#11
Hi,
It will be interesting to see what plays-out in regard to the parts and Cambridge name. Roy Ridgeway has expressed interest in selling what's left, but hasn't put a price on it. Since new 302 sales have been extremely slow for the last year or 2, it seems to me that the only value is in the parts. Hopefully Roy will see it that way too. I would be interested in buying the parts, but probably can't afford them. I can currently calibrate, re-seal and replace backup batteries in 302s. If I had access to parts I could do much more. Gary is not interested because he's very busy with ClearNav work. Dickie Feakes is a very experienced 302 support person in the U.K. He has agreed to repair 2 units that are in need of repair. He has some parts in his stock - including the parts necessary for the 2 repairs. I sincerely hope that some was will be found to support 302 units going forward. Good Soaring, Paul Remde Cumulus Soaring, Inc. _____________________________________________ wrote in message ... Gary & Rodger need to come to an agreement, assuming Gary even wants to support the 300 series, we need to officially dissolve the no-compete or whatever has kept Gary from working on the newer cambridge stuff. Someone Must offer repair service for the thousands of Cambridge units in the USA. Understand, we are not talking about the ability to calibrate or to make simple repairs, Paul and Dickie are capable of that, from what I know Gary is probably the only person who can realistically trouble shoot and repair these things for the Soaring Community. |
On Thursday, May 23, 2013 12:11:18 PM UTC-4, wrote:
Better vario: Immense. Nothing matters as much. What can I do with a better -- and carefully set up -- vario? Outclimb people who think I have some actual thermaling ability. Climb when they land. Roll into that savior bullet thermal that looks like a gust on their varios. With the cost of a relight at $50+, a vario that keeps you in the air more should pay for itself. I thought that a vario needed to use the 3-D inertial sensor to sort out the horizontal and vertical components of "gusts", and I thought that nobody was doing that just yet. Or does the inertial sensor just make the filtering better? |
On Thu, 23 May 2013 16:05:09 -0500, Wallace Berry wrote:
Better instruments is better instruments. I get that. I just keep thinking these expensive systems must do something other than be incrementally better. How much better is a new super vario than a well compensated Borgelt B40? Would a super vario make that much difference in a club class ship? If I'm cruising faster than 70, it is such a booming day that a pellet vario would be overkill. Now, filtering out horizontal gusts is a feature I would be willing to shell out the bucks for (assuming I would not have to put up with waiting for the "Next Software Upgrade" to get the advertised features and off-again-on-again technical service)! FWIW, and as a Libelle driver, I have an SDI C4 as my main vario (I already had it when I got the Libelle and I like its noises and nice, big LCD display), a Borgelt B.40 as backup vario (thanks to the 9v battery strapped to its back) and a really cheap Binatone B.350 satnav running LK8000 to take care of the rest of the navigation tasks. The B.350 has been replaced by the R.350 and costs from £50 ($US 76): it runs LK8000 (I've checked), the screen is bright enough to use in the relatively shaded Libelle cockpit and, sitting on a flexi RAM mount in front of the panel, unlike with many of the bigger PDAs I can easily see everything else on the panel. This shows what I mean: http://www.gregorie.org/gliding/libelle/FLARM_panel.jpg I don't race but I do go XC with this kit. HTH -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
The full approval for the Triadis can be read at:
http://www.ukiws.demon.co.uk/GFAC/approvals/triadis.pdf To claim approval for the Display Unit is incorrect and misleading. A Butterfly Vario installation always consists of Integrated Sensor Unit (ISU, small box also including all sensors and the triadis RU3 flight recorder) and the Display unit. There have been many multi-subsystem installations with IGC-Flight Recorders in the past, e.g. Zander, LX, CAI, and this is just another one. What is misleading? Thanks Marc |
https://groups.google.com/forum/?fro...ng/S-xv58PSe0Q |
I believe the advice given by an English 2x World Champion is to have a
good, well compensated, leak free, simple, vario then spend the difference on Aerotows. Likewise most modern (Standard Class) gliders have a kink in the polar, such that best speed to fly for almost any rate of climb is somewhere around the kink. So there are in fact only two speeds to fly; at the kink if you're comfy, best LD if you're in survival mode. So for the original Discus (Dry) it's either 80kts or 50kts PF At 14:00 23 May 2013, Wallace Berry wrote: In article , The more I read about high end instruments, the less I regret not being able to afford them. I have asked a number of people to explain to me exactly what their "super varios" do that a good basic vario and a decent PDA/software setup does not do. I mean besides calculating to more decimal places. Maybe I would understand if I flew a glider with more than two speeds.... |
At 08:46 24 May 2013, Peter F wrote:
I believe the advice given by an English 2x World Champion is to have a good, well compensated, leak free, simple, vario then spend the difference on Aerotows. Likewise most modern (Standard Class) gliders have a kink in the polar, such that best speed to fly for almost any rate of climb is somewhere around the kink. So there are in fact only two speeds to fly; at the kink if you're comfy, best LD if you're in survival mode. So for the original Discus (Dry) it's either 80kts or 50kts PF I had the great pleasure of flying with the same English 2x World Champion two weeks ago. His advice for modern 18m gliders was also two speeds, 90-100kts or 60kts. I tried it, it works! Mike |
| Thread Tools | |
| Display Modes | |
| Where is Cambridge Aero Instruments | Dan Marotta | Soaring | 2 | February 28th 12 02:05 AM |
| Cambridge Aero Instruments - The Future Looks Bright | Paul Remde | Soaring | 0 | June 27th 08 04:27 PM |
| Cambridge Instruments | Ian McPhee | Soaring | 2 | June 18th 04 11:14 AM |
| Cambridge Aero Instruments | Ulrich | Soaring | 6 | August 7th 03 06:48 PM |
| Cambridge Aero Instruments Inc. Changeover | Joe McCormack | Soaring | 3 | July 30th 03 09:45 PM |
