Parachute Comfort
Old March 28th 13, 07:15 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Parachute Comfort
I mounted a 1050 BRS canister below the rear hatch. The Genesis was designed with BRS in mind, but never tested. The bridle mounts to the 4 lift-fitting, hard points just inside the skin. When deployed below 130 knots and not over 1050 GW, it will bring me down wings level with nose down about 30 degrees. If I should get center-punched bad enough to wipe out the BRS, I figure I would no longer be among the living, anyway. I feel very secure with my little red handle at arms reach and talk about a comfortable cockpit!
JJ
Old March 28th 13, 08:57 PM posted to rec.aviation.soaring
Craig Funston[_2_]
JJ
JJ, that's a pretty nice situation. Even though I rehearse the bailout sequence frequently, I've only got nominal confidence of getting out in a real emergency. Side mounted SH canopy drops my confidence even lower.
Craig
Old March 28th 13, 10:26 PM posted to rec.aviation.soaring
Frank Whiteley
JJ
But JJ, unlike most of us, you have confidence (and experience) in capsule descents;^)
Old March 29th 13, 01:05 AM posted to rec.aviation.soaring
Paul Remde
Hi Frank,
You have me very curious about that comment. Was JJ an astronaut?
Paul
___________________
"Frank Whiteley" wrote in message
JJ
descents;^)
Old March 29th 13, 01:20 AM posted to rec.aviation.soaring
Tom K (ES)
Or a 'Vark driver??
Old March 29th 13, 01:53 AM posted to rec.aviation.soaring
Frank Whiteley
On Thursday, March 28, 2013 7:20:58 PM UTC-6, Tom K (ES) wrote:
Or a 'Vark driver??
That's it. Came down safely somewhere near Roseville, CA, IIRC. McClellan AFB was depot maintenance for the F-111 and they had to be test flown at the end of the visit of course.
Old March 29th 13, 01:18 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Actually, we parked a F-111F on the south side of Carson Sink east of Fallon, NV in 1972. Got her into a spin at 20,000 feet. After holding stick full forward, rudder neutral and roll-augmentation off for 8000 feet, we raised the little handles........everything worked as advertised. Sure is nice to have a readily available back up plan.
JJ
Old March 29th 13, 01:53 PM posted to rec.aviation.soaring
Clay[_4_]
JJ
Thanks to all you guys out there who have served. I could read this kind of stuff forever. Please don't be shy about it.
Old March 29th 13, 03:48 PM posted to rec.aviation.soaring
"Paul Remde" wrote in message ...
Paul,
No, JJ was a F-111 Weapons Officer
_______________________
Hi Frank,
Paul
___________________
JJ
descents;^)
Old March 29th 13, 03:50 PM posted to rec.aviation.soaring
Frank Whiteley
JJ
I think I confused that with one that happened while I was at McClellan in the early 1980's that ended near the RR tracks near Roseville. Certainly more 'interesting'.
Frank
Extending new pilot comfort zone? tstock Soaring 14 January 13th 11 07:44 PM
Country Comfort for EAA writewoodz Home Built 1 September 30th 10 09:52 AM
Lightnings In Art, pt 1 - Jack Fellows - Too close for comfort.jpg (1/1) Mitchell Holman Aviation Photos 0 January 12th 07 03:02 AM
Passenger Comfort..... [email protected] Soaring 32 August 9th 05 02:39 PM
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 08:03 PM
