![]() "Bob Gardner" wrote in message ... An article (actually, a sidebar to an article) in the July IFR magazine says "According to AIM 1-1-20 (f)(7), by omission, you can't just input the VOR as the active waypoint....," and "...according to this passage, the FAA allows GPS to substitute for everything except for a VOR. For some reason, the FAA has faith in its VORs and won't let you substitute GPS for them as a primary means of navigation." Maybe this is why Garmin does not include VOR-based airways. Garmin panel mount units have airways. More likely the reason airways are not included in the handhelds is the limitation on memory for the database. |
Most do not. The ONLY panel mount Garmin that has airways is the CNX-80.
Karl Biding my time in Roskilde, Denmark "C J Campbell" wrote in message ... "Bob Gardner" wrote in message ... An article (actually, a sidebar to an article) in the July IFR magazine says "According to AIM 1-1-20 (f)(7), by omission, you can't just input the VOR as the active waypoint....," and "...according to this passage, the FAA allows GPS to substitute for everything except for a VOR. For some reason, the FAA has faith in its VORs and won't let you substitute GPS for them as a primary means of navigation." Maybe this is why Garmin does not include VOR-based airways. Garmin panel mount units have airways. More likely the reason airways are not included in the handhelds is the limitation on memory for the database. |
On Tue, 15 Jun 2004 15:52:56 -0700, "Bob Gardner"
wrote: An article (actually, a sidebar to an article) in the July IFR magazine says "According to AIM 1-1-20 (f)(7), by omission, you can't just input the VOR as the active waypoint....," and "...according to this passage, the FAA allows GPS to substitute for everything except for a VOR. For some reason, the FAA has faith in its VORs and won't let you substitute GPS for them as a primary means of navigation." Bob, I cannot find that paragraph. AIM 1-1-20 refers to WAAS boxes certified under TSO-146, which do not require any other type of navigation equipment to be on board and can be used for enroute navigation using VOR's (and airways, for that matter), without a VOR receiver on board. You (or the July IFR magazine -- haven't seen it yet) are probably (or should be) referencing 1-1-19 which refers to TSO 129 boxes. Those do require an alternate means of navigation to be on board. But, not having read the article, I would disagree that one cannot use VOR's as the active waypoint in a TSO129 box that is approved for GPS approaches. It makes no sense so long as the VOR is retrieved from the box's database. Since that same box can be used to fly overlay approaches based on a VOR, to claim that because the substitution is omitted in 1-1-19 (f)(7) that it is not allowed, makes no sense. It is certainly allowed in performing the overlay approaches. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Garmin 296 worth the money? | Terry | Owning | 15 | June 22nd 04 09:03 AM |
Microsoft Flight Simulator and Garmin aviation handheld GPS | John Bell | Piloting | 4 | March 25th 04 11:56 AM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
