Sport Pilot Final
Old July 21st 04, 02:59 PM
Dr. Bob Lade
Actually, 45 knots = 51.75 mph, so it looks as if the 415C should be able to
have the SLA classification. That's a good thing, cuz many of the other
"eligible" a/c are tail-draggers. The castored main gear on the Ercoupe
should make a crabbed X-wind landing fairly easy (and necessary since
auto-coordination excludes slipping.)
Dr. Bob Lade
Lade's Internet Service, Inc.
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
239-772-1663 v/f 239-560-1631 m
"ET" wrote in message
"Dr. Bob Lade" wrote in
I meant the Ercoupe 415C, of course g.
Dr. Bob Lade
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
"Dr. Bob Lade" wrote in message
news
I have heard conflicting reports as to whether the Ercoupe 416C would
be eligible as a LSA or not. Anyone know for sure? I see it listed as
having
a
t/o weight of 1260 lb. under the 1320 lb. in the newly published FAA
rules...
Dr. Bob Lade
637 N.E. 15th Court
Cape Coral FL 33909
www.BobLade.com
Looks to me like your in....
Stall speed (clean) 48mph
LSA stall speed 45knots = approx 48.6 mph
ET
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Old July 21st 04, 03:03 PM
dave
Somewhat on topic, is it possible to change (lower) the gross weight
of a production aircraft? Example a piper clipper pa-16 is of course a
4 seater empty wight usually around 900 lbs, if I removed the back
seat and flew it at 1320 lbs or under (my wife and I together weigh
300 lbs or so)? It would meet all the other criteria vne 120 knots or
less, cruise and max speed 120 kts.
Dave
"Rich S." wrote in message ...
That would be closer to 51.7864910 mph.
Rich "The Devil is in the details" S.
Old July 21st 04, 03:16 PM
G.R. Patterson III
Sure. Recertify it.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Old July 21st 04, 04:13 PM
ET
"G.R. Patterson III" wrote in
Sure. Recertify it.
George Patterson
assault. In Tennessee, it's evangelism.
NO,
Well, YES, actually, but it will not do any good for Sport Pilot.
The FAA added the following to avoid just such a thing: "Light-sport
aircraft means an aircraft, other than a helicopter or powered-lift that,
since its original certification, has continued to meet the following:"
The words "since it's original certification, has continued" is your
problem. The same for the ercoupe 415 d's that used to be "c's". You
can't take them back to a "c" and fly under sport (and be legal). I
suppose it's unlikely that a ramp check will get you ... but if the ramp
checkers start carrying laptops with N-number databases in them... maybe
you would get caught.
ET
Old July 21st 04, 05:29 PM
Barnyard BOb -
Actually, NOT in the U.S.A.. [Pun intended]
Since 1959, the U.S. has used 6,076.115 feet
as the international standard for a nautical mile,
making 45 knots closer to = 51.78507102 mph.
However, there are other standards for a n.m.
Therefore... YMMV. g
Barnyard - PhD challenged - BOb
Old July 21st 04, 06:19 PM
G.R. Patterson III
problem.
Ah, yes. Careless reading on my part.
George Patterson
Old July 22nd 04, 01:57 AM
Bob Fry
"Dr. Bob Lade" writes:
Ercoupes don't have castoring (swiveling, turning, rotating) main gear
(legs). They are simply robust enough to take the side forces
generated by a crabbed landing.
Old July 22nd 04, 03:28 AM
Jim Weir
AAARGGH...one was enough. Two is too many.
Castoring means you are extracting the oil of the castor bean.
Castering means that something swivels.
Bob Fry
-"Dr. Bob Lade" writes:
- The castored main gear on the Ercoupe
-Ercoupes don't have castoring (swiveling, turning, rotating) main gear
-(legs). They are simply robust enough to take the side forces
-generated by a crabbed landing.
http://www.rst-engr.com
Old July 22nd 04, 06:01 AM
zatatime
On 21 Jul 2004 17:57:21 -0700, Bob Fry
This is not true. The main gear does rotate to compensate for crabbed
landings.
z
Old July 22nd 04, 04:38 PM
ET
Barnyard BOb - wrote in
able to have the SLA classification.
sorry, my first calculation was Knots with tax (grin). Or maybe I'm just
not tying them right.
ET
Sport pilot - International? Rich S. Home Built 5 August 24th 04 08:55 AM
Sport Pilot cuts off special issuance at the knees Juan~--~Jimenez Home Built 40 August 10th 04 01:19 PM
Diamond DA-40 with G-1000 pirep C J Campbell Owning 114 July 22nd 04 05:40 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
