Va: maneuvering speed ad nauseam
Old November 29th 03, 02:43 AM
Koopas Ly
The engine mount on most light aircraft is designed to withstand 9
G's minimum.
Where is that specified? Does Cessna provide max. g limits for items
on the aircraft or are max. g limits for these items explicitly
specified in FAR 23?
And as I said earlier, the 3.8 figure is based on gross
weight. Reducing gross would allow them to take a higher G figure but
the same net force.
Agreed. This may sound like a stupid question, but how do you define
"gross weight"?
Cessna also states in the 172 POH that it's designed to 150% of
the G figures given, or 5.7 G's. I think the 3.8 figure would be the
yield point, where things begin to bend, and the 150% figure would
break them entirely. Or something like that.
You're correct. An airplane has to sustain ultimate loads, typically
50% beyond limit load (highest in-service load to be experienced) and
show no failure (fracture). An airplane has to sustain limit loads
without permanent deformation (yielding). At least, that's for FAR 25
aircraft.
Dan
Old November 29th 03, 10:01 AM
Julian Scarfe
"Koopas Ly" wrote in message
m...
I am sure most know the typical textbook definition of Va...goes
like..."the minimum speed at which the wing can produce lift equal to
the design load limit" or "the speed at which the pilot can use full
control deflections without over-stressing the airplane".
[Not answering Alex's questions but...]
maybe that's better as "*one* full control deflection".
http://www.dft.gov.uk/stellent/group...ty_025533.hcsp
is not unlike
http://www.ntsb.gov/events/2001/AA587/default.htm
though closer to home for those of us who fly light aircraft.
Julian Scarfe
Old November 29th 03, 02:10 PM
Robert Moore
define "gross weight"?
Ah yes...a grossly misused term and.....one not used in the FAR.
Section 23.25: Weight limits.
(a) Maximum weight. The maximum weight is the highest weight at
which compliance with each applicable requirement of this part
(other than those complied with at the design landing weight) is
shown. The maximum weight must be established so that it is --
However a web search shows that "gross weight" is used mainly by
state motor vehicle codes as follows:
Gross Vehicle Weight or GVW
The combined weight of a commercial vehicle and its load.
And the military:
Definition of: gross weight
(DOD, NATO) 1. Weight of a vehicle, fully equipped and serviced for
operation, including the weight of the fuel, lubricants, coolant,
vehicle tools and spares, crew, personal equipment, and load. 2.
Weight of a container or pallet including freight and binding. See
also net weight.
Using "gross weight" for aircraft can be misleading....for example:
The Boeing-707 had a maximum "taxi weight" of 336,000 lbs, and a
maximum "takeoff weight" of 333,100 lbs. And....its maximum
takeoff weight might be limited to the maximum landing weight plus
the weight of the fuel burned during the flight or to the maximum
weight that would allow compliance with the second segment climb
requirements.
What was its "gross weight"?
Pilots who use the term "gross weight" aren't very well versed in
the FARs.
Bob Moore
Old November 29th 03, 05:07 PM
Dan Thomas
Greg Esres wrote in message . ..
G's minimum.
Where do you get this figure?
Canadian Aviation Regulations 523.561 gives some numbers for
protection of occupants in an emergency landing (a crash). Seats and
belts, for example, have to withstand 9 Gs forward, 6 Gs downward, 3.0
upward for Normal and 4.5 for Aerobatic. Items of mass within the
cabin must be able to withstand 18 Gs forward.
The structure itself must be able to withstand, in the event of
"complete turnover" during a crash, 9.0 Gs forward, and some lesser
numbers in other directions. This structure would include engine
mounts.
Somewhere else in the many sections are more numbers specifying
componemt strengths. The FARs would have an equivalent section. The
minimum legal flight load strengths for any Normal Category airplane
is 3.8 Gs. Note that flight loads and "emergency landing" loads are
not the same, but the airplane must meet those requirements.
A 3.8 G engine mount would be most dangerous. In training students
in our Citabria, we have seen well over 3 Gs on the G meter in botched
landings. The wings and tail don't much care about that impact, since
they don't experience any air-load increases, but the gear, fuselage
and engine mount do. Imagine, for a minute, the effect of an engine
departing the airframe in such a spot: airspeed at or near stall
speed, an airplane that's suddenly 350 pounds lighter, and a CG back
around the trailing edge of the wing. People killed, maybe, for the
lack of one pound (or less) of 4130 tubing?
Dan
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 08:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 08:35 PM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 07:43 AM
