Question on fuel consumption
Old October 22nd 04, 05:36 AM
Peter Duniho
"Shemp McGurk" wrote in message
m...
And from the example you give above, it's about what I thought it
would be: a 747 with, say, 300 passengers is consuming 6 gallons per
mile and a Gulfstream with, say, 10 passengers is consuming 1 gallon
per mile, the per-passenger miles-per-gallon is WAY higher with the
private jet than with the commercial jet.
You have that backwards (maybe because the mileages were stated reverse from
what we're used to in the US).
300 passengers in an airplane that's getting 1/6th of a mile per gallon
winds up being 50 passenger-miles per gallon, while 10 passengers in an
airplane that's getting 1 mile per gallon winds up being 10 passenger-miles
per gallon. The 747 has better mileage by a factor of 5.
That's assuming the figures are actually correct, of course. I can't speak
on whether they are or not.
Pete
Old October 22nd 04, 02:03 PM
Shemp McGurk
"Peter Duniho" wrote in message ...
m...
Yes, you're right...I have it backwards but I meant to say what YOU
say below. Instad of saying "WAY higher" I meant to say "WAY worse".
Pete
Old October 22nd 04, 02:19 PM
Mike Rapoport
Of course this is basically true for any two aircraft, the larger one will
get more passenger miles per gallon. A 777 gets a lot more than a 737 for
instance. The same is true for car vs bus.
MU-2
om...
m...
from
passenger-miles
speak
Pete
Old October 22nd 04, 04:50 PM
Chris W
Shemp McGurk wrote:
Actually, your Gulfstream V comparison with the 747-400 is exactly the
kind of thing I'm looking for: the per-passenger miles-per-gallon on a
private jet versus the per-passenger miles-per-gallon on a commercial
jet.
Yes?
The basic concept is the same for airplanes as it is for ground
vehicles. The larger the vehicle the better the "payload mile per
gallon". If you consider the payload of a new 18 wheeler that gets, I
think, over 6 miles/per gallon, to that of the say 40 mpg of some small
cars, you will find that per pound of payload the 18 wheeler gets a lot
better millage. The same is true for airplanes. I would also bet, with
out knowing the exact numbers, that a 777 has a higher "payload mile per
gallon" than a 40 mpg Honda civic. If you go by Payload mile per gallon
per hour of transit time, the 777 number would eclipse the Honda number.
Chris W
Not getting the gifts you want? The Wish Zone can help.
http://thewishzone.com
"They that can give up essential liberty
to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin, 1759 Historical Review of Pennsylvania
Old October 21st 04, 08:26 PM
Morgans
"Malcolm Teas" wrote
Miles per gallon measurements don't work that well for airplanes.
After all, there's factors like the plane's headwind or tailwind
speed,
airplanes are usually figured at
gallons/hour consumption.
-Malcolm Teas
Yes, we all know that, but approximations (meaningful ones) can still be
made. Yes, you would have to figure with no headwind, and direct route, (or
airways for big stuff) and you would do the same for the ground
transportation. Reality would be different, but that is beside the point.
Figure fuel used for a round trip to a destination far enough away to allow
getting to cruise altitude, then figure gas mileage for a car for the same
destination, and there you have it.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.778 / Virus Database: 525 - Release Date: 10/15/2004
Old October 22nd 04, 02:08 AM
C J Campbell
om...
The government routinely publishes a list of miles-per-gallon
consumption ratings for all cars sold in the U.S.
Does anyone know whether such a list exists for aviation?
It does not exist. The usual method of predicting fuel mileage in an
airplane is to take the gallons per hour, which is relatively constant at a
particular altitude and power setting, and then find out how long it will
take to reach the destination, taking into account wind, payload, and other
factors.
Some small single piston engine planes can easily exceed thirty miles per
gallon, while others are doing well to get a third of that.
Most of the manufacturers post performance specs on their web sites for
various models of aircraft. Boeing, Airbus, Raytheon (Beech), Bombardier,
Cessna, Cirrus, Piper, Lancair, Mooney, Diamond and many other manufacturers
all maintain good web sites that will tell you how their airplanes perform.
Most pilots would look at a government listing of miles per gallon with some
suspicion anyway. Pilots like their fuel consumption figures to be a little
more accurate than the list that is published for automobiles. After all, we
can't just pull over to the side of the road if we run out of gas.
Old October 22nd 04, 09:58 PM
John Galban
"C J Campbell" wrote in message ...
snip
I'm curious, CJ. Can you provide an example of a light single that
easily exceeds 30 mpg? Most of the more common ones (172, PA28,
etc..) tend to average around 15 to 18 mpg, depending on the power
setting.
Old October 23rd 04, 06:31 AM
C J Campbell
"John Galban" wrote in message
om...
snip
per
setting.
I know a guy who claims to get that in his Long-EZ, and my brother says he
will probably get that or better in his Celerity Mirage if he ever finishes
it.
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
Declared "minimum fuel" O. Sami Saydjari Instrument Flight Rules 14 April 4th 04 02:43 AM
Repairing Plastic Instrument Panel Overlay Jeff P Owning 22 January 29th 04 06:42 PM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 03:34 PM
