G-1000 questions
Old October 9th 04, 11:26 PM
john smith
Thanks, hadn't seen that one.
Stefan wrote:
john smith wrote:
Are you saying that the G-1000 is a panel mounted display with remote
avionics which can be mounted in a remote avionics bay?
This article describes it nicely:
http://www.garmin.com/aviation/artic...PA_01_0601.pdf
Stefan
Old March 19th 05, 05:54 AM
oicu812
On Fri, 08 Oct 2004 20:32:38 GMT, john smith wrote:
Has anyone seen a G-1000 out of the box prior to installation?
What are the full dimensions?
How much space is there between the firewall and the rear of the G-1000?
Why?
Newer LCD projectors are compact and have high lumens outputs.
I have seen the new Apple G5 iMac. The thing is only two-inches thick.
I would think the G-1000 would be similarly "thin". This would leave
sufficient space between the firewall and the G-1000 to install a
"Heads-Up-Display" projector. All the information from the G-1000 could
be provided to the projector. The infomation could be pilot configurable.
Surely someone is developing such a HUD?
The technology is now available, it's just a matter of putting it together.
According to Garmin the G1000 isonly going to be sold as a
certificated OEM system in aircraft. For the time being no aftermarket
installs in older acft. Another interesting thing is that no other
items will interface w/ the G1000. If it wasn't designed for it, it
will not be allowed to be installed.
Kevin Patrick
Cessna/G1000 technician
Old March 19th 05, 07:43 AM
kage
Kevin Patrick
Kevin,
Is there going to be a flight director for the G1000?
Karl
Old March 19th 05, 01:37 PM
oicu812
On Fri, 18 Mar 2005 22:43:31 -0800, "kage"
Kevin Patrick
Kevin,
Karl
Right now there is only an interface w/ the KAP-140 autopilot by
Honeywell, Garmin has not developed an autopilot and gotten it
certificated yet. If and when Garmin develops the autopilot system for
the G11000, I think this stuff will probably follow. (an aside, the XM
radio WX system is still not out that was designed for the G1000)
BCNU
Kevin
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 04:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 03:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
