Is it time to stop adding features to soaring software? Is it timeto focus on reliability?
Old December 11th 12, 04:37 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
Default Is it time to stop adding features to soaring software? Is it time to focus on reliability?
AGL wrote:
I'm still using XCSoar 5.2.4, because it has everything I NEED, and runs
with Stone-Axe reliability on my iPAQ 3950, which is STILL the best display
in sunlight I've seen yet.
I'm stil using SoarPilot, usually with a Palm Tungsten "T" or sometimes with
a Windows 5 device with a Palm emulator. It does everything I need. There
is an active YahooGroup of users, that is becoming quieter all the time
because no one seems to be able to come up with more improvement requests.
Frank Paynter used this at one time, and I'm not sure what he uses now or
what prompted a change. a list of what SoarPilot doesen't do would make for
interesting reading.
The hardware is getting old, but is still very readable in sunlight.
Nevertheless, I have installed XCSOAR and LK8000 on a PDA to play with in the
car this winter. Here's the problem with that: It's going to take me a long
time to become as throughly familiar with those, and even longer to trust
them. I fear errors of use more than software errors.
Fortunately we seem to have passed the point where we think that free means
inferior, but we still think that pretty means better.
So, until somthing substantial happens with screens, I'm sticking with what
I've got.
Same here! I still find SoarPilot on an old Tungsten T to be the best
system for me. Simple, easy to configure, and much better sunlight
readability than anything else I have tried. In over 8 years of flying
with SoarPilot, I have had to do a reset in flight just once, and that
was because of a damaged connector. I tried LK8000 on a Mio Moov. Even
with the screen brightness hack could not see it well enough to be
usable.
I am very interested in efforts with the eInk Nook and hope they are
successful. My old Tungstens won't last forever...
--- news://freenews.netfront.net/ - complaints: ---
Old December 11th 12, 04:59 PM posted to rec.aviation.soaring
Richard Brisbourne[_2_]
STILL the best
display=
wit=
h a Windows 5 device with a Palm emulator. It does
everything I need.
Th=
ere is an active YahooGroup of users, that is
time=
more improvement
requests.=
or=
f=
or interesting reading.
Never=
ca=
going to take me a
long=
errors. =20
means=
I'm sticking with
what=
I've got.
Having swapped my HP314 for a Vertica V1 a few
months ago, I reckon something substantial has
happened with screens. I can now manage LK8000
(data sourced from Flarm) comfortably in bright
sunlight wearing sunglasses for the first time. If you
can get a look at someone's Vertica, Glider Guider or
Oudie 2, you'll see what I mean.
Rather than put it in the car, I'd strongly recommend
playing with LK8000 at home either in sim mode or on
Condor if you have it before using it anywhere where
you need to give attention to something else. And
being ruthless about what features to disable.
Old December 11th 12, 05:18 PM posted to rec.aviation.soaring
pcool
We made unit tests to check complicated stuff like OLC realtime
calculations, FAI triangle calculations and such, in the development phase.
But generally I called "unit tests" the people doing individual checking of
each beta versions, and the experience shew that you need at least 300 of
them for 3 months to be relatively sure everything is ok. This is why I have
brought the beta phase to almost 12 months.
One way or another, you still need beta testing because obvious problems are
easy to fix, while the nasty stuff is always obfuscated and for Murphy's
laws will pass all unit tests, because tests did not consider the problem
(otherwise, you would have fixed it already).
Best would be to have both, of course. Xcsoar and LK can have hundreds of
betatesters, and dozens of eyes checking at the code and spotting problems.
But in the end, people doing debugging are just a few around the world, for
both projects. You can count people doing this work on xcsoar and lk8000
with fingers of one hand.
"Tobias Bieniek" wrote in message
We're all using our free time in a way which makes sense and fun. Finding
bugs, correcting them and even rewriting code just because once in the
past we took some shortcuts and now we're seeing the unwanted effects is
not fun.
