Tow DROID
Old February 8th 14, 11:42 PM posted to rec.aviation.soaring
son_of_flubber
Default Tow DROID
On Saturday, February 8, 2014 11:50:52 AM UTC-5, Dan Marotta wrote:
The standard setup is to use a Schweizer hook which is rigidly mounted in
pitch and can swivel around the yaw axis.
Yeah but. Why does the tug pilot have to pull anything when a glider kites? The tug pilot should of course have the option to release at any time.
Here is the 1870 patent for something that look a lot like the Schweitzer tow hook. Click on the thumbnail for a drawing. http://rec.aviation.soaring/
The Tost hook still requires the tug pilot to pull a lever (though the automatic "back release" on the glider side is nice.)
Old February 9th 14, 12:02 AM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
That's a good question.
As a glider pilot, I don't want any part of an automatic release (back
release excepted).
As a tow pilot, I'd rather the glider be released automatically than have
the tug upset and, possibly, driven to the ground.
"son_of_flubber" wrote in message
time.
Old February 9th 14, 03:24 AM posted to rec.aviation.soaring
son_of_flubber
Default Tow DROID
http://www.google.ca/patents/US102067
Old February 9th 14, 04:35 AM posted to rec.aviation.soaring
Bill T
Default Tow DROID
I've seen heavy duty gate (barn door) hinges used with auto tow start to pull apart.
If you use one, keep up on the inspections during the day!
BillT
Old February 9th 14, 12:07 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Tow DROID
That doesn't look to be any more an automatically releasing hook than the
Schweitzer is.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 9th 14, 04:29 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
That patented release mechanism appears to be superior to the Schweizer hook
by having a slot for the clevis to be captured within. With the Schweizer
assembly, the ring can move forward (towards the release mechanism) and,
with the high upward force applied by a kiting glider, render the release
inoperative. Not so, apparently with the older design.
Old February 9th 14, 06:37 PM posted to rec.aviation.soaring
kirk.stant
Default Tow DROID
pitch and can swivel around the yaw axis. So, if the glider kites, it
exerts sufficient force on the release mechanism that the tow pilot may not
have the strength to pull the lever. It's also possible that, should the
glider get too wide, the axis of the release cable is too far off center to
operate the release. So... Stay in position on tow!
Dan, there is a 337 for an inverted mounting of the Schweizer hook on Pawnees - Turf soaring developed it many years ago. It simply mounts the fixed arm at the top, and the swinging arm at the bottom - so that when the glider kites, the rope tension is taken by the fixed arm and there isn't any additional pressure on the release gate (which is what makes the Schweizer hook so hard to release in an kiting situation).
Roy Couillete at Turf may still have access to the 337 documentation, if you are interested.
Old February 9th 14, 10:05 PM posted to rec.aviation.soaring
Default Tow DROID
On Saturday, February 8, 2014 9:31:13 AM UTC-5, son_of_flubber wrote:
Returning for a moment to the 19th century tow hook designs that are on most tugs. Why does the pilot need to pull the release if the glider kites? Why is the release for a deadly tow position not fully automatic? Is a simple purely mechanical, totally foolproof and 100% automatic release not possible? As the guy in the glider, I would be fine with a 100% automatic release. If I kite, release me immediately.
There was a design and prototype of a release like this created many years ago and published, I believe, in Soaring magazine. I know if no one that has adopted this which makes it fairly clear that this is not perceived as a huge problem.
Many of us have inverted our Schweizer hooks to help avoid the problem of high release force when the glider is high.
FWIW
UH
Old February 9th 14, 11:31 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
Thanks, Kirk, but the three tugs that I fly belong to Sundance Aviation in
Moriarty. I'll mention the 337 to the owner and see if he's interested.
"kirk.stant" wrote in message
not
to
are interested.
Aviation applications for the Droid phone Bob Owning 3 January 2nd 10 03:26 AM
