Who's flying out of the higest elev airport?
Old March 8th 04, 04:34 PM
Newps
Hey, I live at 3650 and can't set my altimeter to zero.
Dudley Henriques wrote:
Hey, you mountain types out there :-) I'm doing some research on a safety
issue and need your help . I need a post from someone flying out of Colorado
somewhere, preferably Telluride or a field very close to Telluride. I need
as close to the highest elevation in the U.S. as I can get.
I'm not dealing with this issue in the context of right or wrong as it
pertains to mountain flying. I need to know if the Kollsman window in your
altimeters has a wide enough range to allow you, IF YOU DESIRED TO DO SO, to
set your altimeters to 0 elevation on a consistent basis before take off at
your field instead of a MSL setting. Again, I'm only interested in the
possibility, not the right and wrongs involved with doing this.
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
Old March 8th 04, 05:27 PM
Dudley Henriques
Thanks Newps; that jives with what I have so far anyway. I'm assuming a 27.5
low end on the Kollsman. Does that sound right to you. I'm at home and can't
check it :-)
Dudley
"Newps" wrote in message
news:5g13c.523826$na.1181072@attbi_s04...
safety
Colorado
need
your
SO, to
at
Dudley Henriques
the z's with e's.
Old March 8th 04, 06:50 PM
Newps
I was just at the airport today and I looked at my new overhauled United
altimeter. The lowest setting is 28.10. There is a little travel past
that but you'd have to guess at what the setting really is. The station
pressure here is usually around 26 inches. Looks like the highest
altitude for which you could correct to zero will be about 2000 MSL,
depending of course on the actual altimeter setting.
check it :-)
Dudley
safety
Colorado
need
your
SO, to
at
Dudley Henriques
the z's with e's.
Old March 8th 04, 07:09 PM
Dudley Henriques
I have it at present somewhere between 2500 and 3000 feet ASL as a possible
limit parameter based on averaging out the altimeter settings for the U.S.
It's interesting about the low Kollsman number range. With 28.10, I'm
beginning to see some variables in the low range that I didn't know was
there. I always assumed all the Kollsmans would all be the same. It will be
interesting to see if others have different numbers for their Kollsmans.
D
news:Mf33c.87121$PR3.1225813@attbi_s03...
27.5
can't
check it :-)
Dudley
safety
Colorado
need
your
SO, to
off
at
Dudley Henriques
the z's with e's.
Old March 8th 04, 08:51 PM
Stan Prevost
Dudley, I found reference to an air data computer which would accept an
altimeter setting of 26.75 to 33.00.
Stan
"Dudley Henriques" wrote in message
nk.net...
Colorado
to
at
Dudley Henriques
the z's with e's.
Old March 8th 04, 09:02 PM
Dudley Henriques
Thanks Stan; that's an additional data point for sure.
D
"Stan Prevost" wrote in message
Stan
nk.net...
safety
Colorado
need
your
SO,
to
at
Dudley Henriques
the z's with e's.
Old March 8th 04, 09:40 PM
John Galban
"Dudley Henriques" wrote in message ink.net...
I'm not flying out of a high mountain airport (at the moment), but I
can tell you that most of GA aircraft altimeters I've seen only adjust
down to about 28.00. This makes setting a "0" elevation troublesome
above 2500 ft. MSL.
Old March 8th 04, 10:05 PM
Dudley Henriques
That's about what I'm getting also John. Thanks.
What I actually needed to know was the lower range on the Kollsman, which is
turning out to be just about where you have it at 28. I actually have it at
27.5 at this point, but considering averages, this puts the max 0 set about
where you are with it.
D
"John Galban" wrote in message
om...
ink.net...
SO, to
at
above 2500 ft. MSL.
Old March 9th 04, 12:13 AM
C J Campbell
For some reason, Dudley, your query reminds me of the old joke "How thick is
the atmosphere?" The answer, of course, is "100 miles, but don't tell the
pilots -- they think it is only 29,920 feet thick on a standard day."
Old March 9th 04, 03:10 AM
Marty Shapiro
nk.net:
safety issue and need your help . I need a post from someone flying
out of Colorado somewhere, preferably Telluride or a field very close
to Telluride. I need as close to the highest elevation in the U.S. as
I can get. I'm not dealing with this issue in the context of right or
wrong as it pertains to mountain flying. I need to know if the
Kollsman window in your altimeters has a wide enough range to allow
you, IF YOU DESIRED TO DO SO, to set your altimeters to 0 elevation on
a consistent basis before take off at your field instead of a MSL
setting. Again, I'm only interested in the possibility, not the right
and wrongs involved with doing this. Thanks,
Dudley Henriques
the z's with e's.
I don't have any direct experience with the airports in CO, but my pilots
guide shows LXV (Lake County Airport, Leadville, CO) is at 9,927' MSL. TEX
(Telluride Regional Airport) is 9,078' MSL.
The highest airport I've landed at is TVL (South Lake Tahoe, CA). The
alitude there is 6,264' MSL. None of the aircraft I flew to TVL (C172,
C182, RALL) had an altimeter which could have been set to indicate 0' at
that altitude.
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
Airport Manager position, Fitchburg, MA David Reinhart Piloting 6 August 12th 03 11:46 PM
