On Thursday, May 23, 2013 9:54:12 AM UTC-4, WB wrote:
In article , wrote: "Then, there was a Swiss company that made egg shaped trailers. " There was a 301 Libelle on our field for quite some time with a big advertisement and the slogan "Wer wagt gewinnt" (along the lines of "you gotta take some chances to win" or "he who dares, wins"). I forget the brand it was advertising. It was quite a sight. P3 |
Also - it always amazes me that most tube/box trailers are made just barely big enough to contain the glider. My 15 came with an old wooden monocoque type trailer when I bought it. Unfortunately the deteriorating fiberglass sheathing and the Pacific Northwest climate conspired to return it to nature pretty quickly because it actually functioned well. The fuselage went in nose first on a big stable dolly, the wings went in root first also on big stable dollies, the horizontal stab hing from the ceiling just like in a clamshell. The smartest thing the builder did was to make it roomy. There was actually enough room inside to walk from the back to the front with the glider inside (a little over a foot of clearance between the wing and fuselage). This meant that when moving the wings in or out you could hold the tip at the height that was best for your back and not have to worry about the leading or trailing edge scraping on the trailer or fuselage.
After it disintegrated I replaced it with a clamshell which is even better. |
On Monday, May 20, 2013 4:17:24 PM UTC-7, quietpilot wrote:
Curiously. how does a minden tube differ from a normal tube or clamshell? I've had a Minden trailer for the past 8 years or so. I don't seem to have any trouble assembling that is the fault of the trailer. I've made a few modifications. I added a wood center rail so I don't have to pick up the tail. (I see some guys with Cobra's have to lift the tail.) I also made a wheeled/lever to the ramp to lift the cradle ( like this http://www.youtube.com/watch?v=YP2AD8rtdpA) as the single jack was too floppy. (No problems with leaky jacks like some Cobras) No critters in the years I've had it. Seems to keep the dust out. No worries about the top coming off and the hitch tube hasn't broken. That said I do need to paint the top or remove the paint that is on the sides so it's all bare aluminum. But I think I'll fly instead. Steve DG-200 in a Minden trailer. |
I have a new to me Minden Fab trailer with Grob Speed Astir and associated trailer rigging inside. I'm interested to find out what the differences are depending on the year these were built and type of glider specific equipment they have. My trailer has a dual track ramp and single screw jack with a wide steel ground brace for the fuselage dolly. It's a little wobbly and I'm considering adding one of the leverage bar systems as discussed above. The wings have a dolly at each end. The root dolly has a pipe and attach fitting using one of the Grob twist locks and a hold down bar with wing nuts over the spar stub to secure the wing and keep it vertical. The tip dolly is a simple dual wheel dolly. The trailer has eye bolts in the floor inboard of the tips which the previous owner used to tie down the tips for transport but this tends to pull the tips in towards the fuselage tail. Do any other Minden owners have eye bolts on the outside of the wing tips that would help keep them away from the tail yet help secure the wings? Over all while using an Udo one man rigger the trailer seems to work fairly well other than having to climb inside to release the tail hold down strap.
1-26 Inner Tube Mayhem | JohnDeRosa | Soaring | 5 | May 8th 12 11:27 PM |
L-23 inner tube | Bruce | Soaring | 1 | September 3rd 08 06:21 PM |
Planning a Minden Vacation?-Rating? Soar Minden Block Time FS SAVE SOME MONEY! | [email protected] | Soaring | 1 | January 27th 06 07:16 PM |
pitot tube down | Emilio | Military Aviation | 16 | March 6th 04 11:37 PM |
Aluminum tube, 2.25" ID | Rick Pellicciotti | Home Built | 0 | October 2nd 03 08:24 PM |
