#11
I just helped a fellow pilot test his batteries because he was having in-flight issues with a low battery after just 2 hours. It turned out that his brand new 12Vdc 14Ah battery was defective.
We tested using a 1.2A load (http://aviation.derosaweb.net/#batterytest). His other batteries lasted 5-6 hours at that high load level. We measured his real load by adding one device at a time to the grid. The "all on" load at 1A (constant transmit, audio vario beeping, etc). The somewhat surprising big power hog turned out to be the charging of the battery in his PDA. |
On Sunday, September 23, 2012 6:15:04 PM UTC-4, Mike McCarron wrote:
Help! I have carefully measured my current draw in my glider at .8 amp. l would like to know if there is any reasonable explanation for why a 9 amp hour battery goes from 13 volts open circuit fully charged to 11.6 volts in 4 hours. MC Mike, Get a K2-Energy Lithium-Iron-Phosphate battery (http://store.peakbattery.com/12lfpba.html). They are expensive, but *much* lighter than the corresponding SLA type, and *much* better performance. TA |
Do a search on Shorai lithium. Less expensive than K2, especially on larger batteries. Available on Amazon too. No experience with them.
We live in interesting times, battery wise (and otherwise). bumper |
On 9/27/2012 10:04 AM, bumper wrote:
Do a search on Shorai lithium. Less expensive than K2, especially on larger batteries. Available on Amazon too. No experience with them. We live in interesting times, battery wise (and otherwise). They are probably fine batteries for their intended purpose - starting "powersports" vehicles, like snowmobiles, seados, etc. - but not for powering equipment. Their amp hour rating is deceptive, because the amp hour capacity mentioned is really about half the actual amp hour capacity of the battery. What they are selling you is a battery with same CCA rating (cold cranking amps) as an SLA battery that has the amp hour rating Shorai uses for it's "Powersports" battery. That's why it's cheaper - it's got have the Lithium in it. I'm not suggesting they are intentionally intending to deceive us, just pointing out they use the amp hour rating in a manner confusing to people who think it refers to capacity, and not "equivalent starting performance". -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
Power FLARM power | Andy[_1_] | Soaring | 9 | June 6th 12 12:38 AM |
battery power regulator | Tony V | Soaring | 17 | August 10th 11 05:39 AM |
Oshkosh Camping - Battery Power | Tom McQuinn | Owning | 3 | June 11th 07 12:19 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
battery charger to get through Piper power port? | Kyler Laird | Owning | 16 | March 20th 05 12:08 AM |
