Story: Propeller found miles from crash scene
Old October 15th 04, 03:13 PM
Dale
" jls" wrote:
To me, losing a prop on a single-engine tractor aircraft means instant loss
of power, an aft CG outside of the envelope, and a life-threatening
encounter with the earth's gravitational pull.
A prop for most light aircraft weights about 80 pounds for a constant
speed unit, much less for a fixed pitch prop. I don't anticipate that
on most GA aircraft the CG will go so far aft that you'll have control
problems,unless already loaded with the CG well aft.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old October 16th 04, 06:13 PM
Roger
I have the big 3-blade Hartzel on the Deb. It weighs 83#. The 2-blade
it replaced weighed 57#
www.rogerhalstead.com
Old October 15th 04, 03:30 PM
Bob Chilcoat
A quick back-of-the-envelope (unintentional pun) calculation, assuming a
Cherokee/Warrior prop weighs around 25 lb and is 6" back from the datum
shows a shift in CG of about 1.5" aft. Hardly life threatening. OTOH,
without a prop, the glide ability would really be improved, and it might be
very difficult to judge an approach under those circumstances. He might
have just landed really long compared with where he was hoping to set it
down.
My dad used to tell the story of a Corsair prop that departed the a/c during
a runup somewhere in the Pacific. It flew all the way across the airfield
at low level and was found several hundred feet into the jungle at the end
of an impressive swath cut through the bougainvillea. Depending on the
altitude and RPM at the time of loss, I can easily imagine a lost prop
traveling a mile or two before it hit the ground.
Bob (Chief Pilot, White Knuckle Airways)
I don't have to like Bush and Cheney (Or Kerry, for that matter) to love
America
" jls" wrote in message
loss
Old October 15th 04, 04:06 PM
Montblack
("Bob Chilcoat" wrote)
during
Prop thought fully feathered meant something else.
Montblack
Old October 15th 04, 05:34 PM
G.R. Patterson III
"H.P." wrote:
Griswold Airport (MPE) is in the same town where he went down
(Madison).Wonder how (specifically) the dislodged prop affected the
aerodynamics of the Warrior and his chances for a controllable glide.
The prop and spinner weighs about 40 pounds. Removing it would have about the same
effect on the center of gravity as adding 40 pounds in the back seat would. With two
people on board and little luggage, the W&B would still be ok. The glide ratio would
improve, since a windmilling prop produces drag.
George Patterson
If a man gets into a fight 3,000 miles away from home, he *had* to have
been looking for it.
Old October 16th 04, 10:41 PM
Dan Thomas
"G.R. Patterson III" wrote in message ...
George Patterson
Have I missed something here, or is there a possibility the prop
departed and fell promptly to the ground while the aircraft glided
several miles in whatever direction before crashing? What's so unusual
about a missing prop being miles from the airplane?
Dan
Old October 18th 04, 03:30 PM
Sounds to me like it might be a failure to comply with AD 98-02-08,
SUMMARY: This amendment adopts a new airworthiness directive (AD), applicable to
certain Textron Lycoming 320 and 360 series reciprocating engines, that requires
visual inspections of the inside diameter (ID) of the crankshaft for corrosion
pits, and if corrosion pits are found during this inspection, prior to further
flight, performing a magnetic particle inspection (MPI) or fluorescent penetrant
inspection (FPI) of the ID for cracks. In addition, this AD requires reporting
findings of inspections to the FAA. Finally, terminating action to the
inspections of this AD is the application of a preventive treatment coating on
non-corroded crankshafts to prevent corrosion. This amendment is prompted by
reports of cracks in crankshafts originating from corrosion pits in the ID. The
actions specified by this AD are intended to prevent crankshaft failure, which
can result in engine failure, propeller separation, forced landing, and possible
damage to the aircraft. DATES: Effective March 30, 1998.
Demonick
Old October 18th 04, 09:46 PM
JFLEISC
Saw the clip on TV and the complete crank flange (less propeller) was still on
the plane.
George W. Bush Abortion Scandal that should have been Psalm 110 Military Aviation 0 August 12th 04 09:40 AM
F4U inverted gull wings Bob M. Military Aviation 52 July 16th 04 02:11 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
PFC Lynch gets a Bronze Star? Brian Military Aviation 77 August 2nd 03 11:15 AM
