![]() If you have a Constant Speed prop you will not see the RPM drop as long as you are within the authority of the governor. You will see a change in Manifold pressure and eventually a slight drop in Airspeed. Why does the MP change? (disregarding that governors are not perfect) the engine speed hasn't changed, and the throttle setting hasn't changed. How can the MP change? |
"Jay Honeck wrote in message I've often wondered how a failed magneto
would manifest itself in flight. With some engines, you might not notice tht a magneto has failed in flight. I was flying a C-310Q in cruise and one engine burped momentarily but continued to run normally. While doing my run-up the next day, I discovered what caused the burp. Nowadays, I train my charter pilots to check the mags after landing so that if a mag has failed, maintenance has all night to fix it. D. |
"Capt.Doug" wrote in message
... With some engines, you might not notice tht a magneto has failed in flight. I was flying a C-310Q in cruise and one engine burped momentarily but continued to run normally. While doing my run-up the next day, I discovered what caused the burp. Nowadays, I train my charter pilots to check the mags after landing so that if a mag has failed, maintenance has all night to fix it. In addition to the "burp", you should also note increased fuel flow or higher EGT/TIT temperatures (depending on whether you readjust the mixture to compensate for the less-complete combustion). Nothing wrong with checking the mags after landing, of course, but I've never heard of a mag failing in flight where there was NO actual indication that it had failed. |
"Peter Duniho" wrote in message In addition to the "burp", you should
also note increased fuel flow or higher EGT/TIT temperatures (depending on whether you readjust the mixture to compensate for the less-complete combustion). Nothing wrong with checking the mags after landing, of course, but I've never heard of a mag failing in flight where there was NO actual indication that it had failed. There were no other indications. Many magneto installations can be tuned so that there is no perceptible rpm drop during a mag check. At 8500 feet with normally aspirated engines and with the original EGT probes and gauges in a heavily used charter airplane, it is possible that there won't be perceptible differences after a mag failure. Just wondering, what do you think will be the oil temperature indications of an engine losing oil? What about cylinder head temps? I know the book answers and I know the real world answers. D. |
On Thu, 30 Sep 2004 02:43:30 GMT, "Capt.Doug"
wrote: Just wondering, what do you think will be the oil temperature indications of an engine losing oil? What about cylinder head temps? I know the book answers and I know the real world answers. Care to expand on this? My answers would be oil temp going up for a couple miutes and then going down when there isn't enough oil to be sensed left in the engine. Cylinder head temps would go up. I've never read about this in a book and woiuld like to understand what to expect should it happen. Thanks in advance if you chose to reply z |
that there is no perceptible rpm drop during a mag check. Then they are tuned incorrectly, no? If there's no perceptible drop, how do you know your P-leads and ignition switch are working correctly? |
My experience with failed mags is fortunately limited to Fouled plugs
on the runup. However I am aware of 2 interesting incidents involving Mag's. 1. My flight Instructor was flying departing in a 414. Upon starting one engine he could just barely get it run it was coughing, sputtering backfiring, etc. He shut down and brought the Mechanic who determined that the timing on one of the Mags had slipped. It was firing but at the wrong time. Sorry I am not a Mechanic so I don't know what would have happed to cause that. However had my instuctor done a mag check he would have found that the engine ran fine on one mag and not at all on the other. lesson Learned if an engine start running rough or badly in flight a mag check is a worth while check. 2. A local Cropduster pilot had just finished up and was taking his Ag-Cat back to the home base about 5 miles away. On his Runup he discovered that one mag had died completely. He opted to fly it back to base to get it fixed. Upon landing at his home base he 1st took it to the fuel pump and fueled it. After Fueling he could not get it to start. The 2nd Mag had failed! So far my worse experience with a Mechanical Fail has been the nut on one of the intake valves worked loose in our Tomahawk and the engine began running rough and lost a couple hundred RPM. We simply informed ATC that the engine was running rough and we were diverting to the nearest airport. Brian CFIIG/ASEL |
![]() Brian Case wrote: After Fueling he could not get it to start. The 2nd Mag had failed! While possible, it's much more likely that the dead mag was the one with the impulse coupling. The impulse coupling retards the spark and increases the magneto output to get the engine started. There is usually only one, and it's usually on the left magneto. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
![]() "Peter R." wrote: I also now have one mechanical issue to add to my growing experience. I am not eager for others... Good work. A mag died on me once, and I headed home. As I set up on downwind at my untowered field, one of the local instructors announced a simulated engine out landing. I asked him to wait a bit, since I might have the real thing on my hands! George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
A few years ago, my IFR instructor and I were shooting approaches at an
