 06:34 PM posted to rec.aviation.soaring
We have not experienced this at PGC, however, we do not have SSA insurance. I suspect that the carrier's knowledge--or should I say lack of knowledge--may have a lot to do with this.
Skip
Old June 7th 12, 06:50 PM posted to rec.aviation.soaring
Chris
GC wrote:
The length you need is wire length - not runway length. The ground run
for a launch is barely 100 yards. Any more is for landing, launch
emergencies, etc. Winches are also commonly sited well beyond the
upwind runway threshold. It's a very flexible launching system.
While this is true, there is another reason for a 3000 feet runway: safety.
You need to be prepared for a cable break at any time. Up to 300 feet you
can land straight ahead, if there is enough runway left. If the cable breaks
at a higher altitude, you can do a full circle or a short pattern. If the
runway is too short, you can get in a situation where both options do not
apply.
I guess that you refer to this scenario when you talk about launch
emergency. My opinion is that a cable break is no emergency, but is part of
the procedure. It must be trained well, but if the pilot is prepared for a
break, this is no emergency. You can expect a cable break in one of 100
launches.
BTW, my last break on the winch was in 120m. Too high to land straight, so I
initiated a 180 for a short pattern. After that turn, my altimeter showed
150m. I decided to do a full circle and got 200m. Now I continued and got
1300m in the end. This was fun while the guys below had to fix the cable :-)
Chris
Old June 8th 12, 03:42 AM posted to rec.aviation.soaring
Tom Nau
On Jun 6, 6:38*am, Walt Connelly
Where in the South East US of A might one go to get a winch launch
endorsement? *ALSO, in general how much runway is needed for an adequate
winch launch? *What might the minimum runway length be?
Walt
Walt Connelly
Come over to San Antonio Soaring Society, our club located at Boerne
Stage airport (5C1). We winched last weekend and plan to do it once a
month this summer. You can get an endorsement with our CFIG.
Tom
Old June 8th 12, 09:13 AM posted to rec.aviation.soaring
Paul Tribe[_2_]
At 02:42 08 June 2012, Tom Nau wrote:
On Jun 6, 6:38=A0am, Walt Connelly
launch
endorsement? =A0ALSO, in general how much runway is
needed for an
adequat=
e
winch launch? =A0What might the minimum runway length
be?
Walt
Walt Connelly
Boerne
it once a
CFIG.
Tom
I applaud your efforts to promote winching, coming from a UK
club with no current aerotow option, winching is my usual (and
cost effective) way into the sky.
This BGA leaflet is essential reading:
http://www.gliding.co.uk/bgainfo/saf...ts/safewinchbr
ochure-0210.pdf
If you ask them nicely, I expect they'd have no objections to
clubs on your side of the pond printing them off for circulation.
Old June 8th 12, 01:56 PM posted to rec.aviation.soaring
Frank Whiteley
Winch liability insurance was split off from premises liability under the SSA plan. Winch hull insurance is also a separate product. The advantage is that the 3rd party liability now allows operation away from home base. So yes, it did increase the fixed cost of operating a winch and included a restriction against using steel wire or steel wire rope.
Old June 9th 12, 10:52 AM posted to rec.aviation.soaring
GC[_2_]
apply.
emergency.
Well, yes I do.
launches.
Ok, call it 'launch failures'. Whatever floats your boat.
My actual point was that winching is very flexible. On Long Mynd, a
launch emergency (or failure) high enough for a circuit sometimes means
landing at right angles to the takeoff direction. The actual length
requirement is ONLY for ground over which the wire can be laid out. A
winch operation - unlike aerotow - doesn't necessarily require a single
continuous runway.
GC
Chris
