Flying on the step?
Old November 1st 04, 01:50 PM
Stealth Pilot
On Sun, 31 Oct 2004 21:37:46 GMT, "
I'm reading "Fate is the Hunter" and just read something interesting. Gann
states that they would climb to 100 feet above their cruising altitude and
then descend the 100 feet back down. He called this "flying on the step."
He claims that it bought them a few more knots of airspeed.
Has anyone heard of this? Is it normal practice? Or is it one of those
practices that have been disproven?
Personally, I've never heard of this practice.
it is something that was supposed to be noticeable for an aerofoil
which had a noticeable "drag bucket".
largely non sensical because those aerofoils arent commonly used.
Stealth Pilot
Old November 1st 04, 03:06 PM
OtisWinslow
This idea has been around a long time and I've never been able
to substantiate that it works any better than my normal practice
of leveling off and allowing the aircraft to accelerate to cruise and
then adjusting the power.
" wrote in message
hlink.net...
Gann
Old November 1st 04, 04:08 PM
Dan Thomas
"Kyle Boatright" wrote in message ...
" wrote in message
hlink.net...
Gann
There is no "step", but the perception is probably based on achieving cruise
speed as quickly as possible after climbing to altitude. The most efficient
cruise occurs at a specific airspeed (in reality, angle of attack). Below
that speed the airplane is on the back side of the power curve, and faster
than that speed, the airplane is wasting fuel...
It wouldn't surprise me at all if the transports and bombers in WWII and
before tried to cruise at this "sweet spot" to maximize range. So, if they
climbed to altitude, set power at cruise, and waited for the airplane to
accelerate to cruise speed, they were in for a relatively long wait, and
(in theory, at least) would never quite get to the ideal speed. On the
other hand, if they accelerated to cruise speed before the power reduction
(whether by climbing through, then descending to the cruise altitude, or
just by flying to the desired altitude and keeping the power up), they could
pull power back to cruise and be right at the sweet spot from the get-go...
KB
We see pilots (trained elsewhere) that regularly level off at
altitude, pulling back the power as they do so, then trimming. The
airplane continues to accelerate and more fooling with trim ensues, as
well as with power (in fixed-pitch) since the RPM comes up as well.
This continues for a long time, with altitude fluctuations and other
distractions completely messing up the flight.
In the Flight Training Manual (Canadian) the proper sequence is
Attitude- Power-Trim, when levelling off. Get the airplane level,
leave the power in until cruise speed is reached, reduce it to the
power that will maintain that speed, and only then is the trim set. It
requires forward pressure which some don't like (some airplanes will
require some trim to keep it manageable), but after the proper process
is followed the airplane will hold altitude properly and the pilot can
get on to other things like navigating. I've sometimes made a student
sort out altitude excursions by rolling in lots of nose-up trim and
forcing him to hold it until the other things settle down.
Dan
Old November 1st 04, 06:50 PM
Corky Scott
On Sun, 31 Oct 2004 14:05:51 -0800, "Peter Duniho"
Bottom line: if there were really something to it, it would be wide-spread
industry and military practice. And yet, all those folks continue to climb
to their altitude, accelerate to cruise speed and then throttle back to
maintain that speed.
Perhaps there is something to it then, check out this blurb from a 747
discussion group, the subject for this discussion was started by
someone asking about flying on the step:
***Begin quote***
As for flying 'on the step', I believe Jetguy's on the money. For a
given power setting there will be two speeds available (ie: the two
points on the curve where power available = power required). Being 'on
the step' is when you're flying at the higher of the two speeds.
On a video today I saw a demonstration of how to get 'off the step'.
The scenario was a CX B747-400 simulator with RB211-524H engines. The
aircraft was placed at 40,000' and at a weight which gave a margin of
approximately 30-40kts between the stall and high speed buffet. At a
speed ~ 10kts below the high speed buffet the thrust was reduced,
decellerating in level flight until the onset of the pre-stall buffet.
By this time the aircraft had gone past the lower speed at which level
flight could have been maintained with the initial power setting (ie:
the 'off the step speed'), and was so far up the back side of the
power required curve that full power was needed to maintain level
flight, and stop the IAS from reducing further.
The only solution was to descend, trading a bit of that potential
energy to accelerate the aircraft onto the right side of the drag
curve, and then recapture the initial altitude (if you wanted to test
your luck in coffin corner).
