Water Injection Question
Old July 10th 04, 09:00 AM
Dale
Scott Skylane wrote:
In the piston (large radial) world,
a water/alcohol mix is injected just downstream of the carburettor for
hight power operation. This has the effect of reducing combustion
chamber temperatures, thus allowing higher manifold pressures (i.e. HP)
without detonation.
Scott,
Are you guys using ADI on the -6?
And congrats on making First Officer!!
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old July 10th 04, 05:35 PM
Paul Sengupta
"Don Hammer" wrote in message
A jet engine produces thrust by the amount of mass it can push out the
back end. By injecting water you have increased that mass and the
thrust increases without a cooresponding increase in internal
temperature.
Ooo, a steam engine!
Paul
Old July 10th 04, 06:24 PM
Tom Sixkiller
"Paul Sengupta" wrote in
message ...
temperature.
PW, GE and Honeywell and going to merge with Stanley.
Old July 11th 04, 09:36 AM
DeltaDeltaDelta
Thanks for all your replies. I understand it now. On the older big radials
equipped with some form of pre-charging, the charger itself would heat up
the air as it compresses it and have effect on the detonation point. Now it
makes sense
Triple Delta
Old July 12th 04, 05:39 AM
Scott Skylane
Dale wrote:
/snip/
Scott,
Dale,
Yes, we use it, generally for takeoffs above about 85,000 lbs. If
anyone's interested the fuel burn for an R2800 CB-16 is as follows:
Max Dry power (53" M.P. 2800 RPM 1950 HP) 1850 lbs/hr
Max Wet power (59.5" 2800 RPM 2400 HP) 1550 lbs/hr
And thanks for the congrats!! It sure beats working for a living
Happy Flying!
Scott Skylane
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 05:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
C-17s as water bombers Ross Oliver Piloting 11 November 12th 03 02:22 AM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 09:47 PM
