Request: Technical Proofreading EAA Sport Aviation
Old July 18th 04, 01:23 AM
Chuck Forsberg WA7KGX
Is the second harmonic of the 121.5 ELT signal used by satellites
or a significant number of homing receivers?
Chuck Forsberg www.omen.com 503-614-0430
Developer of Industrial ZMODEM(Tm) for Embedded Applications
Omen Technology Inc "The High Reliability Software"
10255 NW Old Cornelius Pass Portland OR 97231 FAX 629-0665
Old July 18th 04, 04:40 PM
Jim Weir
It was the only way they could get a signal in both the civilian and military
air bands. If you want to be able to use the military homing gear that is
restricted to military frequencies, you had to have part of your signal in the
military band.
It is a crystal BITCH making an antenna that is as good a radiator at the
fundamental as the second harmonic.
-Is the second harmonic of the 121.5 ELT signal used by satellites
-or a significant number of homing receivers?
http://www.rst-engr.com
Request: Technical Proofreading EAA Sport Aviation Jim Weir Home Built 31 July 20th 04 05:15 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 06:11 AM
