#11
In article , Richard Lamb wrote:
Spraying a urethane foam on the inside: This will stiffen the panel and improve the noise level inside the aircraft. It would require a fire rated foam such as "gator skin". Other are available. I'm leaning this way. Thanks to all, tom pettit Lean back the other way some, Tom. You are about to fall off of something here... Filling large cavities with foam may be great for boats, but don't do it to a metal airplane. The lightest mix you'll get will be at least 3 pounds per cubic foot, minimum. Richard Sorry I wasn't clearer on my intention. I'd only spray about an inch on the panels. Not much weight, and still get significant damping. tom |
ala TriMotor - corrugations
-- Dan D. .. wrote in message ... Howdy All, Thanks for your thoutful replies. They seem to fall into three main ideas: Thicker panels: yeah. This will work, but for exterior fuselage panels, it would be prohibitively heavy. I'll pass. Building in some kind of "upset": This will work. Breaks, as I described will make the panels stiffer. Another poster suggested rolling in ridges that would stiffen the panel. These would look kind of goofy, and have a small drag effect. I think I'll pass. Spraying a urethane foam on the inside: This will stiffen the panel and improve the noise level inside the aircraft. It would require a fire rated foam such as "gator skin". Other are available. I'm leaning this way. Thanks to all, tom pettit |
Blueskies wrote:
ala TriMotor - corrugations -- Dan D. Absolutely. MUCH thicker skins ![]() Rihcard |
wrote: In article , Richard Lamb wrote: Spraying a urethane foam on the inside: This will stiffen the panel and improve the noise level inside the aircraft. It would require a fire rated foam such as "gator skin". Other are available. I'm leaning this way. Thanks to all, tom pettit Lean back the other way some, Tom. You are about to fall off of something here... Filling large cavities with foam may be great for boats, but don't do it to a metal airplane. The lightest mix you'll get will be at least 3 pounds per cubic foot, minimum. Richard Sorry I wasn't clearer on my intention. I'd only spray about an inch on the panels. Not much weight, and still get significant damping. tom Balderdash, tom. I think you are blowing in my ear. First, just how do you expect to "spray on" a 1 inch thick layer of foam INSIDE a wing? I can't do it, and I can do anything (with Duct tape!). Second, a 100 square foot wing is 14,400 square inches. One inch thick is 14,400 CUBIC inches, or 8.3 cubic feet. Top and bottom skins give 28,800 cubic inches or 16.6 cuft. At the mythical 3 lb/ft^3, that's 50 pounds. Sorry dude, that boat don't float... Yeah it will. 8^) I was talking about flat panels on the fuselage. The Zenith CH701 I would like to build has about 60 square feet of fuselage area behind the cabin. At one inch, that amounts to 5 cubic feet. One website I visited that made fire retardant spray urethane foam says 1.75 pounds per cubic foot, so the weight of this addition would be less than nine pounds. By the way, I don't know you well enough to blow in your ear. Regards, tom |
In article , "Blueskies" wrote:
ala TriMotor - corrugations I kind of like the idea of corregations. Any ideas on how to accomplish them? thanks, tom |
![]() wrote in message ... snip of misunderstanding Sorry I wasn't clearer on my intention. I'd only spray about an inch on the panels. Not much weight, and still get significant damping. tom Balderdash, tom. I think you are blowing in my ear. First, just how do you expect to "spray on" a 1 inch thick layer of foam INSIDE a wing? I can't do it, and I can do anything (with Duct tape!). Second, a 100 square foot wing is 14,400 square inches. One inch thick is 14,400 CUBIC inches, or 8.3 cubic feet. Top and bottom skins give 28,800 cubic inches or 16.6 cuft. At the mythical 3 lb/ft^3, that's 50 pounds. Sorry dude, that boat don't float... Yeah it will. 8^) I was talking about flat panels on the fuselage. The Zenith CH701 I would like to build has about 60 square feet of fuselage area behind the cabin. At one inch, that amounts to 5 cubic feet. One website I visited that made fire retardant spray urethane foam says 1.75 pounds per cubic foot, so the weight of this addition would be less than nine pounds. If the panels are really flat, then why spray it on? Low density foam is available in sheets. I'll bet the consistency is better than you can get from a can. Bond it on before you rivet. It shouldn't have to go all the way to the edges to prevent the oilcanning. It looks like for the 9 lb weight penalty you could increase the thickness of just those panels by about .010 inches (.15 lbs/sq ft). That would make it less likely to oilcan and stronger. Does the foam really need to be continuous? Why not just bond some foam stiffeners to the inside of the panel every six inches or so? The HP-18 sailplane wing is made from 1/2" foam on four inch centers. That technique might be more anechoic than a smooth continuous foam surface, too. You could taper the stiffeners to be thicker in the center of the panel, and get more stiffness/unit weight that way. An interesting way to bond the stiffeners might be to use 3M VHB (Very High Bond) double stick tape. It's used to bond side panels on truck and trailer bodies. Fast and no goop. Tim Ward |
Ok, a different offering? Look around for some light weight sound deadening material. It's right about 1/8" thick and either has a self stick backing or can be stuck in place with probond. (That's the way my neighbor did his 601-HDS anyway). You really don't need to completely cover the area to reduce rattling. A wide strip across the panel can be as effective. Lastly, check that fire proof foam for "frangibility". (:^) And how well it doesn't stick to bare aluminum? You may find your fuselage is soon full of white fluff... Richard The stuff sticks amazingly well to almost anything. It is quite tough. I guess if it started flaking off, I could cut a hole in the back and start sky writing with the trail of white flakes. Probably the premade dampening material would be most practical. I have used them before. The better performing ones are almost as heavy as the foam, though. tom |