Well... actually... I've been doing exactly that for three years on the
XCSoar project now and let me tell you that this can be fun too. For me it
was a learning experience that ultimately got me my current job and a few
other things before that.
and @Paolo: why do you have unit tests if you don't even trust them?
Old December 11th 12, 06:01 PM posted to rec.aviation.soaring
Max Kellermann[_2_]
Default Is it time to stop adding features to soaring software? Is ittime to focus on reliability?
Your use of the plural "tests" implies that there is more than one. However, that's an exaggeration, there's only one program (TestContest), and it's not even a unit test.
People are not unit tests. I think you misunderstand the meaning of the word "unit test", which is what this thread is about. You dismiss them as "useless" which you know too little about.
Not quite. We XCSoar developers fix a lot of bugs that are found by unit tests. By the time new code gets published, these bugs are fixed already. Unit tests help a lot during development, and save a lot of time.
Just look how many bugs you had to fix last week, that would not have happened with unit tests.
Hm. 4,638 pilots have installed XCSoar 6.5 preview releases on Android alone (number of unique Google accounts, no duplicates). The stable 6.4 version has been installed on Android by 22,005 pilots. Not counting all those people on Linux, Windows, WinCE, Mac OS X. Our bug tracker has 415 user accounts and 2,400 bug reports in the past 3 years. Lots of eyes, lots of bugs & bug fixes!
What makes me wonder is why you rejected the bug fixes I sent you today: https://github.com/LK8000/LK8000/pull/307
Old December 11th 12, 06:43 PM posted to rec.aviation.soaring
pcool
You wont find on github the test procedures for Contest and FAI, the latest
I remember. The contest test you mention is not the one we used.
In either cases I did not make them.
However this is not the point. I agree that having internal tests is better
than not having them! Of course.
Our 289 internal checks made with assertions can help, and did help, but
cannot be compared to your unit tests.
Honestly I cannot judge your code because I dont know it at all, but I am
sure it is well thought for this part as well.
You know the reason why I dont merge your code already, and it is not worth
discussing it here for a simple reason, which I think you agree on.
Some software manufacturers are just upset, to use a minimalistic word, by
the fact free software is now at a quality standpoint that is making a real
alternative to commercial products. Having one free software is already a
pain, having two is simply killing someone business.
It looks pretty funny to them, and not only , to read yours and mine
argumentations about how good or how bad one software is.
"Max Kellermann" wrote in message
phase.
even a unit test.
of
have
are
bugs & bug fixes!
Old December 12th 12, 12:04 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
usable.
I have similar problems, but I've found that turning terrain off and
setting the background map colour to white helps a lot. Then, you find
that the LK8000 overlay numbers are hard to read because they're white
with black outlines. So, set the overlay text colour to white and check
the 'inverse colours' box and now you have solid black letters on a
mostly white map (or you could just use something like dark blue for the
text).
Of course, I mainly fly in flat parts of the UK, so if you fly where most
of the land is standing on end and terrain shading is vital this may not
be a great solution.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old December 12th 12, 08:53 PM posted to rec.aviation.soaring
Wallace Berry[_2_]
usable.
text).
Thanks, Martin. I'll give that a try. Other than the readability issue,
a PNA and LK8000 seems like a very nice self-contained system.
Non-Stop Soaring Film Fest: Showcasing The Best Soaring Videos Kemp[_2_] Soaring 20 December 21st 11 10:25 AM
Stop FireFox From Broadcasting Time & Date - READ THIS! heirophant Piloting 4 February 7th 11 04:54 AM
Webbased software for managing time of takeoff and landings [email protected] Soaring 0 June 10th 08 03:14 PM
Cross Country the main focus of soaring? mat Redsell Soaring 77 October 18th 04 11:40 PM
Soaring Software Academy before SSA Convention Paul Remde Soaring 5 October 8th 04 04:59 AM
