my GPS is on strike!
Old June 14th 04, 04:48 PM
Nathan Young
On Sun, 13 Jun 2004 16:48:25 -0400, Cub Driver
I am going quietly mad. I fired up my Garmin III Plus this afternoon
and plugged in the airport, and behold! The airport is to my south,
and the compass needle pointed north. Then I realized that if I turned
360 degrees, the display never changed: the needle always pointed to
the bottom of the compass rose, and north was always at the top.
Does the GIII have a 'sats tracked' page? My 295 does, and it will
tell you if you are in simulator mode, Searching for a fix, 2D or 3D
fix.
Does the GIII have a moving map display? Where does it show you
(relative to the airport)?
-Nathan
Old June 15th 04, 11:50 AM
Cub Driver
fix.
Yes, it was showing satellites. A bunch of them!
Yes again. It did locate me correctly, 5.9 nautical miles from the
airport.
I get a bit queasy recalling that I have been using the thang for
three years and understand it so little! The sensible thing would be
to take it out for a drive in the Accord, but the trees in New
Hampshire tend to block the sky.
I looked for a website with a decent tutorial but came up dry. In any
event, the Garmin III Plus apparently is no longer sold.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! weblog www.vivabush.org
Tankers and strike packages (Was: EA-18G vs ES-3) [email protected] Naval Aviation 0 December 9th 04 11:11 AM
Russia Threatens to Strike Terror Bases Dav1936531 Military Aviation 51 September 18th 04 12:52 AM
Carrier strike groups test new Fleet Response Plan Otis Willie Military Aviation 0 July 18th 04 10:25 PM
Hamas Leader Rantisi Killed by Israeli Strike on Car Dav1936531 Military Aviation 13 April 21st 04 07:04 PM
Joint Strike Fighter focus sparks concern Otis Willie Military Aviation 0 March 19th 04 09:19 PM
