Jay
QFE QFE is a Q code used by pilots and air traffic control to refer to the current air pressure which will calibrate the pilots altimeter to give actual height above the ground at a particular airfield. Sometimes it's easier to go to Google and type the word or phrase in to get an answer vs asking the group and waiting around for an answer G Big John On Tue, 2 Mar 2004 10:56:21 -0700, "Jay Beckman" wrote: ----clip---- Newbie ignorance: What does QFE stand for? Jay Beckman Chandler, AZ Student Pilot 3.2 Hrs ... Nowhere to go but up? Jay. Remember what goes up must come down (hopefully under control) G |
you can't set QFE when the field elevation is that high above sea level
BT "Joe Morris" wrote in message ... "Jay Honeck" writes: The pilot survived, right? His health is fine. His career, I sadly suspect, is not. A comment from one of the ASF people at a CFIRC I was at over the past weekend was that he is now flying a desk at the Pentagon. The same man stated that the problem was that the pilot had become too comfortable with practicing the maneuver at his home base, which was about 800 (+/-; I don't recall the exact number) feet lower than the airfield at which the accident occurred. At the accident location he set up the split-S so that the top was at the proper altitude MSL -- at his home base, meaning that the entire maneuver was executed 800 feet lower than it should have been. I have *no* military jet experience, but especially for airshows I'm somewhat surprised that there isn't an altimeter set to QFE to serve as a sanity check against exactly this sort of problem. Joe Morris |
Why not
"BTIZ" wrote in message news:fg81c.12502$id3.1896@fed1read01... you can't set QFE when the field elevation is that high above sea level BT "Joe Morris" wrote in message ... "Jay Honeck" writes: The pilot survived, right? His health is fine. His career, I sadly suspect, is not. A comment from one of the ASF people at a CFIRC I was at over the past weekend was that he is now flying a desk at the Pentagon. The same man stated that the problem was that the pilot had become too comfortable with practicing the maneuver at his home base, which was about 800 (+/-; I don't recall the exact number) feet lower than the airfield at which the accident occurred. At the accident location he set up the split-S so that the top was at the proper altitude MSL -- at his home base, meaning that the entire maneuver was executed 800 feet lower than it should have been. I have *no* military jet experience, but especially for airshows I'm somewhat surprised that there isn't an altimeter set to QFE to serve as a sanity check against exactly this sort of problem. Joe Morris |
"BTIZ" writes:
you can't set QFE when the field elevation is that high above sea level Perhaps not on a regular (civilian) aircraft altimeter, but given the number of toys that are part of a typical military bird it would seem that something as simple as a parachute jumper's alitmeter (which *is* designed to be set to QFE) would be a good, inexpensive way to do a sanity check on altitudes used in low-level aerobatics. Joe Morris |
If you think the videos are something you should have seen it first
hand like I did... very surreal to see it happen when you aren't expecting it. Dean "Jay Honeck" wrote in message news:_HO0c.450298$na.1090802@attbi_s04... Many thanks to this group's own John Osterhout for forwarding me these cool videos of the Thunderbirds crash from last fall: http://www.alexisparkinn.com/aviation_videos.htm There are two separate videos -- one shot from inside the cockpit (that many of us have seen, but is still remarkable) -- and one taken by a spectator that I'd never seen before. It shows the entire event from start to horrible finish. Having seen the T-Birds do their show dozens of times, flawlessly, it's still hard to believe that they made such a simple mistake. (The final judgment was that the pilot had set his altimeter incorrectly, resulting in insufficient altitude for the maneuver.) |
hand like I did... very surreal to see it happen when you aren't expecting it. That describes a plane crash pretty well. I witnessed a fatal crash at an airshow ten years ago, (the "stolen Piper Cub" routine gone very, very wrong) and it STILL seems surreal in my memory. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
snip still hard to believe that they made such a simple mistake. (The final judgment was that the pilot had set his altimeter incorrectly, resulting in insufficient altitude for the maneuver.) He didn't exactly (allegedly) "set" his altimeter incorrectly. According to Avweb: "The pilot incorrectly climbed to 1,670 feet AGL instead of 2,500 feet before initiating the pull-down to the Split-S maneuver, according to the Air Force news release. The pilot, Chris Stricklin, 31, apparently flew by mistake to the MSL altitude used when practicing the maneuver at his home base, Nellis AFB in Nevada, which is 1,000 feet lower than the Idaho field elevation." Regards, Rob |
Great shot of the Thunderbird F-16 Ejection | Jay Honeck | Piloting | 51 | February 3rd 04 10:31 PM |
Thunderbird pilot found at fault in Mountain Home AFB crash | Ditch | Military Aviation | 5 | January 27th 04 01:32 AM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Thunderbird crash photos | mowkie | Military Aviation | 0 | October 21st 03 04:49 PM |
Thunderbird crash today | John Doe | Military Aviation | 12 | September 16th 03 05:56 AM |
