Anybody running a Butterfly Vario with XCSoar?
Old July 18th 13, 01:13 AM posted to rec.aviation.soaring
son_of_flubber
Default Anybody running a Butterfly Vario with XCSoar?
On Wednesday, July 17, 2013 5:56:21 AM UTC-4, Max Kellermann wrote:
On Wednesday, July 17, 2013 2:28:21 AM UTC+2, son_of_flubber wrote:
Does anyone know if XCSoar correctly interprets the wind direction information that it gets from a V7?
This question cannot be answered, because the V7 does not send a wind estimate over the wire.
Right, the issue never comes up. The V7 calculates a wind vector for it's internal "get home" function, but it sends airspeed "over the wire" to XCSoar. XCSoar combines the V7 supplied airspeed with the GPS supplied ground speed and direction to calculate a wind vector.
XCSoar can calculate wind based on GPS position (alone) over time but the V7 supplied airspeed makes the wind calculation more accurate and robust.
Did I get that right?
Old July 18th 13, 03:22 AM posted to rec.aviation.soaring
jfitch
I will say that the inertial derived wind vector from the Butterfly Vario is awesome.
Old July 18th 13, 04:40 AM posted to rec.aviation.soaring
Max Kellermann[_2_]
Mostly right, let me clarify:
With just GPS, XCSoar can only use the "Circling" algorithm, which compares ground speeds in opposite circle positions. Wind calculation occurs only while thermalling.
With airspeed input, XCSoar uses an Extended Kalman Filter (https://en.wikipedia.org/wiki/Extended_Kalman_filter) which continuously compares airspeed and ground speed, and can always derive an accurate wind vector while flying straight.
There is a big difference in quality/accuracy and speed between the two algorithms. According to my tests, the EKF algorithm delivers the exact wind after flying straight for less than 20 seconds, while the circling algorithm takes more than a minute of circling, with varying results.
For those curious, this link has a dump:
http://bugs.xcsoar.org/ticket/2961#comment:4
This is a bug report from a user, he uploaded a NMEA dump, which I fed into both algorithms. Observe the volatility of the CirclingWind results.
TL;DR - feeding airspeed into XCSoar is totally worth it. Get a vario that is capable of doing so.
Old July 18th 13, 03:29 PM posted to rec.aviation.soaring
Marc - Butterfly Avionics
Latest version of Butterfly Vario Firmware (more accurate: Butterfly NMEA Interface Unit firmware contained in the latest release) rotates output on LXWP 180° so that it matches XCSoars assumption.
Still don't know if this makes sense, yet it will work for now and I guess its a good idea to share the XCSoar teams assumption...
Cheers
Marc
Old July 15th 13, 11:44 AM posted to rec.aviation.soaring
Max Kellermann[_2_]
On Sunday, July 14, 2013 8:08:50 PM UTC+2, jfitch wrote:
Got a question: the Butterfly wind vector and the XCSoar wind vector (derived from Butterfly information) seem to disagree by 180 degrees. That is they point toward each other. XCSoar seems to believe it too, based on glide calculations. I am using the LX format output on the Butterfly. I am assuming the arrow on each is intended to point the direction the wind it blowing towards, I.e., a vector. From observation, the Butterfly appears to be correct, XCSoar 180 off. Has anyone seen this?
This sounds very much like the Butterfly firmware bug that was reported to the XCSoar bug tracker 4 months ago:
http://bugs.xcsoar.org/ticket/2660
Old July 15th 13, 04:45 PM posted to rec.aviation.soaring
jfitch
I will get to the bottom of this. Please tell me, what is the assumption of XCSoar?
In particular, a CAI 302 !w sentence that looks like this:
!w,180,30,5,,,,,,,,,,*hh
would be interpreted how? Wind blowing from north towards the south, or south towards the north?
(my interpretation of the description "vector wind direction in degrees" indicates from north to south)
In an LX mode, an $LXWP0 sentence that looks like this:
$LXWP0,,,,,,,,,,180,3*hh
(description is less clear, "windcourse" would seem to mean same thing as Cambridge)
How does one get access to the XCSoar forum and bug reporting scheme? I registered over the weekend, but my registration is being held I guess.
Old July 15th 13, 04:51 PM posted to rec.aviation.soaring
Dan Marotta
I've been using XCSoar on an Android with a CAI-302 for almost 3 years now
and the wind calculation/display works perfectly.
If you tecchies would look outside once in a while instead of at your
whiz-bang panels, you could compare the wind velocity arrow to the cloud
shadows. Oh, wait! That would be too much like pilotage.
"jfitch" wrote in message
this?
XCSoar?
Cambridge)
Old July 15th 13, 06:33 PM posted to rec.aviation.soaring
jfitch
If you are flying in the flatlands where the clouds are 2000 AGL and likely to be blowing the same way as the air you are flying in, that works great. Otherwise, not so much.....
For example, final glide Saturday, 77 miles Mt. Patterson to Truckee out of 17,500. Cloud drift not discernible from altitude (or forming ahead as fast as drift), wind lines on Topaz Lake indicate calm, wind lines on Lake Tahoe indicate SSW about 10, AWOS at Truckee reporting W at 7, Butterfly showing 25 knots south. Butterfly says tailwind (and it is correct, too), XCSoar says headwind. Drop through about 12,000 ft., wind switches to 7 from the west. Have fun with your pilotage on that one.
Old July 16th 13, 03:39 AM posted to rec.aviation.soaring
Dan Marotta
Guess I've been flying long enough and without any high tech aids that it
just works for me. And, for the record, at Moriarty we routinely fly at
altitudes up to 18,000 MSL with surface altitudes from about 5,000 up to
around 13,000 MSL.
Personally, I get nervous below about 12,000 MSL unless I'm within gliding
distance of a landable field and, for that reason, my flights aren't nearly
as long as they could be.
Old July 15th 13, 05:03 PM posted to rec.aviation.soaring
to shed some light in this:
CAI: our fault, this was a bug that has been resolved a while ago.
LX: sorry guys, there is no spec on the LXWP wind direction (at least nobody knows of a specification). Both directions are commonly used depending on software you use. Rumors say that even LX devices exist that send data differently (is this true? i don't know). iGlide e.g. features a switch for that.
We will sure use the most common "interpretation" but the question is which one is the most common?
Where are you Butterfly vario? [email protected] Soaring 17 May 25th 14 05:49 AM
Butterfly Vario IGC Richard[_9_] Soaring 3 April 3rd 13 03:24 PM
LXNav V7 vs Butterfly vario? Chris Davison[_2_] Soaring 32 January 8th 13 09:37 AM
Butterfly vario info [email protected] Soaring 1 August 7th 12 10:08 PM
New Butterfly Vario Paul Remde Soaring 238 February 20th 12 04:05 AM
