Flying under IMC
Old June 29th 04, 10:24 AM
Peter Duniho
online.com...
Is that likely to work? ATC may, after all, deny the "on top" clearance.
As Ditch says, ATC has the authority to deny the clearance, of course. But
since it makes their life easier, I don't know why they would. I have never
been denied a request for a "VFR on top" clearance. Granted, I fly VFR much
more often than IFR, but I just can't see why ATC would ever deny a "VFR on
top" clearance.
Pete
Old June 29th 04, 07:11 PM
Newps
online.com...
Peter Duniho wrote:
the "VFR on top" clearance to resolve
whatever issue ATC had, and allow yourself to proceed directly to
whereever you were headed.
They might in very busy terminal airspace that you are inbound to. They
will be gleeful that you want to remove yourself from the separation pool
otherwise.
Old June 29th 04, 08:54 AM
Julian Scarfe
"Peter Bauer" wrote in message
om...
.. when flying under a flight plan (IFR) can i fly routes at my choice ?
e.g. take-off under IMC, enroute 10 min under IFR (clouds), 30 min VFR
on
top, descending to my destination under IMC (through cloúds),
landing
at destination under VMC (below the lower layer of clouds)
.. when reaching IMC after 30 min. VMC ("round trip under VFR") do i have
to file a flight plan (IFR) or am i able to fly only by reference to
instruments through an e.g. 300 ft Layer of clouds and after that,
when
reaching "On Top" fly again under VFR ?
You do not say where you are flying, Peter. Others have answered on the
assumption that you are flying in the US, I'll give you an answer for
Germany.
The airspace system in Germany is not very different to that in the US, but
there are a couple of differences. Controlled airspace generally starts at
2500 ft agl rather than 1200 ft agl. Flying under IFR in class G is
forbidden in Germany. Thus for an IFR flight, if your destination is not an
IFR airport surrounded by controlled (or class F) airspace, you usually need
to be able to cancel IFR by the minimum instrument altitude which is not
below 2500 ft. This makes IFR flights to VFR airports fairly painful.
To fly under IFR you need a clearance. Pop-up IFR clearances (if you find
IMC on a VFR flight like your second scenario) are troublesome. I've had to
dictate an entire flight plan (including the colour of the dinghy cover) to
a FIS controller to get an IFR pop-up, despite having filed a VFR plan with
almost exactly the same info.
"VFR on top" clearances, as Pete described are not used in Germany (in fact
they're not used outside the US). But you will find that practical IFR
clearances tend to include long direct legs, so it's unusual to be in a
situation where a VFR routing will save you a lot over an IFR one.
So where are you based?
Hope that helps
Julian Scarfe
Old June 29th 04, 06:21 PM
Peter Bauer
Hi,
i'm based in Germany with a FAA-PPL ASEL.
It's very interesting to read the differences in IFR-Flying in the
States and in Germany. Although the two countries are "ICAO-countries"
they are not
participating in same air work to each other.
Well, i think ...when learning for an IFR-Rating you should know
before what you are allowed to do with it or not after passing it.
I think most "VFR"-Pilots only know about the new ability to fly in
clouds without reference of the ground surface.
It's very interesting for me to know how the real IFR-flight is
working, what problems with ATC you have when flying under IFR, the
change IFR-VFR, and a lot of other things....and that....before
"doing" the Rating.
Thank you all for asking my questions....
Peter
Old June 29th 04, 09:27 PM
Julian Scarfe
om...
they are not
If you think Germany and the US are different, try crossing the border into
other European countries. Of all of them the airspace system in Germany is
most like the US, and the UK is probably at the opposite extreme. Here we
have mostly class A and class G, with little between. IFR flight in class G
is something we do every day -- there's not a lot of choice.
Good luck if you choose to do the IR.
Julian
Old June 30th 04, 08:49 AM
Kai Glaesner
Julian,
G
IIRC in the UK you have some sort of "poor-mans-IFR" (no pun intended ;-)
called the "IMC" rating, giving you the right to fly under IMC without being
"in-the-system".
Does that thing make it to JAR-FCL?
Best Regards
Kai Glaesner
Old June 30th 04, 09:06 AM
Julian Scarfe
"Kai Glaesner" wrote in message
being
"in-the-system".
Still available as a national rating valid for IFR only in the UK. The only
difference from the way it used to be is that it no longer gives credit
towards an IR. However, an FAA IR gives credit towards a JAA IR, and the
instrument time for an IMC rating counts for the time required for an FAA
IR. So we have the screwy situation that the usual "upgrade" path is IMC
rating - FAA IR - JAA IR.
Julian Scarfe
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 01:33 AM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 04:33 AM
Flying is Life - The Rest is Just Details Michael Piloting 55 February 7th 04 04:17 PM
Wm Buckley on John Kerry Big John Piloting 22 February 7th 04 03:19 AM
Announcing THE book on airshow flying Dudley Henriques Piloting 11 January 9th 04 08:33 PM
