Glad everything worked out OK. Sounds like you learned the meaning of
"marginal". If you make this flight again, you might want to consider leaving a "lot" of fuel behind departing BIH and landing an airport in the Central Valley for fuel if you need to. Even on calm days there is very little margin in a fully loaded normally aspirated airplane, particularly on hot days. I have also had the "why isn't this thing climbing?" experience and didn't like it very much either. There are supposedly over 100 planes that crashed in the Sierra that have never been found... Mike MU-2 "Dave Jacobowitz" wrote in message om... [ summary: lots of plannig, heavily loaded plane. one good, clean flight in the cool morning air, followed by a less admirable return flight where density altitude and loading almost bit ] KPAO - KBIH - KPAO Trip PIREP: The goal here was to do a quick weekend trip to Bishop, California, to so some rock climbing at Owen's River Gorge, the "Premier Sport Climbing Area of the Eastern Sierras." There were several challenges to this trip. 1. equipment was /A IFR Cherokee 180 2. pilot + 4 passenger ( 200#, 160#, 130#, 100# ) 3. climbing gear ( 60# ) 4. Crossing the Sierras 5. no O2. As you know, I worked the Internet and the POH pretty hard to plan this trip, and it kept working out on paper -- but just barely, at least in my mind. Nothing ever said, "no!" but there were plenty of potential gotchas, and though I thought I understood them, in hindsight I think I did not fully respect how they were additive in nature. (see, high, hot, and heavy at the end of this story. ;( ) Loading the A/C --------------- With the passengers and gear, and fuel for Bishop, plus my traditional add'l fuel: destination + alternate + 1 hr, the aircraft was within five lbs of it's max gross. It was legal, but I'd never flown an aircraft in that part of the envelope before. CG was not too bad, however, about midway between fore and aft limits. Outbound Leg ( KPAO - KBIH ) ----------------------------- Got up at a 4:45 am to get a briefing, shower and get to the airport. The briefing, and my examination of the night sky outside my bedroom window made it clear that we would have to depart IFR, but that the central valley would be clear. I filed two flight plans, one IFR, one VFR. IFR: KPAO - SJC - V334 - SUNOL - V195 - ECA VFR: ECA - KMMH - KBIH At 6:30 my friends and I loaded up, and I picked up my clearance from the tower just as they were opening for the day. We took off and were soon climbing through about 750 feet of your basic summer marine layer. This would be my 0.1 hrs of IMC for the weekend. (Exciting for me nontheless, as I got to use my rather new IFR ticket!) Oh, I should mention the takeoff. It was a little interesting. The acceleration on the takeoff roll was underwhelming, and it took a good chunk of the runway (2500' at PAO) to get to a rotate speed, this using the short field takeoff technique. Nevertheless, the Cherokee departed comfortably from the runway and climbed initially at a healthy 500 ft/min in the cool morning air. Before making it onto V195, I cancelled IFR and headed directly to about the position where V230 (the 23 deg redial of FRA VOR) intersects with the base of the sierras. We climbed for a good long while. Though the initial climb rate out of PAO was good, it soon tapered off considerably, and by the time we were at 9000 or so, it was about 100 ft/min. what's always interesting to me abou the high-altitude performance of these aircraft is how the speed range at which the aircraft will climb is so limited. On Saturday morning, it was between 80 and 90 mph. Go outside that range, and go down. So, after I don't know how long, we were cruising allong at 11.5. When we got close to the Mammoth Pass, I let the aircraft climb again, and there was some lift to help us. But the time we were over the higher areas of the pass, the aircraft was at nearly 13000. The view was awesome. I didn't get to take pictures but the passengers were happy. Once past the high terrain, I let the plane descend under power, and rolled well into the yellow arc (whee!) in the smooth mountain air as we passed by KMMH (Mammoth) and turned towards Bishop. The landing at Bishop was easy and pretty routine. Odd experience after landing though. I had a mentally difficult time getting the aircraft maneuvered to where I could push it into a tiedown spot. Basically, there were a few other aircraft on the ramp, incluing a couple of expensive ones with larger than average wing-spans, and for some reason, my brain just "would not compute." I suspect it was partly new airport confusion and potentially partly hyopxia. Anyway, I think I'll invest in an O2 system if I do much more mtn flying. Return Leg ( KBIH - KPAO ) ----------------------------- Because of a passenger's constraint, we could not return on Monday morning in similar cool air conditions that we had gone out in. I was not super- happy with this, but I aquiesced to an early evening departure on Sunday, around 7pm. I thought that this would be a good compromise between waiting for the air to cool and not crossing the mountains in the dark. As PIC, I think this was the biggest mistake of my trip, and I'll be thinking about it for a good while to come. I got a briefing, and a 15 minute-old PIREP from a Centurion at 12.5 said the