#11
tongaloa wrote in :
Nathan Young wrote: On Tue, 10 Feb 2004 15:21:50 -0500, tongaloa wrote: mission requirements 250 kt cruise 2500 kt range 250 lb (pilot and 'stuff') 25,000 ft cruise altitude 250kt cruise is really pushing it in a piston engined airplane. A 421 can max out at 250kts, but cruise will be more like 220-230kt. The only exception might be a Lancair IV-P and this was posted to the homebuilt newsgroup, so that's a thought. Will have a look. Aerostar does 250kt OK at 25000. TIO 540's. Range is limited by 38-42GPH and gross - empty = 2000 lb. Looking for single that can do the 250kt and max gross - empty = big enough number for fuel plus 250lb. http://www.youngeagles.org/15000pics/15035.html Probably does not have the range though... -- ET ![]() "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams |
Lancair IV fitted with extra tanks in lieu of seating might work.
http://www.lancair-kits.com/Lancair_IV.html Cruise 330mph (280kts) Extended fuel option = 110 gallons Range = 1550 sm = 1347 nm fuel consumption = 18-22gph So to make up the remaining 1200nm of range required, you need 4.3 hrs of fuel or 94 more gallons. 94 gallons = 564 lbs The Lancair has a 1500lb useful load, so subtracting the 204 gallons (1224 lbs of fuel) = 276 lb of useful remaining. Just enough for the 250lbs pilot + gear. -Nathan |
Thanks you.
Just submitted some more resumes and purchased a lottery ticket ;-) -bob The Lancair has a 1500lb useful load, so subtracting the 204 gallons (1224 lbs of fuel) = 276 lb of useful remaining. Just enough for the 250lbs pilot + gear. -Nathan |
Thats what I was thinking. He is asking for an especially long range
but also an especially small payload for that power of airplane. So the real technology is how to fill up the plane with all that extra fuel? Internal wing tanks, more complex but puts the load where you want it, so you aren't going to fold the wings up if you hit turbulence. Diesel may be one technology to look at, already turbo for high alt, and very fuel efficient. Have to need a lot of gas to justify the lower power/weight ratio of the power-plant itself. Another point to make is extended flight over water is usually done by multi-engine aircraft for obvious reliability reasons. The Pacific Ocean is a big place; I'm not sure how comfortable I'd feel with the possibility of a single point failure in the most complex system in the aircraft causing me to ditch. tongaloa wrote in message ... Thanks you. Just submitted some more resumes and purchased a lottery ticket ;-) -bob The Lancair has a 1500lb useful load, so subtracting the 204 gallons (1224 lbs of fuel) = 276 lb of useful remaining. Just enough for the 250lbs pilot + gear. -Nathan |
Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 11:50 AM |
TrueType N number Font? | Errol Groff | Home Built | 3 | November 21st 03 01:43 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
ZZZooommm rant latest | Kyle Boatright | Home Built | 181 | September 19th 03 03:30 AM |
Phone number for Dillsberg? | Robert Bonomi | Home Built | 2 | September 9th 03 11:17 PM |
