#11
"Mike Murdock" wrote
Mr. Campbell, based on your previous posts, you seem to have an axe to grind about Cirrus. Why? Do you think Cirrus Design is trying to hoodwink pilots? I'm not Mr. Campbell (fortunately) and I rarely agree with him on anything. Further, I don't think much of the document cited. However, I think that Cirrus fundamentally isn't being honest with its target customer base. I think the Cirrus is a fine airplane with some surprising limitations in standard equipment. Selling what is supposed to be an IFR cruiser, supposedly fully equipped without spherics, is just a bit odd. No option for known ice is equally odd. I can't think of any part of the US where you need IFR capability and don't need either one to maintain that IFR capability year-round. I think it's silly to compare the Cirrus and turbo 182 - the Cirrus is, after all, over 30 kts faster. No amount of dancing will get around that - and the 26 minute average trip difference falls appart when the headwinds kick up. I think the whole spin thing is way overrated - lots of GA airplanes should not be spun. In fact, outside of some military trainers, I really can't think of any 170+ kt IFR cruisers that don't have ugly stall/spin characteristics. I see no real issue here - these are not trainers, and should not be flown by novices. And that is at the heart of the problem I have with the Cirrus. It's presented as an airplane that the low time pilot can use to get solid VFR and IFR utility. In reality, it will take significantly more advanced designs than the Cirrus before this is possible, along with some changes to the national airspace system. The 182 is a reasonable airplane for a low time pilot, and turbocharging the engine really doesn't change that. The Cirrus should be evaluated alongside planes like the Bonanza, Viking, and similar performers - and pilot experience should also be similar. Michael |
Mike Murdock wrote:
The original document upon which this one is based originated from a Cessna dealer, not the Cessna Corporation. This document was (is?) available to CSTARs (aka Cessna dealers) through the Cessna marketing website. So you could consider this an official Cessna Document. AFAIK similar documents were produced for 172 vs Piper Archer and 172 vs Diamond Katana. Cheers, Jens -- I don't accept any emails right now. Usenet replys only. |
C J Campbell wrote:
This article pretty much describes the differences between the two airplanes and points up the issues that I have with the Cirrus. http://www.airplanenoise.com/article....%20Cirrus.pdf It's telling that the article starts with flyover noise comparisons and prop clearance. It's a poorly done attempt at a smear and shouldn't be taken seriously by anyone with the ability to recognize obvious bias. I have no vested interest in either aircraft, although I instruct in both Cessna and Cirrus products. The Cirrus is an "interesting airplane," and overall the value for the average prospective owner (let's say, private pilot with an instrument rating) undergoing the average mission (regional travel, 100-300 hours of flight time per year) is just not there with the Cessna products anymore. Single-engine piston airplane sales trends reflect this. As a Cirrus Standardized Instructor, I have my own set of issues with the SR-20 and SR-22. The cited article barely hints at the real problems (which are NOT the chute or the composite airframe), and it reads much like it was written by a person who has flown neither aircraft. I believe that over time the Cirrus product will improve and flourish, while the Cessna line has been taken as far as it can go, G1000 or no. In summary, if you operate from short/unimproved fields, the Cirrus is not a realistic choice for you. If you want to rocket along at 180+ knots with a fairly advanced (although not overly redundant) avionics package, the SR-22 might fit you like a glove. Side note, the SR-22 is among the most spin-resistant airplanes on the market today. Spins in the SR are a red herring - think electrical system and avionics redundancy if you want to dive into the real can of worms. -Ryan |
H.P. wrote:
I'm a newbie here but airplanenoise.com seems like its straight out of Cessna's marketing department? I don't think I've ever seen such blatant self-serving product marketing dressed-up as ersatz objective analysis!! ...except maybe in the case of Bose Corporation. In the comparisons with every other aircraft make, the message is "Buy anything except a Cessna and you'll go broke on the way to killing yourself". That kind of message doesn't lend itself to much credence in my book. True, but the most egregious error is that it fails to mention that real airplanes have the wing on top! :-) Matt |
Well, I wish it was a buying decision I expect to face...
CJC - I've always taken your posts seriously in the past. Will be difficult after that biased pile of dung. I hope you do work for Cessna - it's the only reasonable excuse. "C J Campbell" wrote in message ... This article pretty much describes the differences between the two airplanes and points up the issues that I have with the Cirrus. http://www.airplanenoise.com/article....%20Cirrus.pdf -- Christopher J. Campbell World Famous Flight Instructor Port Orchard, WA If you go around beating the Bush, don't complain if you rile the animals. |
![]() "Ryan Ferguson" wrote in message om... C J Campbell wrote: This article pretty much describes the differences between the two airplanes and points up the issues that I have with the Cirrus. http://www.airplanenoise.com/article....%20Cirrus.pdf It's telling that the article starts with flyover noise comparisons and prop clearance. It's a poorly done attempt at a smear and shouldn't be taken seriously by anyone with the ability to recognize obvious bias. Have you seen the "Stop the Noise" thread? |
![]() "Maule Driver" wrote in message .com... Well, I wish it was a buying decision I expect to face... I wish it was, too. CJC - I've always taken your posts seriously in the past. Will be difficult after that biased pile of dung. I did not write the biased pile of dung. However, I think it is no more biased than Cirrus' advertising. I believe it brings up a serious number of legitimate issues. I hope you do work for Cessna - it's the only reasonable excuse. Most know that I work for a CSTAR, but not Cessna itself. Personally, I enjoyed flying the Diamond far more than I did the 182. I am also not yet convinced that the G-1000 (or any other flat panel display) is really worth the premium. It is pretty and I could get used to it, maybe even proficient with it, but how much additional utility do I get out of it? |
![]() "Michael" wrote in message om... "Mike Murdock" wrote Mr. Campbell, based on your previous posts, you seem to have an axe to grind about Cirrus. Why? Do you think Cirrus Design is trying to hoodwink pilots? I'm not Mr. Campbell (fortunately) and I rarely agree with him on anything. I really hate having to agree with you on something. It is almost enough to make me change my mind. But, yes, I think the big problem is the type of pilot that the SR22 is being marketed to. |
Mike,
If you are prone to spinning airplanes during the turn from base to final in the pattern, please don't buy a Cirrus. Pleas don't buy ANY airplane, in that case. None are any more recoverable than the other. -- Thomas Borchert (EDDH) |
Cirrus for Duats | Charles | Piloting | 2 | July 17th 04 11:16 PM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
Cirrus attracting pilots with 'The Wrong Stuff'? | Jay Honeck | Piloting | 73 | May 1st 04 04:35 AM |
Cirrus report | Cub Driver | Piloting | 14 | April 30th 04 06:05 PM |
Cirrus Airframe Life Limits | Dave | Piloting | 16 | April 27th 04 05:58 PM |
