Garmin 430 VOR reception
Old September 30th 04, 02:45 PM
Dean Wilkinson
All he has to due is swap coax cables between the units to find out...
"DP" wrote in message news:kuK6d.69$lf2.60@trnddc09...
I wouldn't be satisfied with the answer that one unit is more sensitive or
has better demod until I knew that the splitter, connectors, and coax were
all in good shape. Then I'd wonder if the Garmin was detuned somehow instead
of jumping right on poor or lesser design.
Dan
Old September 30th 04, 03:49 PM
Jack McAdams
Maik wrote in message ...
Hi!
I have a SL30 and a GNS 430 in my plane. They use the same antenna via a
splitter.
When I dial in the same VOR in both units the SL30 catches up the
radials always between 20 and 50 nautical miles earlier than the GNS
430! (Altitude about 3000 ft, flat area)
Is this normal?
What is your experience?
How far away do you have a reception of a VOR with your GNS 430?
Fly safe!
Maik
You may want to try swapping the coax leads at the splitter. That
would quickly tell you if you had any splitter / connection / coax
issues.
Jack
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
garmin 296 Robert M. Gary Piloting 1 June 16th 04 06:59 PM
Garmin DME arc weidnress Dave Touretzky Instrument Flight Rules 5 October 2nd 03 02:04 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
