#11
On Wed, 16 Jun 2004 00:56:11 GMT, EDR wrote:
In article urJzc.46043$0y.44191@attbi_s03, m pautz wrote: Pete, I understand that airplanes spend most of their time out of glide range of airports; so do many gliders. You mentioned that, "It's much more important that one be able to make a gliding power-off approach and landing to *somewhere*" That is my point exactly. My point is that the power pilots of today are not being taught a valuable safety feature, how to fly a pattern without power. I am not making a judgment call on what should or should not be done as a matter of course; that is up to you power guys. What I am saying is that it should be taught and regularly practiced. It is not "required" until the Commercial checkride. The standard that took effect last year is a 180 degree, power off abeam the approach end of the runway, landing. :-)) On my last bi-ennual check ride we did a bunch of instrument work and then the instructor said "as this is your airplane I'd like you to simulate an engine out in what ever manner you are most comfortable." I pulled it back to idle. He then said, "OK we've had a power failure, how about finding a place to land. We were over 4 miles...I think close to 5 miles west of the airport. Having just come out from under the hood I had a good idea of our location. I established best glide while "looking for a spot" which in this case was the airport. We were at 4000 as I recall. At any rate, at best glide we were *high* when we reached the airport. I actually flew the pattern (more or less) with a steep slipping U-turn to the end of the runway. We were down and stopped in about 900 feet. He commented that from our altitude he thought I'd never get it on that 3000 foot runway let alone stopped in the first 900 feet. I do this in a 3100# high performance retract and the flight schools, or instructors drill it into to the students in the trainers. My point is although not called that, the emergency procedures are exactly that... Power off landings to a particular spot and they are often far more than just doing the pattern. I see a lot of power off landings in the trainers at 3BS. Normally the ones with the wide patterns are the pilots who have been flying a while, who don't like stalls and haven't done one since the last bi-ennual flight review. They don't like anything other than something close to a standard rate turn and when landing add 10 MPH for safety, 5 for the kids, 10 for the wife and at least the full gust factor if not more. Oh, and they rarely fly with an instructor except for the dreaded bi-ennual flight review. Perhaps other areas are not doing so, but I see both power and non powered landings. Every few weeks I pull the power abeam the numbers on the way out just to keep in practice. However I would point out that a so called "normal, by-the-book landing" in mine is carrying quite a bit of power. No, that is not a shallow, dragging it in final, it's steep! Far steeper than a power off landing and quite a bit slower. It varies between 75 to 80 with a power off landing being at 90 MPH. That extra 10 to 15 MPH uses a *LOT* of runway. The real eye opener is to do a power off, "no flap" landing. You will use most of the 3000 foot runway even with heavy braking and the nose is so high you can only see the runway through the side windows. I have to admit though, you can barely even tell when the mains touch down. :-)) Of course the real ego deflator is landing in a gusty wind only to find 6 or 7 pilots standing by the gate holding up signs to grade the landing snicker Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Tue, 15 Jun 2004 15:25:55 GMT, m pautz
wrote: So, the question I have for the group is why are power planes taught to have these wide patterns with low angled turns? I have the same problem you do with the normal pattern, particularly the long haul on the 45, during which you can't possibly glide to the airport (usually after having flown over the airport!). Personally, I have gone back to power-off landings for just this reason. And I try, not always successfully, to come in "high, hot, and slipping like crazy" since I don't have the option of raising the flaps. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! weblog www.vivabush.org |
Gee .. that requirement was there back in the 70s. Did they
remove it at some point? "EDR" wrote in message ... In article urJzc.46043$0y.44191@attbi_s03, m pautz wrote: Pete, I understand that airplanes spend most of their time out of glide range of airports; so do many gliders. You mentioned that, "It's much more important that one be able to make a gliding power-off approach and landing to *somewhere*" That is my point exactly. My point is that the power pilots of today are not being taught a valuable safety feature, how to fly a pattern without power. I am not making a judgment call on what should or should not be done as a matter of course; that is up to you power guys. What I am saying is that it should be taught and regularly practiced. It is not "required" until the Commercial checkride. The standard that took effect last year is a 180 degree, power off abeam the approach end of the runway, landing. |
"Roger Halstead" wrote in message ... Of course the real ego deflator is landing in a gusty wind only to find 6 or 7 pilots standing by the gate holding up signs to grade the landing snicker No snicker about it; I had three line boys in Hays, Kansas do that to me several years ago. |