ride through the Mammoth pass was smooth so I felt good about the crossing. We took off from BIH rwy 30 at about 7. The wind was light and variable, and 30 seems to be the calm runway there, and it's the longest. The density altitude was about 7500. The POH made it clear that I could comfortably escape in those conditions, so I tried it, and regret doing so. It's not that there was an accident. There was none. I used the short- field takeoff, leaning for best power before t/o, etc, and as in Palo Alto, the aircraft accelerated at a meandering pace. However, we were off and climbing in less than half the 7100 ft runway. The first 100 feet or so, the plane climbed normally, and then... it would not climb at all. It was a frightening moment for me, though thankfully not for the passengers who did not know something was amiss. (Except for the one passenger up front, a pilot herself, though not current.) Though there were no thunderstorms in the immediate area, there were rain streaks visible under clouds that were perhaps 30 miles or more away (and in the south, opposite of where we were going), and I think the aircraft was caught in some drafts from them. I don't really know for sure, though, whether they were related. In any case, there was maybe a 30 second period when the plane wasn't climbing, and was only 200 feet off the ground. Eventually, it started to climb again, though with only about 100 ft/ min, and only in the narrowest range of airspeeds. I told myself that if took more than three more minutes to climb to 1000 ft agl, I would return to the airport. The plane did start to behave a bit better, and, doing large circles in the (thankfully flat) vicinity north of BIH, we slowly clawed our way up to about 9000, then headed over to MMH, where we again circled to about 12.5, and then we flew the pass. I was expecting downdrafts on the eastern side of the sierras, and so I wanted to have altitude to spare, and I also approached at a 45 degree angle, to allow for an out if things went poorly. However, by now, the plane was out of the hot air, and flying more like it's pitiful (but predictably) performing regular self. Also, I unexpectedly found lift where I expected sink -- and I took it to about 13000. Once over the mountains, we flew direct palo alto. Over Livermore it became obvious that the sunol pass was not going to work vfr, so I asked NorCal approach (with whom I was getting vfr flight following) if I could go off-frequency to air-file IFR to PAO. He said I could stay with him and get the VOR-DME into PAO. While on vectors for the approach, we were over San Jose airpot, from which I could approach PAO VFR, so I cancelled and went in and landed uneventfully. what I Learned -------------- I can cross the Sierras comfortably in an underpowered light plane. It just takes time and patience to get up there, I want room to spare, but it's possible. Nice to know. But the more ominous lesson is to take density altitude, aircraft performance, and aircraft loading seriously. I had made a classic "high, hot and heavy mistake" -- and I paid for it. I didn't do so with my life this time, but the pounding in my heart might have taken some time off the end! I flew the airplane at its limits. I flew according to the book values, and they were actually more or less right, but I did not leave myself safe latitude for them to be wrong. A random variable -- some potential downdrafts or other strange winds, for example, almost turned my barely acceptable climb rate into a descent. Though the outcome was succesful, I think this flight is more of the "Never Again" variety. If I had to do the whole thing over again, I simply would have insisted on a lighter A/C (ie, one fewer passener) and/or that we wait until morning and fly back under similar smooth, cool, conditions we flew out in. Thanks for reading! Dave J |
Thanks for reading! Dave J Thanks for writing... being a new guy I devour these stories looking to be a better pilot.. Thanks! |
On Mon, 21 Jun 2004 17:39:03 +0000, Doug wrote:
Thanks for reading! Dave J Thanks for writing... being a new guy I devour these stories looking to be a better pilot.. Thanks! Well said! I guess the line starts here! ![]() Cheers! |
Dave,
great story, thanks for relating it. Seems you did everything right - but with only a small margin. -- Thomas Borchert (EDDH) |
Chixfly2 wrote:
One of my airplanes is a PA28-140 160hp. I finally took the back seats out to prevent people from saying, "you don't mind flying me, my wife and kids up to Tahoe for the weekend?". Sure you can do that. Make sure to leave San Jose (or whereever) at 5am. Take him up on Tuesday, the wife up on Wednesday, and the kids up on Thursday and Friday. P.S.: I need to get back up to Tahoe - it's gorgeous in the summer! An hour to get there, rent a car, and drive to the 'beach'... Hilton |
| Thread Tools | |
| Display Modes | |
| SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 04:02 PM |
| AOPA Sells-Out California Pilots in Military Airspace Grab? | Larry Dighera | Instrument Flight Rules | 12 | April 26th 04 07:12 PM |
| Soviet Submarines Losses - WWII | Mike Yared | Military Aviation | 4 | October 30th 03 04:09 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Patrick AFB Area Log, Monday 30 June 2003 | AllanStern | Military Aviation | 0 | July 1st 03 07:37 AM |
