#11
"Maule Driver" wrote: I'm thinking the adverse yaw would only work with downwind ailerons. Averse yaw is caused by the drag of the down-deflected aileron. Assuming you have the correct aileron position for the crosswind, the drag of the down-deflected aileron will help counter weather-vane. In the B-17 if you used the wrong aileron you would not have enough rudder to counter it...the ailerons on that airplane produce a lot of drag. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Yep, I got mixed up.
"Dale" wrote in message ... In article , "Maule Driver" wrote: I'm thinking the adverse yaw would only work with downwind ailerons. Averse yaw is caused by the drag of the down-deflected aileron. Assuming you have the correct aileron position for the crosswind, the drag of the down-deflected aileron will help counter weather-vane. In the B-17 if you used the wrong aileron you would not have enough rudder to counter it...the ailerons on that airplane produce a lot of drag. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Maule Driver wrote:
Yep, I got mixed up. "Dale" wrote in message ... In article , snip... In the B-17 if you used the wrong aileron you would not have enough rudder to counter it...the ailerons on that airplane produce a lot of drag. That's a bit strange. What is the "wrong aileron"? Ailerons control roll, while the rudder controls yaw. If you are "wing low" while approaching in a crosswind, it is possible that the windward wing will dip and a spin will try to start. You need to correct using the rudder, but if no more authority is available, you have a problem. It's not specific to the B-17. |
In article I8lJc.83007$IQ4.42418@attbi_s02,
"William W. Plummer" wrote: That's a bit strange. What is the "wrong aileron"? Ailerons control roll, while the rudder controls yaw. I'm referring to after you're on the ground...during rollout. I had a "Captain" roll in the wrong aileron when the airplane began to turn into the wind...things got pretty interesting for a bit. G -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
William W. Plummer wrote:
Maule Driver wrote: In the B-17 if you used the wrong aileron you would not have enough rudder to counter it...the ailerons on that airplane produce a lot of drag. That's a bit strange. What is the "wrong aileron"? Ailerons control roll, while the rudder controls yaw. But not always, and not only. If you have an ASES rating you must be familiar with the use of ailerons for steering on the surface. You also should not overlook the necessity of using rudder to control roll in high angle of attack on swept wing high performance aircraft, while avoiding the use of ailerons. If you are "wing low" while approaching in a crosswind, it is possible that the windward wing will dip and a spin will try to start. You need to correct using the rudder, but if no more authority is available, you have a problem. It's not specific to the B-17. Perhaps you are more familiar with the specific characteristics of B-17s than is Maule Driver. If so, by all means tell us about it. Do you notice the apparent contradiction between your statement in your first paragraph and your claim in the second paragraph? -- Jack "Cave ab homine unius libri" |
In article , Jack
wrote: Perhaps you are more familiar with the specific characteristics of B-17s than is Maule Driver. If so, by all means tell us about it. Do you notice the apparent contradiction between your statement in your first paragraph and your claim in the second paragraph? Which two paragraphs? mine or Maule Drivers? G -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Very long XC Story | SFM | Instrument Flight Rules | 2 | October 27th 04 03:08 PM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
SWRFI Pirep.. (long) | Dave S | Piloting | 19 | May 21st 04 03:02 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
IFR Long X/C and the Specter of Expectations | David B. Cole | Instrument Flight Rules | 0 | February 24th 04 07:51 PM |
