Sad news
Old June 29th 12, 04:37 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Default Sad news
On Jun 29, 9:45*am, Jock Proudfoot wrote:
*. . * I don't
have an exact location for the crash and there is some uncertainty in
my mind as to whether the location given in a different article is
correct... because I can't match that tree line to anything I can see
on satellite views where the accident is said to have occurred. *More
likely is that it is a bit farther out.
-Evan / T8
Location; *N 43 *48' *7" *W *80 *24' *43.71"
Fuselage approx 15' south of the treeline. *Facing SW, parallel to the
treeline. On it's belly. Debris field contained to approx 50' radius
Cheers * ...Jock
Thanks. This helps a lot. But now it's even more of a puzzle. Google
map the location. It's 1.18 miles E/SE of a visible airport, marked
"arthur aerodrome" on google maps. There's an even closer "Bellwood
Aerodrome" but that doesn't exist according to the satellite photo.
It's 3.05 miles SE of the intersection of the runways at York. Most of
all, there are huge fields all over the place, bigger than this one,
with no trees at the ends, and next to the obvious roads, unlike this
field which is landlocked with no visible trailer access. It just
makes no sense to land in this field, let alone run in to the trees. I
hope the accident investigation unravels the mysteries a bit. Ugh.
John Cochrane
Old June 29th 12, 04:50 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Sad news
On Jun 29, 10:45*am, Jock Proudfoot wrote:
*. . * I don't
-Evan / T8
Cheers * ...Jock
Thanks. This location and orientation raises more questions in my
mind than it answers. Only the flight log will sort this out.
-Evan Ludeman / T8
Old June 29th 12, 04:53 PM posted to rec.aviation.soaring
Sean F (F2)
Default Sad news
Per Google Earth I believe that the crash site (N 43 48' 7" W 80 24' 43.71) was 2.61 miles(4.18 km) SE of the center of the contest airport (Arthur East Field) (N 43° 50' 26" W 80° 26' 34").
On Thursday, June 28, 2012 8:39:28 PM UTC-4, Evan Ludeman wrote:
On Jun 28, 7:44*pm, John Cochrane
Ramy
The accident was described to me by friends on site... who probably
don't feel like talking about it. *I don't much, either, except to say
it's clear that it was a landing accident, hit trees on short final.
High winds a factor, probably. *Good field was selected, pattern was
flown, it wasn't some panic straight in thing. *Location is ~2 miles
SSE of YSA. *I liked Derek. *Very sad about this.
-Evan Ludeman / T8
Evan:
At 2 miles out it would only take 300 feet to make it home. "Good
pattern" and 2 miles out don't really add up. If you have 600 feet at
2 miles to make a good pattern, making it to the airport is easy.
I don't intend uninformed criticism of the pilot here, 2 miles out is
a coffin corner for all of us. *I am just curious whether to file the
tragedy in the *"final glide mishap" rather than "landout mishap"
category.
I note the Canadian rules say a 500 foot finish cylinder at 2 km, but
still the rather mild altitude penalty of 20 points per 100 feet,
unlike the current US rule in which you are scored as a landout 200
feet below finish height. *Also that the altitude is up to the CD. Do
you know the finish configuration at this contest? Sorry to bring it
up on ras, but this is the sort of thing that no NTSB ever would have
the wit to ask. 2 miles out puts the pilot half a mile from the finish
cylinder, an unusual place for a pilot to abandon a task.
http://www.sac.ca/index2.php?option=...iew&gid=538 &...
Thanks for the info. I'm only pursuing it because it has been a
terrible season, and perhaps time to search again if there is anything
we can do to lessen the frequency of these tragedies.
John Cochrane
I haven't talked to the person who has the flight log, let alone seen
it myself. We really can't analyze this accident without it. I don't
on satellite views where the accident is said to have occurred. More
I really only weighed in here because I am as certain as I can be
based on second or third hand info that this was a landing accident,
not a thermaling stall/spin, as one might have suspected based on the
news.
-Evan / T8
Old June 29th 12, 05:51 PM posted to rec.aviation.soaring
soartech[_2_]
Default Sad news
For those without Google Earth this site is about 50 miles WNW of
Toronto, Canada near the village of Metz.
This terrain is nothing but huge, 2000+ foot landable fields in all
directions. The tree line mentioned is just that:
a single line of trees. The only obstacle to a straight in landing.
Easy to avoid.
I agree that this may have been a health emergency that caused this.
Good news and bad news about SPOT 2 devices Frank[_12_] Soaring 6 May 12th 10 06:43 AM
No news Is Good news? Pete Reinhart Soaring 5 September 23rd 06 05:23 PM
AFW - Sad News Hilton Piloting 3 September 25th 04 02:34 PM
Weak Dollar (Bad News - Good News) JJ Sinclair Soaring 6 January 27th 04 03:06 AM
Sad News JohnD Soaring 11 October 11th 03 09:17 AM
