#11
![]() "Otis McNatt" wrote in message om... Suppose *both* pilots in, say, a B-737, were to die in flight due to some incredible, but unfortunate coincidence. For kind of a neat question that most of us have wondered at some point (meteors not withstanding.) I've knew a guy who talked a non-jet pilot through a landing in a lear with no problem. btw, small though they are, lears are not that forgiving. there are a lot of particulars involved with each jet. i got a chance at a little stick time in a straight wing citation, and even though it was a much simpler airplane than any of the jets i've flown, i was not familiar with it. i've sometimes thought that the tough part for someone who was jumping in a jet with no experience would be the wing loading and power response. without a ball park target power setting on final, one might start chasing power, airspeed and sink rate, and not catch up in time. could most professional jet pilots land another jet? sure, but they would be on the radio asking someone who flew that type about system operation, target values, etc. |
![]() "Otis McNatt" wrote: I was just curious about just how much trouble an MD-88 pilot, say, would have with a 737, if he were just thrust into the cockpit in an emergency situation, without ever having been there before. Could he pass a checkride for the type rating? Probably not. Could he land it? Yes. -- Dan C172RG at BFM |
![]() I remember reading something written by an airline pilot once, in which he said in effect that when an airline pilot begins training on a new aircraft, it can be almost as bewildering as with his first aircraft. There's a difference between learning an aircraft's systems, and landing the darn thing. One one level they all work the same. "Push forward, the houses get bigger. Pull back and the houses get smaller. Keep pulling back and the houses get bigger again." Jose -- (for Email, make the obvious changes in my address) |
om... Suppose *both* pilots in, say, a B-737, were to die in flight due to some incredible, but unfortunate coincidence. For instance, one could die of a heart attack, and the other, say, of an aneurysm. Now, I'll admit the chances of this happening are remote, but it could happen; stranger things have. So, suppose it did happen. If there happened to be an airline pilot on board who was certified in any of the other Boeing models, from the 717 up the 747 and 777, but having no experience flying the 737, would he have much of a problem landing the plane? The most modern airliners are automated. The pilot takes off and climbs until at a safe point enganges the autopilot and the plane flies itself from that point on. Most modern airliners have a Flight Management Computer which pretty much does everything, including serving coffee (joke). Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) , requires the pilot to only dial the right nav data; it will intercept the localizer, descend, flare, touchdown, brake, and steer itself down the runway to a stop. When everything works, it's quite amazing to watch ... the first 3-4 times. Then I am ready to bet, it gets boring. So if the plane was not damaged in the accident that killed the two pilots, a person with zero knowledge of piloting, under the guidance of experts on the ground, can land the plane ... for the very simple reason that the plane will land itself. All he/she will have to do is dial the right data in. pilots are there in case something goes wrong and they make sure that the plane is flying great when nothing is going wrong. 1 - the difference between the professional pilot and the rookie is that the rookie is always surprised when an emergency happens, the pro is surprised when no emergency happens. 2 - (this comes from my instructor) thousands and thousands of engeneering hours went into your plane. It knows more about flying than you'll ever do. Just my personal, non-qualified, attempt at an answer. -- Marco Rispoli - NJ, USA / PP-ASEL My on-line aviation community - http://www.thepilotlounge.com |
Marco Rispoli wrote:
Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) Unless things have changed in recent years, there are very few runways that are equipped with a Cat IIIb ILS. -- Chris W Not getting the gifts you want? The Wish Zone can help. http://thewishzone.com |
Otis McNatt wrote: If there happened to be an airline pilot on board who was certified in any of the other Boeing models, from the 717 up the 747 and 777, but having no experience flying the 737, would he have much of a problem landing the plane? Hell, I could probably land it. But I can't tell you what systems are powered by electrical bus B, or whether loss of hydraulic system A renders the auto brakes inop. That's the difference between being a pilot and having a type rating. -- Ben Jackson http://www.ben.com/ |
Chris W wrote
Marco Rispoli wrote: Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) Unless things have changed in recent years, there are very few runways that are equipped with a Cat IIIb ILS. NOT required! At least in the Boeing jetliners that I flew at PanAm. You are confusing "Approach Categories" with "Autoland". In the B-727, the autoland system functioned quite well from a CAT II ILS. Our B-727 minimums were CAT II and if we saw any of the Part 91 "things" at or above minimums, we could just leave the autoland engaged to touchdown. Autoland IS required for CAT IIIb approaches but in my experience, was optional for CAT II operations. Bob Moore ATP B-707 B-727 PanAm (retired) |
"Bob Moore" wrote in message
. 122... Chris W wrote Marco Rispoli wrote: Best case scenario: a plane with a full automated autloand system (Cat IIIb I think it's called) Unless things have changed in recent years, there are very few runways that are equipped with a Cat IIIb ILS. NOT required! At least in the Boeing jetliners that I flew at PanAm. You are confusing "Approach Categories" with "Autoland". In the B-727, the autoland system functioned quite well from a CAT II ILS. Our B-727 minimums were CAT II and if we saw any of the Part 91 "things" at or above minimums, we could just leave the autoland engaged to touchdown. Autoland IS required for CAT IIIb approaches but in my experience, was optional for CAT II operations. Bob Moore ATP B-707 B-727 PanAm (retired) Thanks for the clarification Bob. As I said, I am unqualified and just going by what I am learning in IFR basics ... and MS Flight Sim. ![]() -- Marco Rispoli - NJ, USA / PP-ASEL My on-line aviation community - http://www.thepilotlounge.com |
Northern NJ Flying Club Accepting New Members | Andrew Gideon | Aviation Marketplace | 1 | June 12th 04 03:03 AM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
Announcing THE book on airshow flying! | Dudley Henriques | Military Aviation | 2 | January 7th 04 03:41 PM |
U.S. NAVY TO TEST FLYING SAUCER | Larry Dighera | Piloting | 0 | December 22nd 03 07:36 PM |
