"Magnus" wrote in message
... [...] 1. Why would they use VOR radials for this on a VFR chart, when a VOR isn't even required for VFR flight? Someone else answered that. You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR. 2. The C airspace set up for Jacksonville international doesn't even have a VOR. Is there a source where I can get more information on the legend that the sectionals have? I'm still trying to figure out why it matters. At an airport without a VOR, obviously they cannot be radials from the VOR. At an airport with a VOR, the difference between a radial and a bearing from the airport is, for the purposes of determining which frequency to use for ATC, inconsequential. If you are so close to the radial/bearing that it makes a difference, the right frequency to use is the one for the sector you're about the fly into, regardless of which side of which boundary you happen to be on. The only boundary case I can see even coming close to mattering is if you happen to be flying inbound or outbound right smack on the boundary itself. My guess is that in that case, ATC doesn't care which sector you contact. If they do, it is easy enough for them to send you over to the correct one, if you happen to choose the wrong one. If I had to guess, I'd guess it's bearing from the airport, for the reasons pointed out already (that defining it as VOR radials would be meaningless at an airport without a VOR). But in reality, the sectors can be chopped up differently from what's on the chart anyway, due to those pesky letters of agreement. Use the chart as a guideline as best you can, and if you get it wrong, no big deal. ATC will straighten things out. Pete |
![]() "Peter Duniho" wrote in message ... Someone else answered that. You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR. No navigation equipment is required for VFR entry of Class B or C airspace. How does one know where a VOR radial is without using any navigation equipment? |
news ![]() No navigation equipment is required for VFR entry of Class B or C airspace. So? What's that got to do with this thead? How does one know where a VOR radial is without using any navigation equipment? Look at your chart. When you can see out the window, this is a much more reliable way of identifying a VOR radial than using the actual radio (which is permitted to have as much as 6 degrees of error anyway). Pete |
![]() "Peter Duniho" wrote in message ... So? What's that got to do with this thead? It was a response to the statement, "You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR." You don't see the connection? Look at your chart. When you can see out the window, this is a much more reliable way of identifying a VOR radial than using the actual radio (which is permitted to have as much as 6 degrees of error anyway). Please explain how it's done. |
et... It was a response to the statement, "You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR." You don't see the connection? No, I don't. Please explain how it's done. For VORs with a printed compass rose, it's trivial. The compass rose will be oriented to match the radials, and you simply plot the radial based on that. For VORs without a printed compass rose, just correct magnetic heading with the deviation for the VOR, and plot the radial based on that. Either way, you get a line that is drawn on your chart. You use your eyeballs to visually identify landmarks on the ground that show you where the line is. Honestly, it makes me wonder how you ever became a pilot, given that you can't figure out basic stuff like this. You must find it difficult just to navigate your way out of a paper bag. Pete |
I don't have an operational problem with using the chart and I know
that approach control won't go crazy if I somehow manage to use the wrong frequency. My issue is being told by a designated examiner something that a: doesn't make sense and b: she can't back up with a source It's not the radials that's the problem, it's the selected starting point from where the bearings in the legend should extend. Claiming that the bearings should extend from anything other than the primary airport for the airspace seems crazy to me. Apart from the fact that some airports don't have VORs, even if it does, your not flying to a VOR, you're flying to the airport and the airport and VOR don't necessarily have to be co-located so to me, the reference point naturally should be the airport and not any nav-aid that happens to be in the area. But like I said, I'd like to find a proper source where I can read about these charts. On 2004-04-24 12:33:25 -0400, "Steven P. McNicoll" said: "Peter Duniho" wrote in message ... Someone else answered that. You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR. No navigation equipment is required for VFR entry of Class B or C airspace. How does one know where a VOR radial is without using any navigation equipment? |
![]() "Magnus" wrote in message ... I don't have an operational problem with using the chart and I know that approach control won't go crazy if I somehow manage to use the wrong frequency. My issue is being told by a designated examiner something that a: doesn't make sense and b: she can't back up with a source Indicators that she's quite probably mistaken. |
Well then. there you have it..
A DE gave you bad information ![]() (s)he is human. It happens. Old Wives tales get passed on and bad information perpetuates itself. SHould it happen? No. Does it happen? Yes. What can you do? If you REALLY want to, refer it to the FSDO and they can point it out to the examiner. You didnt (improperly) receive a notice of disapproval over it did you? You have your ticket so go out there and use it, and chalk this up to experience. Dave Magnus wrote: I don't have an operational problem with using the chart and I know that approach control won't go crazy if I somehow manage to use the wrong frequency. My issue is being told by a designated examiner something that a: doesn't make sense and b: she can't back up with a source It's not the radials that's the problem, it's the selected starting point from where the bearings in the legend should extend. Claiming that the bearings should extend from anything other than the primary airport for the airspace seems crazy to me. Apart from the fact that some airports don't have VORs, even if it does, your not flying to a VOR, you're flying to the airport and the airport and VOR don't necessarily have to be co-located so to me, the reference point naturally should be the airport and not any nav-aid that happens to be in the area. But like I said, I'd like to find a proper source where I can read about these charts. On 2004-04-24 12:33:25 -0400, "Steven P. McNicoll" said: "Peter Duniho" wrote in message ... Someone else answered that. You don't need a VOR receiver to be able to know where a VOR radial is, when flying VFR. No navigation equipment is required for VFR entry of Class B or C airspace. How does one know where a VOR radial is without using any navigation equipment? |
![]() How does one know where a VOR radial is without using any navigation equipment? Look out the window. The radials are painted on the ground. every five degrees. Jose -- (for Email, make the obvious changes in my address) |
Florida Mil and NASA Comms Log - Tues, 18 May 2004 | AllanStern | Military Aviation | 4 | July 10th 04 02:00 AM |
Florida Military Comms Log - Thurs 15 Apr 2004 | AllanStern | Military Aviation | 1 | April 17th 04 08:38 PM |
Lost comms after radar vector | Mike Ciholas | Instrument Flight Rules | 119 | January 31st 04 11:39 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
