Improved shear/stall-spin alarms
Old June 10th 13, 04:39 PM posted to rec.aviation.soaring
Bill D
Default Improved shear/stall-spin alarms
On Monday, June 10, 2013 9:03:38 AM UTC-6, Dan Marotta wrote:
You should really learn to feel the aircraft and not rely on
horns, bells, whistles, gauges, etc. They WILL fail some day...
Straw man argument.... 99.9% of the time they don't fail and they save lives.
I can assure I do know what an impending stall feels like. However, for most people, it doesn't take much distraction for them to miss the sensations.. Our miserable safety record proves that.
The entirety of aviation, excluding gliders, has found AoA/stall warning systems necessary whether it's high performance jets or airliners. Presumably, the professionals flying them can feel a stall developing but their stall warning systems are still a no-go item.
Old June 10th 13, 05:04 PM posted to rec.aviation.soaring
Dan Marotta
Yes, I know that the MEL requires a lot of stuff. Still, what do you do
when it fails?
My argument is not so much about the equipment as it is about slavishly
relying on devices to bring you home. You WILL have electrical failure some
day and will have to actually read a map, land visually, respond to light
signals from a control tower, pick up a wing with rudder instead of aileron.
Your 99.9% argument omits the 0.1% and that's a lot higher number than the
number of accidents per 100,000 flying hours.
Aviation requires nothing but skill and attention in maintenance and
operation. Bells and whistles are mandated by the barn door closers.
"Bill D" wrote in message
lives.
sensations. Our miserable safety record proves that.
Old June 10th 13, 07:31 PM posted to rec.aviation.soaring
Michael Huber
Has anyone tried any of various AOA instruments on the market?
There are
several under $1000.
Except, there's no need for a separate probe, just use the glider's
nose as a probe's nose cone and add the pressure sensing ports.
If you are looking for a simple DIY AoA indicator you might want to
check http://www.akaflieg.tugraz.at/akagproj.html
Parts cost around $20, and you can build it in an evening. The
downside is that there is no good integration with XCSoar yet, but
that might change if there is enough interest.
Michael
Old June 10th 13, 07:40 PM posted to rec.aviation.soaring
Vaughn
I don't fly either jets or airliners, but I can tell you that the
average Joe learning to fly in, or renting, an old Cezzna probably can't
hear the stall alarm because they were never designed to overpower the
noise isolation of today's headsets.
Old June 10th 13, 08:00 PM posted to rec.aviation.soaring
Bill D
There are
Michael
The electronics look clever but putting a vane on a fin-mounted TE probe isn't going to work for anything but measuring the wing's down-wash angle. A vane needs to be on the nose well ahead of the wing where, unfortunately, it's likely to get broken. To me, pressure ports on the top and bottom of the nose cone seems the least intrusive.
Old June 10th 13, 08:03 PM posted to rec.aviation.soaring
Bill D
Well...as one data point, my hearing isn't great and I wear an excellent noise cancelling headset but I can plainly hear a Cessna stall warning.
Old June 10th 13, 11:14 PM posted to rec.aviation.soaring
Vaughn
I can't, and that's with about a decade of experience with a pretty wide
selection of rental Cezznas using both passive and electronic headsets.
Surely I'm not alone.
Old June 10th 13, 11:22 PM posted to rec.aviation.soaring
Bill D
Audible warnings are not the right thing anyway what with all the toots and beeps in glider cockpits. A light plus a cellphone vibrator motor in the stick grip seems better.
Old June 11th 13, 03:06 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dan Marotta wrote, On 6/10/2013 9:04 AM:
when it fails?
some day and will have to actually read a map, land visually, respond to
light signals from a control tower, pick up a wing with rudder instead
of aileron. Your 99.9% argument omits the 0.1% and that's a lot higher
number than the number of accidents per 100,000 flying hours.
Yes, devices fail, but so do people. If the device fails less often than
the people, would you accept the device as useful?
My experience is I fail more often than the devices, such as gear
warnings, slow speed warnings, automatic hookups, and more. My radios
have worked reliably, but I haven't always set the frequency correctly.
I made more mistakes with paper maps than I ever did because the GPS
failed, and I've flown more hours with GPS than with maps.
I think each device has to be evaluated for efficacy, not discarded
because it might fail some day. If we treated pilots the same way, there
would be no pilots, either.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old June 11th 13, 08:22 PM posted to rec.aviation.soaring
Michael Huber
down-wash angle.
Trust me, this position works fine for a glider, the only reason to
change it would be a retractable engine. The vane is of course
affected by down-wash, but as an approximation, down-wash angle is
proportional [1] to the angle of attack. This means an angle measured
in this position is not really the angle of attack, but an angle
proportional to AoA. With proper calibration this is just as fine for
the purpose of a stall warning.
The sensor itself could be placed in any position (remember, it´s
wireless), but for a glider stall warning device the TE probe is a
reasonable compromise.
Michael
[1] Down-wash is not proportional to AoA anymore close to the critical
AoA, but it still works.
Another stall spin Jp Stewart Soaring 153 September 14th 12 07:25 PM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
