"Tanks on both" checklist item
Old December 4th 03, 06:41 PM
Frank
Tony Cox wrote:
"Koopas Ly" wrote in message
om...
The only time that fuel is set to one particular tank is on the
ground. I've never used fuel from only one tank in flight. Why would
someone do that?
Some models of 172 *require* you to select a single tank
above 5000', due (supposedly) to vapor lock problems.
Check your POH.
No 'supposedly' about it. Ours locked at 7500' on a humid day because one of
my partners didn't believe it could happen and didn't follow the procedure.
Fortunately an airport was within glide range. Strangely enough, by the
time he landed the engine was running fine again....
Frank....H
Old December 4th 03, 07:10 PM
Craig Prouse
"COUGARNFW" wrote:
Amazing...all those answers by 172 owners and no one of them went to the net
to find the "truth".
The question is why is the selector placed in the "BOTH" position for
landing, not why is the selector placed in some other position above a
certain altitude for certain models.
Old December 4th 03, 08:35 PM
Bob Martin
With regards to fuel tanks in a C172, why does the takeoff and landing
checklists both call for the fuel selector handle to be in the "both
tanks" position?
someone do that?
Not really related to 172's, but our RV-6 has no "both" position... either
left, right, or off. You just have to remember to switch them occasionally.
Also, IIRC the 150 has just "on" and "off".
Old December 4th 03, 09:39 PM
Roger Hamlett
"Bob Martin" wrote in message
tanks" position?
someone do that?
occasionally.
There is a significant difference here between low wing, and high wing
designs. If you have a low wing aircraft, and have a 'both' selector, if one
goes empty, air is sucked into the system by the fuel pump, and fuel
delivery stops. Hence low wing aircraft with a 'both' position, have to have
a central 'sump' from which the fuel is drawn. On high wing aircraft, where
the fuel is delivered by gravity, if one tank goes dry in the both position,
fuel will still feed from the other. Hence 'both', is relatively unusual on
low wing designs, but more common on high wing planes. This is why your RV6,
doesn't have a 'both'.
Best Wishes
Old December 4th 03, 10:17 PM
G.R. Patterson III
tanks" position?
It's basically to ensure that you will have fuel through the entire takeoff. The
reason it's done for landing is in case you need to go around. The idea is that,
even if one tank goes empty or has some other problem, you will have a steady
supply of fuel.
ground.
Then you don't have to worry too much about it, do you?
someone do that?
I do it in my Maule to equalize fuel burn. It will draw down the left tank more
rapidly than the right if I don't. I believe most Cessnas are worse in this
regard than my aircraft; my 150 certainly was.
Also, why is the fuel selector set to one tank during refueling? Is
it to minimize crossfeeding?
Yep. In my Maule, the lower tank will overflow through the vents if this is not
done. My 150 (which didn't have the option of selecting tanks) would do the
same if the vented tank was the lower one. Note that my Maule will do this even
if the selector is set to "off". Dunno if that's the case with a Cessna.
George Patterson
Some people think they hear a call to the priesthood when what they really
hear is a tiny voice whispering "It's indoor work with no heavy lifting".
Old December 5th 03, 01:19 AM
Dan Thomas
"Tony Cox" wrote in message thlink.net...
om...
someone do that?
Check your POH.
Lots of old pilots didn't trust fuel gauges, which is still a
wise attitude. They'd sometimes fly on one tank until it ran dry and
the engine quit, then switch to the other and know exactly how much
they had left and how much they'd burned. This doesn't work well if
the tanks are very far off the airplane's centreline, as the imbalance
can require increases aileron input, causing more drag and tiring the
pilot. It can also panic passengers and create unpleasant cabin odors
and extra janitorial work after the flight.
Dan
Old December 5th 03, 02:33 AM
CVBreard
I'm an old pilot, don't trust fuel gauges and purposely ran a tank dry...only
once...scared the hell out of me and my wife. Never did that again. :-)
(Longer story, but that's the short version.)
Old December 5th 03, 03:54 AM
Bob Martin
either
occasionally.
one
have
where
position,
on
RV6,
Ok, that makes sense now... thanks
F-104 in Viet Nam Question Don Harstad Military Aviation 2 August 28th 04 08:40 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 05:31 PM
IFR Checkride Checklist BTIZ Instrument Flight Rules 0 April 18th 04 12:06 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
Tanks for nothing (repost from Bearhawk list) Del Rawlins Home Built 0 August 6th 03 03:06 AM
