#11
Thanks for the update, Wayne. I was wondering when you'd get some new pics
up. Hopefully the avionics job won't pinch you too bad! -- Ben C-172 - N13258 @ 87Y |
Jim Weir wrote in message . ..
The largest airplane supply company in the country...your local TrueValue hardware store. Coming to think about it, though, I have not personally run a flame test on the stuff, so you may want to get a square foot of it (they sell it by the running foot off a huge roll) and burn it yourself. Jim Jim, If it is the Reflectix Insulation, the mfg had done flammability tests http://www.reflectixinc.com/testingind.asp I will have to try to correlate the ASTM test data to FAA test to see if it is suitable as a replacement for the fiberglass insulation in our Cessna 177b. |
I was thinking that, the original panel is wonderful!
Paul "Frank" wrote in message ... Also, interesting to see the original panel. Ours has been modified somewhat, resulting in a bit of a hodge-podge look. |
You got it. My 175 has been modified too, master moved down and large holes
cut. Wayne "Frank" wrote in message ... "Wayne" wrote in message ... goto http://12.151.5.4/172 The plane is really starting to come along now. Wayne Nice pics. Especially the arrival shots. It looks like it it/was a twin to mine, except we don't have the 'Cessna' lettering on the nose. It's a '63 172D right? Also, interesting to see the original panel. Ours has been modified somewhat, resulting in a bit of a hodge-podge look. -- Frank....H |
I'm going to play avionics shop too. Hope i don't pinch myself.....
Wayne "Ben Smith" wrote in message ... Thanks for the update, Wayne. I was wondering when you'd get some new pics up. Hopefully the avionics job won't pinch you too bad! -- Ben C-172 - N13258 @ 87Y |
("hlongworth" wrote)
If it is the Reflectix Insulation, the mfg had done flammability tests http://www.reflectixinc.com/testingind.asp I will have to try to correlate the ASTM test data to FAA test to see if it is suitable as a replacement for the fiberglass insulation in our Cessna 177b. (From their pretty good website) http://www.reflectixinc.com/commercial.asp Bla bla bla ...bla, bla bla ...Improved livestock production ...bla, bla, bla. Hey, that's some good stuff!! g Lightweight, moisture resistant, good sound deadening properties, easy to use ...plus, it improves livestock production!! -- Montblack |
![]() "Jim Weir" wrote in message ... Coming to think about it, though, I have not personally run a flame test on the stuff, so you may want to get a square foot of it (they sell it by the running foot off a huge roll) and burn it yourself. Margy used some stuff we ordered from Aircraft Spruce when she redid the headliner in the Navion. Dirt cheap, and still a whole lot better than the fiberglas stuff. Looked more like carpet padding than bubble wrap. |
V-6 STOL Project For Sale | Bruce A. Frank | Home Built | 0 | January 28th 05 07:28 AM |
Talon Homebuilt Aircraft Project For Sale | spar | Home Built | 1 | December 8th 04 08:46 AM |
1947 Fairchild project value | dmoon | Owning | 3 | February 18th 04 10:37 PM |
Question: Researching Project | Tilt | Home Built | 21 | December 17th 03 02:39 PM |
Project 172, sitting outside, uncovered for 18 years! | Wayne | Owning | 4 | August 5th 03 04:57 PM |
