Sport Aviation (EAA Magazine), April issue, pages 110-112.
The article shows a system of metal rod-stakes and the 3-part chain with the repair link in the middle. The article goes into some detail on how to make a 3-part chain with a repair link (pretty trivial to figure that out) but says absolutely nothing about how the hex head (nut?) and locking nut get onto the rod. Now, my suspicion is that the top inch or so of the rod is threaded, a nut run down to the bottom of the thread, a lockwasher, then another nut. That's my SUSPICION. The article is silent on how this is done. Anybody wanna confirm my suspicions. If so, tell me how the guy, by his own admission with a minimal shop, can thread a 5/16 rod. That's a pretty hefty (and rather unusual) die/thread size. ¼-20 is pretty common, but I'm not a good enough machinist to say whether or not 5/16 is a garden variety tool. It is also true that if you pound a lot on that hex nut at the top (if that is what it is) there is no chance in hell that you will ever be able to separate the nut from the rod without a torch. I mean, I think it is a great idea, and I'd like nothing more than to get rid of those stupid corkscrews I've been using for thirty years, but I'd like some of your comments on how we might make it better. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote: but says absolutely nothing about how the hex head (nut?) and locking nut get onto the rod. It mentions in one sentence near the end (last column) that he threaded it, and warns to get the bolts tight before you start whacking them with a hammer and ruining the threads. I was looking at those plans but figuring I'd just weld the head on. It is also true that if you pound a lot on that hex nut at the top (if that is what it is) there is no chance in hell that you will ever be able to separate the nut from the rod without a torch. I don't think you're ever supposed to get it off. Why would you? It looks like it's only there to hold on the washer, which is only there to give you something to pry it out by. -- Ben Jackson http://www.ben.com/ |
The "corkscrew" type of tiedown appear to be the most worthless type of
tiedowns. I use the tiedown set from Sporty's pilot shop. It comes with 3 tiedown rods. They have an auger at the lower end that is about 3 or 4 inches in diameter. It is a miniature version of what is commonly used as anchors for guy wires in tower construction. I keep the box in the baggage compartment at all times. I also have a piece of old ground rod about 12 to 14 inches long (so it also fits into the box). It is a steel ground rod coated with copper. I use this to twist the tiedowns into the ground. Works good at Oshkosh, where the ground is usually pretty hard with a rock or two as well. Scott, N0EDV http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die Jim Weir wrote: (Ben Jackson) shared these priceless pearls of wisdom: - -It mentions in one sentence near the end (last column) that he threaded -it, and warns to get the bolts tight before you start whacking them with -a hammer and ruining the threads. Got it. Completely missed that sentence. Am I reading that right? That he actually EXPECTS the exposed rod threads to peen over against the top nut? I sort of would like to be able to disassemble it because I'm sure that the flatwasher (or is that a lockwasher?) is going to bend and break after a couple of dozen uses. Or, I could simply hacksaw the threaded part off and rethread it. I doubt 18" is going to hold much tighter than 17". Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
On Wed, 21 Apr 2004 10:44:21 +0100, Scott
wrote: The "corkscrew" type of tiedown appear to be the most worthless type of tiedowns. I use the tiedown set from Sporty's pilot shop. It comes Actually the "corkscrew" tie downs made from spring steel work very well. They came from Sporty's as well. I have three and have used a three foot piece of pipe to get them in and out (Thanks Cy) They held is some pretty stong winds. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com with 3 tiedown rods. They have an auger at the lower end that is about 3 or 4 inches in diameter. It is a miniature version of what is commonly used as anchors for guy wires in tower construction. I keep the box in the baggage compartment at all times. I also have a piece of old ground rod about 12 to 14 inches long (so it also fits into the box). It is a steel ground rod coated with copper. I use this to twist the tiedowns into the ground. Works good at Oshkosh, where the ground is usually pretty hard with a rock or two as well. Scott, N0EDV http://corbenflyer.tripod.com/ Building RV-4 Gotta Fly or Gonna Die Jim Weir wrote: (Ben Jackson) shared these priceless pearls of wisdom: - -It mentions in one sentence near the end (last column) that he threaded -it, and warns to get the bolts tight before you start whacking them with -a hammer and ruining the threads. Got it. Completely missed that sentence. Am I reading that right? That he actually EXPECTS the exposed rod threads to peen over against the top nut? I sort of would like to be able to disassemble it because I'm sure that the flatwasher (or is that a lockwasher?) is going to bend and break after a couple of dozen uses. Or, I could simply hacksaw the threaded part off and rethread it. I doubt 18" is going to hold much tighter than 17". Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
"Roger Halstead" wrote comes Actually the "corkscrew" tie downs made from spring steel work very well. They came from Sporty's as well. I have three and have used a three foot piece of pipe to get them in and out (Thanks Cy) They held is some pretty stong winds. Roger Halstead Right. Just don't think that all corkscrews are created equal. The hardware store, or dog steaks, "will" twist off at OSH. They have to be spring steel. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.659 / Virus Database: 423 - Release Date: 4/19/2004 |
