Seeking anecdotes about "instructor in command"
Old July 2nd 04, 04:20 PM
Andrew Gideon
Michael wrote:
But in order to trust the instructor, you have to believe the
instructor really knows best. In other words, you have to believe
that while you are operating outside your envelope, the instructor is
well within his. This is made more difficult because there are many
documented cases where this was not true. All I can say is, choose
your instructor carefully. Just because the FAA gives a guy a piece
of paper doesn't mean he's qualified.
You're absolutely right about making the right instructor choice.
But I still think that there's a line here that can be drawn, if not easily.
Yes, we're trusting the intructor. But there's still a difference, at
least as I see it, between (1) deliberately going past one's envelope with
the backup of an instructor, and (2) letting one get out of one's envelope
due to complacency. One is an intentional - and communicated, but I'm
thinking this is merely a consequence of intent - act while the other
occurs through a relaxation of one's attention/care/responsibility.
However, this idea of the instructor as a safety mechanism can be taken
too far with the pilot has in his mind, even if quietly, "if this was
bad, he'd say something".
Now you're changing the situation. Yes, poor communications can be
deadly.
Yes. But I'm thinking that this - communication - is more a symptom than
cause in the "syndrome" I'm trying to define.
It is indeed quite possible for the student to see something
the instructor has missed. It is absolutely legitimate and proper for
the student to bring this up. However, it is equally legitimate for
the instructor to say "Yes, I'm aware of this, and it's not a problem
because..." and you either trust the instructor and keep going or you
get another instructor.
But this is a perfect example of "trust" and not "complacency". To turn
this into "complacency", the student would either (1) not notice because
he's paying less attention or (2) not tell the instructor. Either could
result from the student assuming that if there really were a problem, the
instructor would say something.
The concerns of the copilot should be addressed, but the ultimate
decisionmaking authority remains with the captain. Always. And yes,
somtimes that means pressing on when the copilot is uncomfortable
because the captain is comfortable.
This is something on which I'm not yet clear. In my reading, some of the
accident descriptions include the captain overriding the copilot's
discomfort. In one example, the last words on the CVR were "I told you
so". I think that what's being offered is that sometimes the more
comfortable pilot *should* be overridden.
However, an instructional flight is - as you note - obviously a different
situation. There's the expectation of discomfort, if you will. As long
as "envelope excursions" are made explicitly, this is "trust". It's the
unawared excursion that's the problem.
I think you need to separate the two.
Right. That's exactly what I'm doing grin.
When operating outside one's envelope, there is unavoidable risk.
That is a good point. Justified, but there nevertheless.
This was a perfect example of poor communication.
Yes. Thanks for sharing it.
Basically, I think you're invoking intent when what we're really
dealing with is just communication. The intent was the same first and
second time around; it's just that the first time around we botched
the communication and nearly put a wing in the trees.
Perhaps. In this example, you accepted going past your envelope explicitly,
even though there was a communication failure. I still believe that
there's "more room for error": performing a task outside the envelope w/o
explicitly realizing/considering that fact.
Of course, failure to realize something will cause that non-realization to
not be communicated.
- Andrew
Old July 2nd 04, 05:53 PM
Teacherjh
But when?
Jose
Old July 2nd 04, 05:56 PM
Andrew Gideon
But when?
Good question. I don't yet have an answer. It may be that the literature
doesn't provide a clear answer, but I'm not yet ready to say that.
- Andrew
Old July 6th 04, 06:35 PM
Michael
So what you're postulating is the existence of a pilot who stops
asessing risk just because the instructor is there, even though he's
actually a pilot who is already able to fly on his own, and thus
necessarily able to asess and manage risk? Are you sure this actually
happens? Because from my point of view, that's like abdicating one's
responsibility as a pilot, and dropping to the level of a passenger
who is allowed to manipulate the controls or share some cockpit tasks.
If that's what you mean, well, I admit there is a difference between
that and simply poor communication - but are you sure this actually
happens?
But in training, it's fairly common and perfectly legitimate to force
the student to operate at task saturation for extended periods. This
will cause him not to notice things because he is paying less
attention - but this is the unavoidable price of teaching the
emergency survival skill of flying at task saturation.
And that may be part of the ground rules of the flight.
For example, a hooded pilot abdicates the responsibility for collision
avoidance to the safety pilot. He can pretty much keep on trucking
unless the safety pilot says something.
But do you see that there was no complacency involved? We both fully
understood that we were undertaking envelope expansion - that we would
be operating within his envelope but outside mine. Yet we still
screwed it up.
I simply have a hard time imagining how it would happen. I mean, if
what you're doing is within your envelope, why do you have the
instructor there? You could simply do it yourself.
Michael
Old July 6th 04, 06:39 PM
Michael
But when?
I will suggest one for you - when more comfortable does not mean more
capable. The problem is how to measure capability.
I will also suggest that nothing is perfect, and that just because
something bad happens after the less comfortable pilot predicted it
would does not mean that his reasoning was not faulty. I offer for
your consideration the famous warning, "Beware the Ides of March."
Michael
Old July 6th 04, 07:04 PM
Teacherjh
Yes, I think that's exactly what is being postulated. I think there's a
continuum between the extreme case of becoming a passenger, and the other
extreme case of ignoring the instructor's existance.
Jose
Old July 6th 04, 07:09 PM
Andrew Gideon
happens?
No, I am absolutely *not* sure.
One possible example: landing after an instrument lesson. Normally, the
landing would be well within a pilot's envelope. But if the wind is more
gusty than comfortable to this instrument student, and he doesn't really
evaluate this because he's depending upon the instructor...
- Andrew
Old July 6th 04, 07:12 PM
Andrew Gideon
Michael wrote:
I offer for
You don't check with soothsayers as a part of your preflight? If only
Caesar had received a full briefing...
- Andrew
Old July 6th 04, 08:07 PM
G.R. Patterson III
Well, the FARs *do* say "all available information".
Lessee here ... where'd I put the horoscope page......
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Aviano welcomes new wing command Otis Willie Military Aviation 0 June 19th 04 09:18 PM
This made me chuckle. . . Scott Ferrin Military Aviation 21 April 15th 04 07:12 AM
Strategic Command Missions Rely on Space Otis Willie Military Aviation 0 September 30th 03 09:59 PM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