A very interesting demo which certainly highlights one of the major
differences between putting around in a Cessna and high altitude jet
transports.
***end quote***
This would appear to be specific to swept wing airliners only.
My father, who flew PB4Y-1's and -2's told me about the climb above
and dive down to cruising altitude technique which he used for his
long range patrol. The PB4Y-1, called the "Privateer" by the Navy,
was the navalized version of the B-24. Loaded for patrol, it would
have been substantially overgross. The B-24 also had a wing called
the Davis Wing, which had a very narrow cord (high aspect ratio) and
it's likely that it had a narrowly defined best cruise angle of
attack. I think it's possible that if you did not accelerate to the
proper airspeed, you could spend a long time wallowing along behind
the power curve before enough fuel burned off to allow the airplane to
nose down to the proper angle of attack. I agree though that finding
that proper cruise attitude and speed could be achieved by the diving
down method as well as leaving climb power on and throttling back once
the proper speed has been reached, or slightly exceeded. The point is
to exceed it slightly before throttling back, I doubt the airplane
cared which way you managed that.
Corky Scott
Old November 1st 04, 07:18 PM
Capt.Doug
" Has anyone heard of this? Is it normal practice?
Or is it one of those practices that have been disproven?
Keep in mind that Mr. Gann occasionally flew aircraft outside their
published limitations. If you fly within your equipment's published
limitations, flying on step will be a myth.
D.
Old November 1st 04, 07:25 PM
Mike Rapoport
When people talk about being "on the step" they are talking about their
being a cruise speed above that which can be obtained by accelerating in
level flight. It is a bunch of BS. You are correct that there are two
speeds achievable at any given power setting, one above L/D max and one
under. There are not TWO speeds above L/D max.
In the case of any airplane, if you have power to climb, you have power to
accelerate. There is no case where you can climb to an altitude and not
accelerate to whatever cruise speed is availible (and there is only one).
MU-2
"Corky Scott" wrote in message
climb
***Begin quote***
transports.
***end quote***
Corky Scott
Old November 1st 04, 09:41 PM
Newps
Peter Duniho wrote:
You might as well have asked about "low wing or high wing".
Marvel Mystery Oil similarly makes people lose their minds.
Old November 1st 04, 09:53 PM
Dale
I flew a B-24 for a couple of years. We rarely flew at gross, and
certainly never reached the weights the airplanes were operated at
during the war.
If you didn't either climb above and dive down or leave the power up to
accelerate to cruise speed it would make about a 10-15 mph difference in
speed. The method we prefered and used was to climb above the desired
altitude and dive back down. This was quicker than using power to
accelerate.
A pilot that was ham fisted in pitch could bleed off the speed at cruise
and end up on the low end.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old November 1st 04, 11:53 PM
Peter Duniho
"Dale" wrote in message
=== leave the power up to accelerate to cruise speed ===
speed.
[emphasis mine] True...that's what's already been said. Though, in truth,
if you you simply set cruise power, you would eventually accelerate to the
desired cruise speed. It would just take a lot longer.
accelerate.
No, it wasn't. Basic thermodynamics (conservation of energy) dispute that
claim. The time you spent climbing could have been spend accelerating at
climb power, and in the end you'd reach your cruise speed at practically the
same time either way.
He'd have to be pretty ham fisted to drop from cruise speed all the way down
below best L/D to the other equilibrium speed for the power setting. A
pilot that ham-fisted shouldn't be trusted with a Cessna 150, never mind a
B-24.
Pete
Old November 2nd 04, 02:04 AM
Dale
Well, no, you wouldn't. I know this from experience in the airplane.
Sure worked quicker for us. We tried both methods.
B-24.
It's very easy to do in the B-24, you don't have to be a bad pilot, just
not used to the quirks of the Liberator.
I'm speaking from experience flying the airplane. How much time do you
have in a B-24?
Dale L. Falk
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Flying is Life - The Rest is Just Details Michael Piloting 55 February 7th 04 04:17 PM
Announcing THE book on airshow flying Dudley Henriques Piloting 11 January 9th 04 08:33 PM
Announcing THE book on airshow flying! Dudley Henriques Military Aviation 2 January 7th 04 04:41 PM
U.S. NAVY TO TEST FLYING SAUCER Larry Dighera Piloting 0 December 22nd 03 08:36 PM