I thought it was brilliant. I am going to build some for my 172. So
simple, really. Ross Jim Weir wrote: Sport Aviation (EAA Magazine), April issue, pages 110-112. The article shows a system of metal rod-stakes and the 3-part chain with the repair link in the middle. The article goes into some detail on how to make a 3-part chain with a repair link (pretty trivial to figure that out) but says absolutely nothing about how the hex head (nut?) and locking nut get onto the rod. Now, my suspicion is that the top inch or so of the rod is threaded, a nut run down to the bottom of the thread, a lockwasher, then another nut. That's my SUSPICION. The article is silent on how this is done. Anybody wanna confirm my suspicions. If so, tell me how the guy, by his own admission with a minimal shop, can thread a 5/16 rod. That's a pretty hefty (and rather unusual) die/thread size. ¼-20 is pretty common, but I'm not a good enough machinist to say whether or not 5/16 is a garden variety tool. It is also true that if you pound a lot on that hex nut at the top (if that is what it is) there is no chance in hell that you will ever be able to separate the nut from the rod without a torch. I mean, I think it is a great idea, and I'd like nothing more than to get rid of those stupid corkscrews I've been using for thirty years, but I'd like some of your comments on how we might make it better. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
I used 7/16" rod, drilled out 1/2" nuts(to 7/16") & welded the h**l out of 'em--
actually got some 7/16" Spring steel from a spring mfg. co--nearly impossible to bend!! for a Stinson 108. Jim Weir wrote: Sport Aviation (EAA Magazine), April issue, pages 110-112. The article shows a system of metal rod-stakes and the 3-part chain with the repair link in the middle. The article goes into some detail on how to make a 3-part chain with a repair link (pretty trivial to figure that out) but says absolutely nothing about how the hex head (nut?) and locking nut get onto the rod. Now, my suspicion is that the top inch or so of the rod is threaded, a nut run down to the bottom of the thread, a lockwasher, then another nut. That's my SUSPICION. The article is silent on how this is done. Anybody wanna confirm my suspicions. If so, tell me how the guy, by his own admission with a minimal shop, can thread a 5/16 rod. That's a pretty hefty (and rather unusual) die/thread size. ¼-20 is pretty common, but I'm not a good enough machinist to say whether or not 5/16 is a garden variety tool. It is also true that if you pound a lot on that hex nut at the top (if that is what it is) there is no chance in hell that you will ever be able to separate the nut from the rod without a torch. I mean, I think it is a great idea, and I'd like nothing more than to get rid of those stupid corkscrews I've been using for thirty years, but I'd like some of your comments on how we might make it better. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
At OSH last year, I used 3/4" iron water pipe. I bought 4' sections
(threaded at each end) and sawed them in half at an angle (to make ground penetration easier). Screwed a "T" connector on the end (for the rope), and that was it. You need a hatchet or small ax to put it in (carried anyway as part of my survival kit), but, when pounded in at an angle, they do not come out. I probably spent a total of $15 on everything. A bit heavy, but I don't use them much, so that's not a big problem for me. You could probably use a smaller diameter, but I tend to over-engineer things. (This was for a C172.) jerry Wass wrote: I used 7/16" rod, drilled out 1/2" nuts(to 7/16") & welded the h**l out of 'em-- actually got some 7/16" Spring steel from a spring mfg. co--nearly impossible to bend!! for a Stinson 108. Jim Weir wrote: Sport Aviation (EAA Magazine), April issue, pages 110-112. The article shows a system of metal rod-stakes and the 3-part chain with the repair link in the middle. The article goes into some detail on how to make a 3-part chain with a repair link (pretty trivial to figure that out) but says absolutely nothing about how the hex head (nut?) and locking nut get onto the rod. Now, my suspicion is that the top inch or so of the rod is threaded, a nut run down to the bottom of the thread, a lockwasher, then another nut. That's my SUSPICION. The article is silent on how this is done. Anybody wanna confirm my suspicions. If so, tell me how the guy, by his own admission with a minimal shop, can thread a 5/16 rod. That's a pretty hefty (and rather unusual) die/thread size. ¼-20 is pretty common, but I'm not a good enough machinist to say whether or not 5/16 is a garden variety tool. It is also true that if you pound a lot on that hex nut at the top (if that is what it is) there is no chance in hell that you will ever be able to separate the nut from the rod without a torch. I mean, I think it is a great idea, and I'd like nothing more than to get rid of those stupid corkscrews I've been using for thirty years, but I'd like some of your comments on how we might make it better. Thoughts? Jim Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com -- Remove "2PLANES" to reply. |
| Thread Tools | |
| Display Modes | |
| Pat Tillman got what he deserved! (good article) | Stephen Harding | Military Aviation | 6 | May 5th 04 02:45 AM |
| Tiedown Stakes (Article in SportAv.) | Jim Weir | Home Built | 34 | April 24th 04 02:21 AM |
| Article: GPS Vehicle Tracking System Issues for the Buyer | Johann Blake | Military Aviation | 0 | January 16th 04 12:26 PM |
| Re; What do you think? | Kelsibutt | Naval Aviation | 0 | September 29th 03 07:55 AM |
