On Tuesday, October 16, 2018 at 2:36:58 PM UTC-5, Craig Funston wrote:
Hi Dan, I was asking about the LS1 powered Pawnee. That's a modern engine designed to run on unleaded fuel with or without ethanol. I may have missed other parts of the discussion related to alternate fuels and certified aircraft engines. If not it would be nice to have discussions about the use of mogas in STC'd engines in another thread. Thanks, Craig Craig just wants the LS1 powered Pawnee so he can run the airconditioner to keep cool while towing. Don't blame you one bit! Steve Leonard |
I was flabbergasted when I saw the Corvette powered Pawnee at Narromine, and they didn't have air conditioning!
To sorta answer this, there is an ongoing push by AOPA and other groups along with the FAA (in the US) for a suitable unleaded fuel for use in the older "leaded fuel" engines.
I know we added a supplement to our low lead fuel for our towplanes. Don't remember the name of it. As to using auto derived engines for aircraft duty, sheesh, other than endurance racing (likely max runtime until rebuild, maybe 25hrs?), auto engines were not designed to run near full power for about 2000hrs before rebuild. While most piston aircraft engine are rather archaic compared to modern auto engines, they are rather dirt simple and last for a long time at high power loads. Yes, a better ignition system can help, although try getting that certified. Yes, in the US, and other countries, there is a push to find a suitable unleaded fuel. Aviation is still a small niche market (a bit larger than sailplanes, but still small for Shell, BP, Exxon, etc.), so what do they care about losing us due to environmental concerns? There have been discussions on Subaru forums about peeps wanting 300hp+ from a 2.5L NA Subaru engine for aero use. Yes, can be done, but at what cost? Most is in the experimental arena. As to going LPG, it usually is a big drop in power due to the lower power density of the fuel compared to gasoline, leaded or unleaded. Really hard to beat gasoline for now. Anywhere close is big money to get there. Hey, I am all for innovation, yes, we need to move from leaded fuel, but there are tradeoffs. Just ask the peeps that get ethanol blends for cars based on season. There is a MPG drop because of it. The little performance gain due to ethanol cooling is more than offset (thus far) by the lower power density of the fuel. This is more common in northern bits of the US, especially in metro areas (I am in the NY metro area). I log my fuel mileage, I can tell when fuel stations go from summer blend to winter blend. It averages 15% drop in mileage. |
On Tue, 16 Oct 2018 13:13:58 -0700, Charlie M. (UH & 002 owner/pilot)
wrote: To sorta answer this, there is an ongoing push by AOPA and other groups along with the FAA (in the US) for a suitable unleaded fuel for use in the older "leaded fuel" engines. I know we added a supplement to our low lead fuel for our towplanes. Don't remember the name of it. Slightly off topic, but how do you guys like this engine conversion? https://www.youtube.com/watch?v=loy2n8s_l00 The airframe is interesting: it was developed in California as a low-cost counter-insurgency aircraft, but never caught on. The design was bought by a NZ outfit and redeveloped as an agricultural plane in, I think, the early '60s. It originally had 250hp, but was rapidly upgraded to a 400hp Continental flat 6. Now they either have a 750 shp turbine or, line this one a big block truck V8. I don't know if its burning petrol or diesel. You see one or two 750hp turbine derivatives (the PAC750 bush plane)over here in the hands of jump clubs. They like them because the carry a lot of jumpers at a time and can manage 2500 fpm descent rates, so the turn- round time is good. Back on topic: I've not heard of them being used as tow planes, but I reckon they'd be a match for the big turbine Zlins at that game. Anyway, enjoy the video and its V8 sound track ! -- Martin | martin at Gregorie | gregorie dot org |
On Tuesday, October 16, 2018 at 4:20:17 PM UTC-7, Martin Gregorie wrote:
On Tue, 16 Oct 2018 13:13:58 -0700, Charlie M. (UH & 002 owner/pilot) wrote: To sorta answer this, there is an ongoing push by AOPA and other groups along with the FAA (in the US) for a suitable unleaded fuel for use in the older "leaded fuel" engines. I know we added a supplement to our low lead fuel for our towplanes. Don't remember the name of it. Slightly off topic, but how do you guys like this engine conversion? https://www.youtube.com/watch?v=loy2n8s_l00 The airframe is interesting: it was developed in California as a low-cost counter-insurgency aircraft, but never caught on. The design was bought by a NZ outfit and redeveloped as an agricultural plane in, I think, the early '60s. It originally had 250hp, but was rapidly upgraded to a 400hp Continental flat 6. Now they either have a 750 shp turbine or, line this one a big block truck V8. I don't know if its burning petrol or diesel. You see one or two 750hp turbine derivatives (the PAC750 bush plane)over here in the hands of jump clubs. They like them because the carry a lot of jumpers at a time and can manage 2500 fpm descent rates, so the turn- round time is good. Back on topic: I've not heard of them being used as tow planes, but I reckon they'd be a match for the big turbine Zlins at that game. Anyway, enjoy the video and its V8 sound track ! -- Martin | martin at Gregorie | gregorie dot org The E-Tug Pawnee VH-CUR with (backwards facing) LS1 V8 was great, but they had so many teething pains programming the chip that it didn't stick around at Keepit. Believe the E-Tug group have it all worked out now. When I saw it, the E-Tug used a ground adjustable 4-blade prop on a PSRU made in Washington. Climbed way too fast at first, got to 2000' before the end of the runway which is a concern at a competition. During the period when the throttle would not go back to idle, it was shut down and landed dead stick with no shock cooling issues - but the water pump wasn't turning then either. Believe there are newer LS- series V8s that are better. Just found some photos from 2007. https://www.dropbox.com/sh/0gh8y9b7p...ykXOTBjEa?dl=0 Jim |
On Tue, 16 Oct 2018 13:13:58 -0700, Charlie M. (UH & 002 owner/pilot) wrote: To sorta answer this, there is an ongoing push by AOPA and other groups along with the FAA (in the US) for a suitable unleaded fuel for use in the older "leaded fuel" engines. I know we added a supplement to our low lead fuel for our towplanes. Don't remember the name of it. Slightly off topic, but how do you guys like this engine conversion? https://www.youtube.com/watch?v=loy2n8s_l00 The airframe is interesting: it was developed in California as a low-cost counter-insurgency aircraft, but never caught on. The design was bought by a NZ outfit and redeveloped as an agricultural plane in, I think, the early '60s. It originally had 250hp, but was rapidly upgraded to a 400hp Continental flat 6. Now they either have a 750 shp turbine or, line this one a big block truck V8. I don't know if its burning petrol or diesel. You see one or two 750hp turbine derivatives (the PAC750 bush plane)over here in the hands of jump clubs. They like them because the carry a lot of jumpers at a time and can manage 2500 fpm descent rates, so the turn- round time is good. Back on topic: I've not heard of them being used as tow planes, but I reckon they'd be a match for the big turbine Zlins at that game. Anyway, enjoy the video and its V8 sound track ! Yeah, that's video's been in my bookmarks for a few years. It's hard to find newer footage and in decent quality :-( Here's a newer model in 720p \o/ in a a two week old upload. https://www.youtube.com/watch?v=YOTwJ1ASz1c Oh, here's a two year old 1080p video of a classic 400 HP piston one. Looks like it's made by a model flyer who gets some stick for noise lol https://www.youtube.com/watch?v=XSGYL3j5EXo |
Why are the wings bent?Â* Was the shop where it was built too small to
lay the wing flat? On 10/16/2018 5:20 PM, Martin Gregorie wrote: On Tue, 16 Oct 2018 13:13:58 -0700, Charlie M. (UH & 002 owner/pilot) wrote: To sorta answer this, there is an ongoing push by AOPA and other groups along with the FAA (in the US) for a suitable unleaded fuel for use in the older "leaded fuel" engines. I know we added a supplement to our low lead fuel for our towplanes. Don't remember the name of it. Slightly off topic, but how do you guys like this engine conversion? https://www.youtube.com/watch?v=loy2n8s_l00 The airframe is interesting: it was developed in California as a low-cost counter-insurgency aircraft, but never caught on. The design was bought by a NZ outfit and redeveloped as an agricultural plane in, I think, the early '60s. It originally had 250hp, but was rapidly upgraded to a 400hp Continental flat 6. Now they either have a 750 shp turbine or, line this one a big block truck V8. I don't know if its burning petrol or diesel. You see one or two 750hp turbine derivatives (the PAC750 bush plane)over here in the hands of jump clubs. They like them because the carry a lot of jumpers at a time and can manage 2500 fpm descent rates, so the turn- round time is good. Back on topic: I've not heard of them being used as tow planes, but I reckon they'd be a match for the big turbine Zlins at that game. Anyway, enjoy the video and its V8 sound track ! -- Dan, 5J |
