Handpropping _ What are the FAR's or AC's
Old August 9th 04, 03:03 PM
Brian Jennis
Default Handpropping _ What are the FAR's or AC's
I've heard people say things like - it's illegal to start
your plane by propping it by hand unless there's a licensed
pilot at the controls. Others have said it's illegal to use
the armstrong starter unless it's tied down. Does anyone
know what the applicable regulations, FAR's and Advisory
Circulars are on the subject of starting by hand?
Old August 9th 04, 04:31 PM
Bob Gardner
There are no regulations on the subject, just recommendations. If anything
bad were to happen, "careless and reckless" would be the relevant
regulation.
Bob Gardner
"Brian Jennis" wrote in message
news
Old August 10th 04, 10:57 AM
Cub Driver
If anything
regulation.
I tried to pin my CFI down on these matters, and he said: "Dan, there
are all sorts of reasons why you don't want this to become an issue."
Incidentally, the original poster (I think) said that a pilot had to
be at the controls. I was instructed that a pilot or *mechanic* had to
be.
There is a page on hand-propping at www.pipercubforum.com/handprop.htm
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
Expedition sailboat charters www.expeditionsail.com
Old August 10th 04, 02:13 PM
Ron Natalie
"Cub Driver" wrote in message ...
be.
As others have pointed out, there are no requirements in the regs (other than the
catchall don't be a hazard). Back when I was pre-student pilot, I helped a guy
start his taylorcraft. It takes about two minutes to explain how to work the mags
and mixture.
It's unbelievable to me that people would hand prop a plane without either someone
at the controls or the aircraft restrained. Nearly all of these accidents happen because
the throttle is a little more advanced than expected. Even if you had to leave the
controls unattended to untie the running plane, it would be safer (as you'd have the
chance to bring it back to a safer idle first).
Had a hand propping incident at OSH this year. Guy pulls his Luscombe and turns it
perpendicular to the rows. Starts it and it starts heading for the weeds (out accross the
runway cleararea and eventually into some trees). However, the pilot says, "oh no" and
attempts to grab the thing. This only suceeds in turning the aircraft now so that it is
heading through a Cessna wing, and the tent of the aircraft underneath of it. Through
shear dumb luck, the occupants of the tent escape with only cuts from pieces of their
aircraft being thrown into them.
Old August 10th 04, 04:38 PM
Wallace Berry
Had a hand propping where my bird got away from me and whacked into a
pole. Had the tail tied down, brakes set, and wheels chocked. I was
careless in that I didn't check the strength of the rope and since I was
in the grass the chocks needed to be larger than my usual chocks. The
throttle was, in fact, advanced a bit too far. On start up the rope
broke, the wheels slid in the grass and rode over the chocks, I grabbed
the wing and turned the plane around and eventually had to let go. It
weathervaned right around again and smacked into a pole. Luckily, no one
hurt and no major damage to other aircraft. I'm rebuilding my bird now.
This was the first time I had ever started it without someone at the
controls.
Things I should have done: I could have turned the fuel valve off after
priming the engine. The engine would have run long enough for me to turn
the fuel valve back on. I could have tied a string from the throttle
back to the tail tiedown. That would have retarted the throttle as the
plane moved forward. Lesson learned is that one should take as many
precautions as humanely possible when handpropping.
What I REALLY should have done: Installed the perfectly good starter
that I had sitting in my shop.
be.
guy
the mags
and mixture.
someone
happen because
leave the
have the
Take out the airplane for reply
Old August 9th 04, 09:15 PM
Robert M. Gary
These regulations are Canadian. There are no restrictions in the U.S.
Its not reasonable to expect another pilot to be around everytime you
fly. Just be careful and never **NEVER** hand prop a plane that was
not designed to be hand proped (or anything more than around 100 hp).
I would never consider proping my Mooney.
-Robert, CFI (frequent hand proping guy).
Brian Jennis wrote in message . ..
when does a "remain clear" instruction end? Arden Prinz Piloting 171 March 2nd 04 12:26 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