"m pautz" wrote in message
news:7yEzc.44640$0y.5757@attbi_s03... So, the question I have for the group is why are power planes taught to have these wide patterns with low angled turns? Why are the patterns outside the glide angle of a powerless airplane? Light the blue touch paper, stand well back. Paul |
"OtisWinslow" wrote: It is not "required" until the Commercial checkride. The standard that took effect last year is a 180 degree, power off abeam the approach end of the runway, landing. Got my ticket in '76. The first landings I was taught in a C-150 were no flap, no power landings. Pulled the power abeam the numbers and set up a glide at 70 mph. Edward |
On Wed, 16 Jun 2004 08:21:38 -0700, "Tom Sixkiller"
wrote: "Roger Halstead" wrote in message .. . Of course the real ego deflator is landing in a gusty wind only to find 6 or 7 pilots standing by the gate holding up signs to grade the landing snicker No snicker about it; I had three line boys in Hays, Kansas do that to me several years ago. I was speaking from experience:-)) I have been on both ends of the grading from being the grader to the gradee. I've stopped over in Hays due to haze (for real) to and from BJC when taking the southern route to keep out of the storms. Man, there ain't nuthin between Salina and Hays. Not much more to Goodland. The one thing I remember about Hays (after the haze lifted) was seeing what appeared to be a bluff way off to the west. It's really a series of hills, but from the airport it darn near looked like a cliff. Well, time to close the windows. There's another storm headed this way. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Cub Driver wrote
Personally, I have gone back to power-off landings for just this reason. And I try, not always successfully, to come in "high, hot, and slipping like crazy" since I don't have the option of raising the flaps. And what happens when you eventually hit an updraft? If you're already high, hot, and slipping like crazy, that updraft will put you too high and hot to land, and you will need to go around. Here's a bit of reality - unless you run out of gas, it is highly unlikely that an engine that was working just fine when you entered the pattern will fail so suddenly and so completely that it won't produce enough power to flatten your glide enough for you to make the runway given a reasonable pattern. On the other hand, it may well crap out badly enough that you won't have the power to go around - especially if you are flying a 65 hp Cub, which is a marginal performer anyway. I'm all for keeping the pattern close in, but there are limits to everything. Michael |
Edward Todd wrote
Got my ticket in '76. The first landings I was taught in a C-150 were no flap, no power landings. Pulled the power abeam the numbers and set up a glide at 70 mph. And there is a good reason to learn that way - it reduces complexity. You don't screw around with anything after the downwind abeam point. You set throttle to idle, pull carb heat, trim to the correct airspeed, and after that all you do is fly the airplane. Obviously your instructor understood the concept of starting simple and moving to the complex. I'm sure you learned to do full flap landings at some point - but flaps are additional complexity you don't need while learning to fly a pattern and land. On top of that, the flare becomes less critical since the sink rate is reduced. Unfortunately, most of today's instructors don't really understand this. They start the student doing landing procedures that involve multiple power, flap, and airspeed changes in the pattern. Each of those changes requires a change in trim. The result - the student has too damn much to do. His airspeed control goes to hell (because with all those configuration changes the plane is perpetually out of trim) and he just doesn't have enough time to simply fly the plane. So what happens? Power is added and the pattern is made wider to slow things down and give the student more time to do everything that he doesn't really need to be doing yet. Accelerated stall becomes a concern because the student may not be able to tell that he is pulling back too much - he's gotten used to flying out of trim. On top of that, the student is still fumbling for throttle, flaps, and trim - and is late making power reductions and flap additions, so the pattern gets even bigger. The instructor spends his time reminding the student to perform the "procedure" instead of watching his flying. Everything is worse. Michael |
"Michael" wrote in message m... Cub Driver wrote Personally, I have gone back to power-off landings for just this reason. And I try, not always successfully, to come in "high, hot, and slipping like crazy" since I don't have the option of raising the flaps. And what happens when you eventually hit an updraft? If you're already high, hot, and slipping like crazy, that updraft will put you too high and hot to land, and you will need to go around. You have obviously never slipped a Cub. An updraft that can keep a Cub from making the numbers has not been invented. My wife came in over the numbers at pattern altitude and we were down and stopped on the first third of a 3,000 foot runway. Gotta love a plane with a real rudder. |
| Thread Tools | |
| Display Modes | |
| Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 07:49 PM |
| "bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 29th 04 12:04 AM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