On Tuesday, October 16, 2018 at 3:14:01 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote:
To sorta answer this, there is an ongoing push by AOPA and other groups along with the FAA (in the US) for a suitable unleaded fuel for use in the older "leaded fuel" engines. I know we added a supplement to our low lead fuel for our towplanes. Don't remember the name of it. As to using auto derived engines for aircraft duty, sheesh, other than endurance racing (likely max runtime until rebuild, maybe 25hrs?), auto engines were not designed to run near full power for about 2000hrs before rebuild. While most piston aircraft engine are rather archaic compared to modern auto engines, they are rather dirt simple and last for a long time at high power loads. Yes, a better ignition system can help, although try getting that certified. Yes, in the US, and other countries, there is a push to find a suitable unleaded fuel. Aviation is still a small niche market (a bit larger than sailplanes, but still small for Shell, BP, Exxon, etc.), so what do they care about losing us due to environmental concerns? There have been discussions on Subaru forums about peeps wanting 300hp+ from a 2.5L NA Subaru engine for aero use. Yes, can be done, but at what cost? Most is in the experimental arena. As to going LPG, it usually is a big drop in power due to the lower power density of the fuel compared to gasoline, leaded or unleaded. Really hard to beat gasoline for now. Anywhere close is big money to get there. Hey, I am all for innovation, yes, we need to move from leaded fuel, but there are tradeoffs. Just ask the peeps that get ethanol blends for cars based on season. There is a MPG drop because of it. The little performance gain due to ethanol cooling is more than offset (thus far) by the lower power density of the fuel. This is more common in northern bits of the US, especially in metro areas (I am in the NY metro area). I log my fuel mileage, I can tell when fuel stations go from summer blend to winter blend. It averages 15% drop in mileage. Wrong again, Charlie. In the era of smallish 50-100HP auto engines in Germany in the 70's we used to flog them for many hours at full throttle on the Autobahn. They were made for this abuse and lasted just as long as those in a taxi. Herb |
Wrong?
Answer this, did you/others run small engines for close to 2000hrs at full throttle with no rebuilds? Frankly, not likely. While most IC aircraft engines are archaic, they spend most time at close to full power for close to 2000 hours. Herb, while I know you (and you know me, but maybe not remember me), I have to say most automotive engines trying to do what a "lump of an archaic engine" is normally used in US GA gas piston engines, Rough guess........would you run a car engine at full power for 2000hrs? Quick numbers, 45MPH for 2000 hours, say about 90,000 miles. Me, no Frikkin way. You, I have no clue, go for it, not my wallet. Herb, go rush against other issues, I think you lose on this one.......OK? |
Back in the early 2000's Parowan had a 600 HP BiPlane Ag wagon. I took a few tows in my 1958 KA6CR with that thing. Wild man JC Hutchcorne would get me to Pattern altitude before the first taxiway and often at 2000' by the end of the airstrip with a little wind. Probably burned fuel like crazy but the time under full power was very short. It seemed the tow angle was about 30 degrees, up.
Pulse Oximeters are getting cheaper! | Uncle Fuzzy | Soaring | 3 | June 13th 09 11:30 PM |
Tows at Ely | [email protected] | Soaring | 1 | April 22nd 09 12:45 PM |
Aerotrekking: Why isn't it cheaper? | Larry Dighera | Piloting | 4 | January 21st 07 04:02 PM |
A cheaper way to fly? | Ronnie | Owning | 7 | June 5th 06 12:54 AM |
Flying just got cheaper!! | [email protected] | Piloting | 16 | April 28th 06 06:59 PM |
