Wing-support for Duo one-person assembly
Old September 2nd 12, 11:02 PM posted to rec.aviation.soaring
Dave Nadler
Default Wing-support for Duo one-person assembly
On Sunday, September 2, 2012 4:58:12 PM UTC-4, wrote:
Hi Dave!
I use the IMI single-seater for my Antares, In teh club we use
the IMI double-seater version for the Arcus. I prefer the IMI over the Lange.
Have Fun
Hans
Thanks Hans !
See ya, Dave
PS: Hans has an Antares 18 - no batteries in the wing !
PS: Hans - Further questions about the the IMI double-seat version:
- suitable for one-person assembly ?
- spring strong enough to offset the weight of the wing ?
- have you used this on a Duo (much bigger chord than Arcus) ?
- do you have to go under the wing to adjust or lock the height ?
Old September 3rd 12, 01:29 AM posted to rec.aviation.soaring
Barry[_4_]
Dave,
I use a wingrigger on my Arcus and it works fine. Steve strengthened the unit and added larger tires.
Barry (ARC)
Old September 3rd 12, 02:45 AM posted to rec.aviation.soaring
On Sunday, September 2, 2012 8:29:39 PM UTC-4, Barry wrote:
Dave,
Barry (ARC)
So you solo rig your Arcus?
Old September 3rd 12, 12:09 PM posted to rec.aviation.soaring
Am Montag, 3. September 2012 00:02:43 UTC+2 schrieb Dave Nadler:
I think one could do it, but I have nevery tried it, because in club there are always other people around and we just use it so that we do not have to carry the heavyt wing
Yes (it is not a spring but a gas strud)
No, but there is much room for adjustment of teh fixation.
Yes, this feature is much more ellegantly solved with the Lange design. But I see no safety risk in this.
Old September 3rd 12, 04:11 PM posted to rec.aviation.soaring
Dave Nadler
The risk is to my inflexible spine...
I really don't want to be repeatedly bending over
and/or crawling under the wing.
This is NOT necessary with a good design !
Thanks again,
Best Regards, Dave
Old September 3rd 12, 06:56 PM posted to rec.aviation.soaring
Am Montag, 3. September 2012 17:11:15 UTC+2 schrieb Dave Nadler:
Yes, this feature is much more elegantly solved with the Lange
snip
You are right is not necessary, but the the additional comfort (or usability in you case) comes with a higher price tag. When I adjust the hight of the wing I normally sit on the round and do not bend my back.
Old September 4th 12, 06:32 AM posted to rec.aviation.soaring
Morgan[_2_]
On Sunday, September 2, 2012 11:44:38 AM UTC-7, (unknown) wrote:
When you lift the tip of the main wing panel to pull it out of the trailer, how many pounds are you lifting?
And what is the total piece weight of the DD inboard wing panel?
Total weight is 215lbs I believe. I haven't ever stepped on a scale while picking up either the wing tip or the root. I'd guess the split is like 130lb/85lb or something like that between the root and the tip. It's heavy, but mostly it is awkward.
There is a lot of weight on the trailing edge once you rotate flat. Then for the person at the tip, the height is very high given the dihedral. When Julie and I rig, the tip is at about shoulder height for her.
Old September 4th 12, 11:51 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Hi Dave!
Have Fun
Hans
Thanks Hans !
See ya, Dave
Hi Dave
I bought Paul Cordell's Nimbus 3D a couple of years or so back and it had a very basic wing rigger with it. I one man rig without any problems. It uses a mechanical screw height adjustment but once it is set it hardly needs any fiddling. To get the fine adjustment for pin alignment I adjust the fuse up or down with the fuse cradle jack(Cobra trailer). I've seen people with much fancier and more complex gear have more trouble, you just gotta have the knack
Although the Duo is quite high at the outer end of the inner panel I wouldn't think you would have too much trouble with a well set up wing rigger
Weather permitting I'll get you some photos tomorrow and email them to you
Cheers
Colin
Old September 4th 12, 03:26 PM posted to rec.aviation.soaring
Dave Nadler
On Tuesday, September 4, 2012 6:51:03 AM UTC-4, Ventus_a wrote:
Hi Dave
rigger
you
Cheers
Colin
Thanks Colin !
Old September 4th 12, 03:28 PM posted to rec.aviation.soaring
Dave Nadler
On Thursday, August 30, 2012 1:49:24 PM UTC-4, Steve Leonard wrote:
Make a Duo Cuff for your Antares rigger.
The two gliders live in different places.
I guess I could buy another unit from Lange
and rework the cuff. Might require other mods
(increase height) - may be simpler to build
my own from scratch rather to buy a project !
See ya, Dave
Wing assembly dollies Udo Soaring 1 December 2nd 10 02:51 AM
USED One person assembly rig Tim Mara Soaring 0 May 1st 10 03:13 PM
assembly wing dolly Anoucement Udo Rumpf[_2_] Soaring 2 January 13th 09 06:53 PM
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg [email protected] Aviation Photos 0 April 11th 07 02:45 AM
USAFE commander: 86th Airlift Wing will divide for combat, support operations Otis Willie Military Aviation 0 November 27th 03 11:31 PM
