"gatt" writes:
But what if you fly someplace and, say, the alternator fails while you're gone? You certainly don't fly back, Why not? If the return flight is a couple of hours, get the battery charged up, have someone handprop or use up some battery to crank it, take off, turn off all the electricals and fly it home. If you need to enter controlled airspace turn things back on briefly. |
"Tony Cox" wrote in message
ink.net... [...] It shouldn't really affect you in any case. If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. Just fly legally and it won't apply to you. The part about remaining with the airplane or paying $5/mile (up to the $1000 maximum...yikes!) certainly would. |
"Peter Duniho" wrote in message
... "Tony Cox" wrote in message ink.net... [...] It shouldn't really affect you in any case. If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. Just fly legally and it won't apply to you. The part about remaining with the airplane or paying $5/mile (up to the $1000 maximum...yikes!) certainly would. Nah. A good lawyer could get you off easy! The way that clause is written, you're supposed to remain with the plane for 3 days at the remote location even if what needs to be repaired is no worse than it was when you took off. And what does "remain" mean anyway? Sleep in the back seat? I wouldn't worry about it. It's just some pettifogger's way of trying to protect themselves after some renter ripped them off. |
ink.net... [...] you're supposed to remain with the plane for 3 days at the remote location even if what needs to be repaired is no worse than it was when you took off. Who said anything about "what needs to be repaired is no worse than it was when you took off"? It's a given that you would leave the plane at the FBO if it weren't airworthy there. The question is what happens when it becomes known to be unairworthy after arriving somewhere else. Pete |
... "Tony Cox" wrote in message ink.net... [...] you're supposed to remain with the plane for 3 days at the remote location even if what needs to be repaired is no worse than it was when you took off. Who said anything about "what needs to be repaired is no worse than it was when you took off"? I did, but only as an illustration as to how the clause could be interpreted. The question is what happens when it becomes known to be unairworthy after arriving somewhere else. Well, if it wasn't broken when you took off, the clause hasn't anything to say on the matter. Otherwise, who knows? The clause says nothing about 'airworthiness'. Don't take off when things 'need repair' and it won't be an issue. |
![]() "If the PIC determines that the plane needs repair before being flown, and the PIC has flown the plane away from its home location, the PIC must remain with the plane for three (3) days while the plane is being repaired. The PIC is responsible for all costs of his own lodging, food, travel expenses, etc. during this three day period. If the PIC elects to leave the plane during this three day repair period, you are responsible for the smaller of $5 per mile or $1000 for an FBO staff member to retreive the plane." I've never seen something like that before. I wouldn't fly there. It shouldn't really affect you in any case. If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. Just fly legally and it won't apply to you. "if you aren't doing anything wrong, you have nothing to be afraid of" Suppose you take off in a good airplane, land in Kalazazoo, and the vacuum system dies. Not your fault. You didn't take off (to Kalamazoo) in a plane that you knew needed repairs; in fact it didn't. But now you're there, and the lawyers eat you. Run, don't walk. Jose -- (for Email, make the obvious changes in my address) |
The lawyers would starve on this one!
This only applies if the pilot knew about the problem before taking off... "Teacherjh" wrote in message ... "If the PIC determines that the plane needs repair before being flown, and the PIC has flown the plane away from its home location, the PIC must remain with the plane for three (3) days while the plane is being repaired. The PIC is responsible for all costs of his own lodging, food, travel expenses, etc. during this three day period. If the PIC elects to leave the plane during this three day repair period, you are responsible for the smaller of $5 per mile or $1000 for an FBO staff member to retreive the plane." I've never seen something like that before. I wouldn't fly there. It shouldn't really affect you in any case. If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. Just fly legally and it won't apply to you. "if you aren't doing anything wrong, you have nothing to be afraid of" Suppose you take off in a good airplane, land in Kalazazoo, and the vacuum system dies. Not your fault. You didn't take off (to Kalamazoo) in a plane that you knew needed repairs; in fact it didn't. But now you're there, and the lawyers eat you. Run, don't walk. Jose -- (for Email, make the obvious changes in my address) |
Have you considered the possibility of something failing AFTER you've
departed? Stranger things have happened. Everyone is assuming that the pilot is departing in an unairworthy plane. Alternators can fail. Birds can strike the wing or windshield. Quit reading more into this than there is. Dave Bill Denton wrote: The lawyers would starve on this one! This only applies if the pilot knew about the problem before taking off... "Teacherjh" wrote in message ... "If the PIC determines that the plane needs repair before being flown, and the PIC has flown the plane away from its home location, the PIC must remain with the plane for three (3) days while the plane is being repaired. The PIC is responsible for all costs of his own lodging, food, travel expenses, etc. during this three day period. If the PIC elects to leave the plane during this three day repair period, you are responsible for the smaller of $5 per mile or $1000 for an FBO staff member to retreive the plane." I've never seen something like that before. I wouldn't fly there. It shouldn't really affect you in any case. If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. Just fly legally and it won't apply to you. "if you aren't doing anything wrong, you have nothing to be afraid of" Suppose you take off in a good airplane, land in Kalazazoo, and the vacuum system dies. Not your fault. You didn't take off (to Kalamazoo) in a plane that you knew needed repairs; in fact it didn't. But now you're there, and the lawyers eat you. Run, don't walk. Jose -- (for Email, make the obvious changes in my address) |
The town had one lawyer. He was starving. Another moved in and now they are both doing a brisk business. Jose -- (for Email, make the obvious changes in my address) |
Thanks to everyone for their interpretations. I think I'll just check out
some more FBO's .... I'm sure someone else has comparable rates without these types of restrictions. ![]() Now if I could only afford my own plane....... Robert "Teacherjh" wrote in message ... "If the PIC determines that the plane needs repair before being flown, and the PIC has flown the plane away from its home location, the PIC must remain with the plane for three (3) days while the plane is being repaired. The PIC is responsible for all costs of his own lodging, food, travel expenses, etc. during this three day period. If the PIC elects to leave the plane during this three day repair period, you are responsible for the smaller of $5 per mile or $1000 for an FBO staff member to retreive the plane." I've never seen something like that before. I wouldn't fly there. It shouldn't really affect you in any case. If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. Just fly legally and it won't apply to you. "if you aren't doing anything wrong, you have nothing to be afraid of" Suppose you take off in a good airplane, land in Kalazazoo, and the vacuum system dies. Not your fault. You didn't take off (to Kalamazoo) in a plane that you knew needed repairs; in fact it didn't. But now you're there, and the lawyers eat you. Run, don't walk. Jose -- (for Email, make the obvious changes in my address) |
Bush's Attempt to Usurp the Constitution | WalterM140 | Military Aviation | 20 | July 2nd 04 04:09 PM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Military Aviation | 1 | April 9th 04 11:25 PM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Naval Aviation | 0 | April 7th 04 07:31 PM |
CBS Newsflash: Rental trucks pose imminent and grave danger to national security | Ron Lee | Piloting | 4 | January 15th 04 03:07 PM |
