"Vaughn" writes:
We are not talking about a trainer, we are talking about an advanced, owner-flown, plane that will occasionally end up in an inadvertant spin. Any pilot that has enough experience to be flying one shout at least be able to recite the standard spin recovery procedure. Saying that the plane "will occasionally end up in an inadvertent spin" is a lot like calling it a plane that "will occasionally end up crumpled on the side of a mountain in clouds and freezing rain." You have to be trying really hard to spin one; it's hard to pin that on the plane. We can probably all recite the standard spin recovery procedure. I suspect that a significant number of us have never experienced a spin nor actually done the procedure, and should it happen in real life will probably be really confused and disoriented for long enough to die. When I moved to California I was able to recite the standard earthquake procedure, but when it happened the first time I had no idea what was happening to me until it was already over... |
Vaughn,
A capability for a normal spin recovery sounds like a much better idea. Define normal. -- Thomas Borchert (EDDH) |
![]() "Thomas Borchert" wrote in message ... Vaughn, A capability for a normal spin recovery sounds like a much better idea. Define normal. The "standard" spin recovery or one that is specified in the POH that does not guarantee a (however gentle) crash. Vaughn -- Thomas Borchert (EDDH) |
Cirrus could improve their situation vastly by adding speed breaks.
This could reduce the stalls, at least on approach. It would also reduce the severe shock cooling they are seeing due to their engine control system. I believe I have seen Cirrus claim the plane can be revovered from a spin normally, but experience to date has so far shown that may not be that easy. "C J Campbell" wrote in message ... "Doug Vetter" wrote in message et... The SR20's limit of 12000 hours is still too limiting, IMHO, but I can appreciate the FAA's conservatism regarding any new (indeed revolutionary) design. I was told by a Diamond rep that the Diamond aircraft do not have airframe life limits. I would consider them to be just as revolutionary as the Cirrus. However, I have not looked up the Diamond's type certificates to verify the rep's claims. However, I must disagree with the comment about the airplanes "falling out of the sky" -- we just touched on this in Jay's thread. This has NOTHING to do with the airplane. It has EVERYTHING to do with pilots with more money than skill flying them. Actually, it has EVERYTHING (sic) to do with the airplane, whether it is some design flaw that causes them to disintegrate or whether it is a design flaw that makes them too difficult to fly for the pilots that are buying them. In any event, I think the FAA will eventually order Cirrus to get to the bottom of it, no matter what the cause. The FAA nearly grounded Cirrus with the first rash of accidents. I doubt that their patience with Cirrus is unlimited. The pilot in Florida had 600 hours in type, was instrument rated, and was a founder of the Cirrus Pilots Association. That does not fit the description of "more money than skill." The Cirrus cannot recover from a spin or even an incipient spin. Pilots are supposed to deploy the chute if the Cirrus enters a spin. Fine, if you are 900' AGL or more. Probably more, if the chute takes longer to deploy when the airplane is in a spin. So a departure stall or approach stall in this airplane is going to be far more dangerous than in other aircraft. And let us be clear he stalls were a factor in a large percentage of the Cirrus accidents so far. Given that the most common GA accident is low level maneuvering: the slick design of the Cirrus, the inadequate flaps, the poor stall handling abilities, pilot unfamiliarity with the new equipment (which also keeps pilots' eyes inside the cockpit), poor maintenance and quality control, and the inability of the parachute to deploy at low altitude all seem to me to add up to a lot of trouble. |
![]() "Dude" wrote in message ... Cirrus could improve their situation vastly by adding speed breaks. This could reduce the stalls, at least on approach. It would also reduce the severe shock cooling they are seeing due to their engine control system. How would speed brakes help? Speed brakes do not reduce the speed at which a wing stalls. |
Before I get flamed, remember this is a seies of questions, not a
statement... In my 182 I slow the plane, assuming gear is already down, by reducing power and pitching up. On a laminar flow wing (does the Cirrus have a laminar flow wing?) I understand that the wing stall happens pretty abruptly - either you are flying or your not. If that is the case, it seems that speed brakes would aid in getting the speed under control without as much danger of being close to the stall speed and pitching up to control airspeed. All right, I'm done. Have at it... Michael "Newps" wrote in message ... "Dude" wrote in message ... Cirrus could improve their situation vastly by adding speed breaks. This could reduce the stalls, at least on approach. It would also reduce the severe shock cooling they are seeing due to their engine control system. How would speed brakes help? Speed brakes do not reduce the speed at which a wing stalls. |
"Michael 182" wrote in message
news:MkUic.32804$w96.2278982@attbi_s54... [...] If that is the case, it seems that speed brakes would aid in getting the speed under control without as much danger of being close to the stall speed and pitching up to control airspeed. I think I kind of get what you're trying to say about the pitch angle/control, even if it seems like a bit of a red herring to me. But it seems a little odd to me to talk about "getting the speed under control" (i.e. slowing down) and claiming that one method will be "without as much danger of being close to the stall speed" as some other method. Assuming you use either method to slow an equal amount, from the same initial airspeed, the resulting airspeed will be the same, and will be just as "close to the stall speed", assuming neither method changes the stall speed (which is the case when comparing speed brakes versus pitching up). Pete |
![]() "Peter Duniho" wrote in message ... "Michael 182" wrote in message news:MkUic.32804$w96.2278982@attbi_s54... [...] If that is the case, it seems that speed brakes would aid in getting the speed under control without as much danger of being close to the stall speed and pitching up to control airspeed. I think I kind of get what you're trying to say about the pitch angle/control, even if it seems like a bit of a red herring to me. But it seems a little odd to me to talk about "getting the speed under control" (i.e. slowing down) and claiming that one method will be "without as much danger of being close to the stall speed" as some other method. Hmmm - I agree - I meant that the use of speed brakes would allow slowing without using as much pitch - does that make sense? Michael |