uncontrolled field in a rented archer. After a missed approach procedure we both heard the engine noise drop. We both looked at each and asked "did you touch the throttle?". Neither of us had so we knew it was probably a failed mag. We continued around and landed. We called back to the flight school to send somebody out to get us. Nice to have two of those mags! I'm actually glad it happened. It was a good learning experience with an undramatic and happy ending. There was no question in either of our minds that although we could have flown back to the fbo at PNE, we wouldn't. Why take a chance? Dave 68 7ECA Peter R. wrote: Given my relative low time of 700 hours, I wanted to share the story of my first in-flight mechanical problem, which happened today while returning from southwest Pennsylvania to central NY. Cruising along at 11,000 feet with the XM radio playing in my headsets (thanks to an earlier thread here, my first flight with the new XM radio was this flight), my scan suddenly noticed the JPI engine monitor, now flashing an increasing turbo-inlet temperature. A quick background: I fly a turbo-normalized Bonanza and was taught by Tornado Alley (the manufacturers of the turbo add-on) to cruise at wide- open throttle and 75 degrees lean of turbo-inlet temperature peak. Once this optimum lean mixture is found, the turbo-inlet temperature will remain relatively constant throughout the remaining cruise at that altitude. Thus, watching this temperature continue to climb to a peak temperature, I immediately knew something was amiss. Not knowing what was the issue, my first order of business was to take in all the gauges and sounds to see if the engine was suffering an imminent failure (low oil pressure, etc.) or not. The results of this scan would determine whether I would be landing immediately or continuing to my home airport, some 60nm away. Other than the high TIT, there was no indication of a problem. I then tried re-adjusting the mixture to see if somehow it had vibrated loose. The only way to reduce the temperature was to enrichen the mixture in through peak to some point safely rich of peak, an action that definitely indicated a problem. With the mixture set rich of peak and the temperature down to a safe number, the fuel flow jumped to 24 gallons per hour (compared to 16 per hour at lean of peak during normal cruise). I had more than enough fuel, so I opted to leave the mixture ROP to hold down the temperature while I thought over my options and prepared the aircraft to land at any nearby airport. At this point, I was out of ideas as to what the problem was, so I began thinking how I was going to explain this problem to the mechanic Monday morning. That is when an idea crossed my mind. Tornado Alley states in their white paper that in order for lean of peak operation to properly function, the magnetos and the spark plugs must all be in excellent working order. A problem with fouled plugs or a bad magneto would show up as a rough running engine or high temperatures when at lean of peak. With this, I reached down and slowly turned the key from "Both" to "L"eft. Nothing noticeable happened in either the engine sound or the temperatures. Back to "Both." Slowly I turned the key from "Both" past "L" and into "R"ight. Instantaneously, the engine QUIT! Damn, I thought, and I quickly turned the key back to "Both," returning the engine to life. My heart-rate just when up a little. OK, there's the problem, a dead mag. Just about the time I discovered this, Center called me to hand me off to my class C airport's approach control. I acknowledged the hand-off and thought for a second on how best to safely deal with this problem. Although it was a severe clear VFR day, I was on an IFR flight plan. I decided that one dead mag was not an emergency, but I didn't want to be vectored all over while approach control sequenced airliners for their arrival, either. So, I keyed the mike and said, "Syracuse Approach, Bonanza 2845W, level one-one thousand, with a request." "Bonanza 45W, altimeter 30.18, go ahead with your request," answered Approach. "Syracuse Approach, Bonanza 45W has a mechanical problem, it is not an emergency yet, but I do need vectors straight to the airport for an immediate landing and I would like to remain at altitude until I get closer." "Bonanza 45W, expect all that, and when you have time, could you tell me the nature of your mechanical problem?" Since I did have a moment, I replied, "Magneto failure. The aircraft is equipped with two mags, but if the remaining one fails, my engine will quit. Also, I am now unsure of how the aircraft will operate at low power settings with the dead mag while on approach." ATC answered, "Thank you and if there is anything you need, please ask." Knowing what she was implying, I kept the "Declare Emergency" call on my mind and ready to use had the engine began to run rough. I then called the airport in sight, despite still being out about 30 miles, and ATC cleared me for a visual approach. At this time I began a gentle descent until I knew I was close. With the field made, I dropped gear and flaps and reduced power to 17 inches MP. Not knowing what to expect, I was pleasantly surprised to discover that the engine continued to deliver with no roughness. Landing was uneventful and on roll-out, tower asked me where I was parking on the field. I replied that I needed to park at the GA maintenance facility, to which the controller laughed and stated that she should have known that answer. With the leaves beginning to change color here in central NY, I am now hopeful that maintenance will be able to replace the mag sometime early this week. I also now have one mechanical issue to add to my growing experience. I am not eager for others... |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP | vvcd | Piloting | 0 | September 22nd 04 07:13 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
