#11
"Chris Schmelzer" wrote in message
Simple example of what gets people killed in any sort of risky activity (be it rock climbing, mountaineering, scuba diving, etc..) PANIC! Quite true. ...all he had to do was look at the damn instruments and put himself in level flight and wait for direction.. It's very easy to judge when you're not the one in his situation. Even instrument rated pilots have been known to lose control after venturing into IMC. This is why you need to train and THINK about your response to emergencies so you don't turn into a COMPLETE freaking idiot in an emergency... Luckily that (turning into an "idiot") will never happen to you, right? -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
"John T" wrote in message ews.com...
"Cecil E. Chapman" wrote in message m I was surprised to learn that one of the controllers at another airport I've flown to in the past, actually had never been a pilot NOR ever BEEN IN a G.A. aircraft. Why was that surprising? Hi, I don't have a pilot's license and nor have I started training for one, but does the radio chatter usually sound this clear? I was discouraged a little bit earlier in the week when I was listening in to some ATC that I couldn't understand! Thanks... |
one, but does the radio chatter usually sound this clear? I was discouraged a little bit earlier in the week when I was listening in to some ATC that I couldn't understand! Thanks... No, it doesn't usually sound this clear. But the only the first section of the recording was recorded from the radio. The middle section was between two different ATC facilities, and was thus took place over a dedicated telephone line. The final section was recorded when the pilot called in for a weather briefing later that day. The radio section did seem remarkably clear. It's possible that it has been run through some filters to clean it up a bit. Maybe the pilot happened to be right on top of receiving station for the particular facility. The radio is almost completely impossible to understand when you first start to listen. The sound quality isn't great, people talk very quickly, standard radio procedures are soundly ignored, and many phases are abbreviated in some way. If you happen to know any pilots, it might help to have one of them listen in with you and translate a bit, but even that isn't all that necessary. The good news is that once you begin to get used to the things that are commonly said on the radio, it will begin to make much more sense to you. Then when you begin your training, you will be way ahead of the pack when it comes to radio work. You are going to begin flight training, aren't you? You know you want to do it! |
ATC trainees are taught that the pilot is responsible for the safety of the
airplane and the controller is responsible for the safety of the airport - period... Denny "Larry Fransson" wrote in message news:2003122517430716807%lfransson@comcastnet... On 2003-12-25 15:23:45 -0800, "Cecil E. Chapman" said: The other thing that bugs me is that the VFR pilot (like another poster has already said) really received very little useful control input (aside from the first instruction to break the stall) and instrument interpretation instructions. At one point the VFR pilot was simply told to "just fly straight and level" when the pilot found himself in IMC again. I can think of a plethora of other suggestions that might have been made to the VFR pilot, on how exactly he should interpret 'straight and level' using his instruments and more importantly how to make turns at a bank and turn rate that is appropriate to being in IMC. All of which could be explained quickly without overwhelming the pilot. There's no requirement for ATS types to know anything about flying airplanes, and they should not try to give flight instruction over the radio. For similar reasons, I do not attempt to provide weather briefings or radar vectors. -- Larry Fransson Seattle, WA |
In article , Larry Dighera says...
On Wed, 24 Dec 2003 23:34:45 -0500, Aardvark wrote in Message-Id: : http://www.naats.org/docs/flightassist.mp3 While this FSS controller promotional audio clip seems to provide a glimpse at a very frightened pilot's fear of death, I failed to find any meaningful assistance provided by FAA personnel other than some dubious control input suggestions. It seems the pilot was able to regain control of his aircraft and composure merely as a result of having the (false?) reassurance of contact with another human. Interesting stuff. It also goes to show that flying really can't be _that_ dangerous at all. Look at all the almost winners of Darwin awards that are still out there alive and flying today. |
On Fri, 26 Dec 2003 08:31:34 -0500, "Dennis O'Connor"
wrote in Message-Id: : ATC trainees are taught that the pilot is responsible for the safety of the airplane and the controller is responsible for the safety of the airport - period... Perhaps. But that would run counter to FAA Order 7110.65's mandate for ATC to issue Safety Alerts: http://www2.faa.gov/atpubs/ATC/Chp2/atc0201.html#2-1-6 |
Recently, Larry Dighera posted:
On Wed, 24 Dec 2003 23:34:45 -0500, Aardvark wrote in Message-Id: : http://www.naats.org/docs/flightassist.mp3 While this FSS controller promotional audio clip seems to provide a glimpse at a very frightened pilot's fear of death, I failed to find any meaningful assistance provided by FAA personnel other than some dubious control input suggestions. It seems the pilot was able to regain control of his aircraft and composure merely as a result of having the (false?) reassurance of contact with another human. Interesting stuff. If the pilot had been unable to regain control, the rest would have been moot. Once control was regained, the guy was still lost, with no idea of which way to turn to get into VFR conditions. To me, that was the meaningful assistance provided by the FAA personnel, and I'm hard pressed to think of a reasonable substitute. Regards & happy holidays, Neil |
![]() Dennis O'Connor wrote: ATC trainees are taught that the pilot is responsible for the safety of the airplane and the controller is responsible for the safety of the airport - period... If you are VFR. If you are IFR I also am largely responsible for your safety as well. |
It isn't a surprise, 'now', but when I was a primary student (and learned that there was no requirement that controllers to be pilots too) I was surprised, because I had just presumed that they 'must' be pilots, that's all.... -- -- =----- Good Flights! Cecil PP-ASEL Check out my personal flying adventures complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
-- John T Me again..... I just think that it would be prudent to have controllers that were also pilots, just as it is prudent for (at least it is required by law, in parts of California) food service workers to have some training in handling choking problems. -- -- =----- Good Flights! Cecil PP-ASEL Check out my personal flying adventures complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 02:54 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 02:11 PM |
