Hmmm... a double-balloon balloon with wings. I wouldn't invest in
it/him. the double balloon concept: it could have better control over roll but it will expensive in terms of weight and drag. Extra fabric, structural components, etc. Then again is added control needed? We've been flying around in blimps/etc for a century without problems in this area (to the best of my knowledge). And pitch shouldn't be an issue, separate chambers inthe front/back of a -long- tube will fix that. Only 50% larger than a 747 to carry the same load? I'm using preliminary specs from the imaginary CL160 program from the Zeppelin company to extrapolate here. (but I consider Zeppelin a bit more credible, the current company is making rigid airships now; can the data be compared to the gravityplane is another matter) Anyways the CL160 is supposed to be 250m x 65m x 82m in length with a payload of 160 tons. The 747 is 70 meters long and has a load of 125 tons. So then the gravplane needs to be roughly 3x the length. I wonder how the inventor got the 4x improvement numbers over existing wind turbines. Some data along with the claims would be nice. Overall the general concept is sound, we all know it could work. There's nothing cutting edge about this and current algorithims and models will work- so why does he need to prove the idea in the ocean? Submarines have diveplanes. Why the glider tests? We already have gliders and balloons. To me he seems like a crackpot inventor just wanting to play. If he was serious why not break out the engineers to see what is feasible technically abd draw up some real plans, and then bust out the finance types to see if it is worth doing? my .02 -lance smith "Louis L. Perley III" wrote in message ... Saw an article today about an aircraft that would change it's buoyancy, so it would float up like a balloon and then change buoyancy and glide down. Interesting stuff, although I doubt we'll see it anytime soon. Is something like this even practical? The article says they take the aircraft up 10 miles to get 400 miles range, I would think ATC wouldn't like the idea of a free balloon (which is what it would be at that point) up in the flight levels. http://www.machinedesign.com/ASP/vie...PACE&catId=379 |
![]() "Louis L. Perley III" wrote in message ... Saw an article today about an aircraft that would change it's buoyancy, so it would float up like a balloon and then change buoyancy and glide down. Interesting stuff, although I doubt we'll see it anytime soon. Is something like this even practical? The article says they take the aircraft up 10 miles to get 400 miles range, I would think ATC wouldn't like the idea of a free balloon (which is what it would be at that point) up in the flight levels. http://www.machinedesign.com/ASP/vie...PACE&catId=379 1) I wonder why a typical blimp has to use such a large volume (the ballon) to provide the lift and a relatively tiny cabin attached underneath, whereas this craft seems to use a much smaller volume (the wings). Has the inventor calculated this correctly? 2) Where is the power source? Conservation of energy says that the plane could not continue to ascend and descend without some input of energy. The initial ascent would be powered by the energy required to separate helium from the atmosphere, which is accomplished on the ground, but it should not be true that the plane would "always land with its tanks fully pressurized", since theoretically the amount of energy generated by the turbines during the descent could not be enough to compress the gas used for the ascent. Esecially if the efficiency of the turbines is 20%. On the other hand I still think that Boeing 747s get off the ground by some sort of magic. There is no way such a huge vehicle could be lifted by thin air. |
"Marc" wrote:
2) Where is the power source? Conservation of energy says that the plane could not continue to ascend and descend without some input of energy. A gas balloon can oscillate up and down by harnessing the temperature differential with altitude. As it rises, it cools, the gas contracts and the balloon then falls to lower, warmer, altitudes, where the gas expands and the cycle repeats. It could in theory have wings that allow it to glide somewhat during each cycle. I seriously doubt the practicality of such a craft. A similar concept, alluded to in the text, is currently used in extremely low powered ocean monitors that use a phase change material for buoyancy control. The phase change material has a larger volume when cold, so it rises when submerged to a chilled depth. Winglike structures let it "glide" towards the desired location to be sampled. They're slow, but effective and can cruise for months. Electronics are powered by solar energy at the surface during each cycle. The initial ascent would be powered by the energy required to separate helium from the atmosphere, which is accomplished on the ground, but it should not be true that the plane would "always land with its tanks fully pressurized", since theoretically the amount of energy generated by the turbines during the descent could not be enough to compress the gas used for the ascent. Esecially if the efficiency of the turbines is 20%. Agreed. Todd Pattist (Remove DONTSPAMME from address to email reply.) ___ Make a commitment to learn something from every flight. Share what you learn. |
Todd Pattist wrote in message . ..
"Marc" wrote: 2) Where is the power source? Conservation of energy says that the plane could not continue to ascend and descend without some input of energy. A gas balloon can oscillate up and down by harnessing the temperature differential with altitude. As it rises, it cools, the gas contracts and the balloon then falls to lower, warmer, altitudes, where the gas expands and the cycle repeats. It could in theory have wings that allow it to glide somewhat during each cycle. I understood that as the balloon rises, the decreasing atmospheric pressure allows the balloon to expand, displacing more air and increasing lift to compensate. Some guy invented a black balloon some years ago, really big, that was entirely solar powered. It worked. Dan |
![]() "Marc" wrote in message news:tXH0c.9865$ko6.197285@attbi_s02... 1) I wonder why a typical blimp has to use such a large volume (the ballon) to provide the lift and a relatively tiny cabin attached underneath, whereas this craft seems to use a much smaller volume (the wings). Has the inventor calculated this correctly? Those two big pontoons are also being used for lift. The cargo/passengers ride in the small section between the wings. Whatever else you can say about it, this thing is enormous. It is really just a huge double dirigible with wings. The wings double as additional helium storage. If it were my design I would replace the wind turbines with conventional blimp engines and use the wings and rudders for directional control, folding the props to reduce drag during the glide portion of the flight. This would give greatly improved range and controllability during the climb. Right now his aircraft has a claimed range of only 400 nm, hardly worth the effort given the costs involved. It is not really a "perpetual motion machine" any more than any other lighter than air aircraft. The compressed air stored by the turbines is not used to provide lift. It can provide some thrust, but not enough to keep the aircraft flying indefinitely, nor does the inventor claim any such thing is possible. Obviously they are not able to store much air during the descent, which is why the aircraft has such a short range. When you get right down to it, I have to wonder why he is bothering with them at all. Although it is short range and slow, it is expensive. People have been fooling around with various winged blimp designs for years. Perhaps some day someone will come up with something workable. |
Louis L. Perley III wrote:
Saw an article today about an aircraft that would change it's buoyancy, so it would float up like a balloon and then change buoyancy and glide down. Interesting stuff, although I doubt we'll see it anytime soon. Is something like this even practical? The article says they take the aircraft up 10 miles to get 400 miles range, I would think ATC wouldn't like the idea of a free balloon (which is what it would be at that point) up in the flight levels. http://www.machinedesign.com/ASP/vie...PACE&catId=379 -- Louis Perley III N46000 - KBJC A blimp pakaged in such an areodynamic package and the 40:1 glide ratio from something that drives air compressors is a bit tough for me to chew on. John Roncallo |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Best Home Base Work | Reynard | Owning | 0 | November 9th 04 04:37 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Highest-Ranking Black Air Force General Credits Success to Hard Work | Otis Willie | Military Aviation | 0 | February 10th 04 11:06 PM |
Ford V-6 engine work | Corky Scott | Home Built | 19 | August 21st 03 12:04 PM |
