Dust to Dust . . .
Old December 3rd 03, 12:20 AM
Phil McAverty
"Montblack" wrote in message
("tony roberts" wrote)
snip
Has anyone ever disposed of cremated remains from a light plane?
How did you do it? All suggestions/ideas gratefully received.
This is a wind up surely?
Old December 3rd 03, 04:11 AM
tony roberts
Why would you think that?
From the reading that I have done over the last couple of days, and from
the responses posted here, it does not appear to be a unique event.
Tony Roberts
PP-ASEL
VFR OTT
Night
Almost Instrument
Cessna 172H C-GICE
Old December 3rd 03, 06:09 PM
Kevin McCue
Last time this came up IIRC a good suggestion was.
Put ashes in paper bag. Carefully slit the bag w/razor knife to weaken the
bottom. Tie shut w/a length of cord (12-15ft). Take aloft. secure end of
cord to seat rail or whatever, throw bag out window. Bottom rips out at the
end of the fall, drop done. Suggestion also mentioned adding glitter to
ashes to aid in viewing from the ground.
Kevin McCue
KRYN
'47 Luscombe 8E
Rans S-17 (for sale)
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old December 3rd 03, 10:51 PM
David Reinhart
There was an article about this in AOPA Pilot a couple years ago. The
airplane was a Cherokee, with the small window, so I don't know how well the
procedure would work in a 172 with the larger hinged window.
Go buy a large oil funnel with a long, flexible spout. Also get a large
sponge (or more than one--enough to fill the window opening). Cut off the
pointy tip at the end of the spout. Repackage the remains into something
easy to pour from.
Fit the sponge into the window. With two people in the airplane, take off.
Close all the vents. While one person flies at a comfortable slow-flight
speed, the other works the spout of the funnel past the sponge (maybe have a
spare sponge?). Open the vents. This should create a suction through the
funnel. Pour the remains into the funnel.
As I stated once before, I'm not a ghoul. This showed up at a time when my
mother was very sick and her wishes are to have her ashes scattered by air.
Dave Reinhart
tony roberts wrote:
I appear to have volunteered for a task I know nothing about.
My friend who owns a Cherokee was approached by a neighbour who advised
him that his father was dying and has asked that his ashes be scattered
from an aircraft over a rural area near where I live. My friend
volunteered, then thought that a high wing may do the job better, and
asked me if I would do it in my 172 - in a weak moment I agreed.
Throwing the sealed bag out of the window is an appealing option for its
simplicity, but I doubt that next of kin or persons on terra firma would
agree.
An open bag, thrown out of the window may or may not empty on its way
down - not reliable enough. Also I don't want the dear departed to hit
the horizontal stab and take us with him.
Tipping the contents of the bag out of the window would, I suspect,
result in the contents siphoning back into the cockpit.
A tube hanging out of the window, with a funnel at the top? That may
create a venturi effect and cleanly suck the ashes out of the plane.
Tony Roberts
PP-ASEL
VFR OTT
Night
Almost Instrument
Cessna 172H C-GICE
Old December 5th 03, 10:20 AM
Tim Hogard
tony roberts ) wrote:
: I appear to have volunteered for a task I know nothing about.
: My friend who owns a Cherokee was approached by a neighbour who advised
: him that his father was dying and has asked that his ashes be scattered
: from an aircraft over a rural area near where I live.
Others have posted ways to do this.
Take a pair of eye protection goggles with you. I recomend the ones
you find for use in chemistry classes that are completley sealed.
You don't wany any of the ashes to blow back in your face.
-tim
http://web.abnormal.com
Old December 5th 03, 05:05 PM
Model Flyer
"Tim Hogard" wrote in message
ones
If doing this to finally get rid of a not so loved one - always on
your case - and the ashes did blow back in your face, that person
would always be up you nose, for the rest of your life.:-)
Cheers,
Jonathan Lowe.
don't bother me with insignificiant nonsence such as spelling,
I don't care if it spelt properly
Sometimes I fly and sometimes I just dream about it.
-tim
Old December 6th 03, 11:53 PM
Lynn Melrose
x-no-archive: yes
agree.
The best method I have seen was using a plane with an STC'd camera port in
the floor. In this case it was a C-182. Some plumbing was constructed to
make a tight fit over the port, and at the appropriate time a simple valve
was opened. I believe Avweb or one of the similar publications had an
article about this subject.
Old December 7th 03, 12:05 AM
mike regish
Do a search in the rec.aviation newsgroups archive. It's been discussed
before, but it's been quite a while. I believe the tube and funnel method
worked pretty well. I would think you'd want the tube long enough to get
below the horizontal stab. I guess that ask can be pretty gritty and you
don't want it in your hinges. A little duct tape and tubing and you're good.
mike regish
"Lynn Melrose" wrote in message
x-no-archive: yes
agree.
Old December 7th 03, 07:20 AM
Brien K. Meehan
tony roberts wrote in message news:nospam-A53B13.21060101122003@shawnews...
I found this link:
http://www.trailsendaerialdispersion.com/index.html
Has anyone tried one of these?
Aviation Video: Another F-16 bites the dust Iwan Bogels Instrument Flight Rules 0 September 21st 04 07:02 AM
Aviation Video: Another F-16 bites the dust Iwan Bogels Owning 0 September 21st 04 07:02 AM
Russia & India to send joint manned mission to Moon Michael Petukhov Military Aviation 84 November 20th 03 11:04 PM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