I would think vortex generators would help reduce the stall speed without
causing to much drag and reducing its speed. Michael 182 wrote: Before I get flamed, remember this is a seies of questions, not a statement... In my 182 I slow the plane, assuming gear is already down, by reducing power and pitching up. On a laminar flow wing (does the Cirrus have a laminar flow wing?) I understand that the wing stall happens pretty abruptly - either you are flying or your not. If that is the case, it seems that speed brakes would aid in getting the speed under control without as much danger of being close to the stall speed and pitching up to control airspeed. All right, I'm done. Have at it... Michael "Newps" wrote in message ... "Dude" wrote in message ... Cirrus could improve their situation vastly by adding speed breaks. This could reduce the stalls, at least on approach. It would also reduce the severe shock cooling they are seeing due to their engine control system. How would speed brakes help? Speed brakes do not reduce the speed at which a wing stalls. |
I've got about 500 hours in both SR20s and SR22s, so I'll throw out
some real world experience (not that it's worth anything in a newsgroup, but here goes.) The folks claiming that they stall without warning and are then difficult to control have obviously never flown one. You get plenty of warning (as required in Part 23) by buffeting, mushy controls, and the stall warning. If you keep going, the inner part of the wing stalls first (it is at a higher angle of attack than the outer part; take a look at the wing cuffs.) When that happens you still have aileron control if you're sloppy and try to use it. It feels like a washboard road. If you are sufficiently uncoordinated you can drop a wing, and if you try hard enough you can spin one, but you have to be asleep at the yoke to do this. They are not particularly difficult to slow down because of the fixed gear. You can deploy half flaps at a relatively generous 120 KIAS. Much easier to deal with than the Baron I fly. I'm not sure where the "too small flaps" claim comes from; they seem to work just fine, and making them bigger would reduce the speed at which they can be deployed, and make the power-off descent angle with full flaps even more impressive than it is now. Handling is responsive and predictable. They're way fun to yank and bank. The side yoke does not require much force and comes naturally very quickly. The trim is a bit of a pain (it runs too fast) but you get used to it pretty quickly. The paranoia about spins and spin recovery seems overblown. The test pilots have spun them and recovered, and nowhere in the POH does it say that spins are "unrecoverable" (contrary to another posting here.) Until recently the POH suggested normal spin recovery technique, though this was removed in a recent revision, presumably as a CYA move. I have heard, though cannot confirm, that some kind of spin certification will be required for JAA certification, so hopefully that will put this issue to rest. Having said that, part 23 only requires recovery from a one turn spin, which isn't really a spin at all. The drama about the "death zone" below 900' is seriously overblown; I suspect that the majority of pilots have never had spin training, and even those that have are unlikely to recover from the usual base-to-final spin in *any* aircraft. The 4000-ish hour life limit on the SR22 is a certification artifact; Cirrus chose to use a very conservative formula based on the SR20 airframe life tests in order to speed the SR22 certification process, but will be extending the life based on testing. I think you'll find the *vast* majority of Cirrus owners are very happy with their purchases (with the exception of ArtP, who seems to have gotten a lemon.) I've never had a maintenance problem that cancelled (or ended) a flight, and the only failures I've had have been with OEM parts, and this is true of most owners. The only design characteristic that I think can cause handling problems for low-time transitioning pilots is the high wing loading, which requires higher takeoff and landing speeds (rotate at 70 KIAS, final approach at 70-75 in an SR20 or 75-80 in an SR22) and causes serious sink rates if you get too slow. You have to land them like heavy airplanes--hold the approach attitude all the way into the flare, and no 50 AGL roundouts like in 172s. A number of the landing accidents were due to this (IMHO), coupled with insufficient training (which I understand has been fixed, though it's been three years since I last had the factory training.) Early on the trainers were recommending coming in five knots faster than the POH numbers in order to accommodate sloppy 172 technique, which results in excessive float, and bouncing, and things go badly after that if you don't immediately go around. If you have the discipline to fly the numbers, they are pussycats to land, and have more than enough energy to flare and land smoothly even with the power at idle. As far as the accidents go, simply pointing at statistics and calling the plane a death trap and saying that they are "falling out of the sky" isn't supportable by the facts. Of the eight fatal accidents (not counting the flight test accident) five (and possibly a sixth, though there isn't much data on the crash in Spain) were CFIT. Hard to blame these on the plane per se. Ultimately it comes down to whether people do more stupid things in Cirrus aircraft than in other brands. Statistically it's too early to tell, and the time-in-type average is very low. Basically, you can cook the numbers to support your position, regardless. I think it's probably true that someone who is going to be stupid enough to scud run at night or in mountainous terrain is probably more likely to die in a Cirrus than a Cessna because of the speed. It may well be that pilots feel safer in a Cirrus than in a 25 year old 172 (I know I do, and it's arguably true, particularly IFR) and perhaps that leads the marginal ones to take bigger risks. But there is no shortage of pilots doing dumb things in all manner of aircraft, and dying on a regular basis. Time will tell. |
Advice and experts with 400 series Cessnas (414 and 421), purchase and training | [email protected] | Owning | 36 | January 9th 05 02:32 AM |
Air Shares Elite and Cirrus Sr22 | Teranews \(Daily\) | Owning | 4 | September 5th 04 05:28 PM |
Cirrus SR22 Purchase advice needed. | Dennis | Owning | 170 | May 19th 04 04:44 PM |
New Cirrus SR22 Lead Time | Lenny Sawyer | Owning | 4 | March 6th 04 09:22 AM |
Fractional Ownership - Cirrus SR22 | Rich Raine | Owning | 3 | December 24th 03 05:36 AM |
