Two non-aviation questions
Old November 9th 04, 06:11 PM
gatt
I'm not convinced that birds don't stall.
They're experts at stalls, spins and recovery. (Ospreys, kestrels...)
Last night I was reading a commercial rating textbook and one section
addressed the question of whether, like humans, birds ever forget to lower
their landing gear. Below the paragraph is a series of three photos
showing a seagull landing feet up, sliding his ass across the ground.
It would appear he forgot to do his GUMPS check.
-c
Old November 9th 04, 06:20 PM
David CL Francis
On Mon, 8 Nov 2004 at 19:42:55 in message
, Morgans
"David CL Francis" wrote
The boat can move
because there is a relative velocity between the two fluids. It is
obvious you can sail if there is no wind at all provided you are in a
tidal flow.
Not really. Relative velocity between the wind and water does not enter in,
much. In the case of a tidal flow you cite, it would have to be one hell of
a tidal flow; enough to make apparent wind, and a LOT, at that.
I've done it, although I have sailed where the tide can reach 9 knots
and 5 knots is quite common. The whole driving force for a sail boat
_is_ the difference in velocity between the two fluids. It must be. In
an 8 knot tide and an 8 knot wind in the same direction you have no
option but to start the engine (or in my case I used to get out the
paddle).
With very slow wind speeds, there is not enough wind to keep the sail in in
an airfoil shape, then you go nowhere, other than the speed of the water.
Most flows do not reach a minimum speed.
Again I have made headway when you could scarcely detect any wind and
you lean the boat way over to make the sails nearer the right shape to
catch the tiny winds. In my boat it also tended to reduce the wetted
area and lengthen the waterline (I used to think!).
Every one knows a sailing boat can tack up wind but can it tack down
wind? The answer is not much, mainly I believe because of the much
higher drag of the water. Sand yachts and ice yachts can, and they can
sail on a reach, downwind faster than the wind is blowing.
More problems. Sailboats *can* tack down the wind. They often do, if they
do not have a spinnaker. (Large parachute shaped sail, added while going
down wind) Problem is, you have to go a lot faster to justify the extra
distance. Usually, you just go down wind slower, and don't worry about it.
I thought I said that - my words were 'not much'? My boat used to have
a spinnaker thank you. It came out of a chute on the foredeck.
The drag of the water *is* an issue, but not as you state. The boat, until
you ride on top of the water, can go only so fast, almost irrespective of
how much extra power you add. It is called hull speed, and generally
speaking, it is higher, the longer the boat is.
Can we call it drag please? Drag rise at hull shape speeds is not
totally unrelated to approaching the speed of sound. I know the speed of
sound in water is very high but the natural speed of waves is not do so
high. That's why bores occur - they are a sort of shock wave travelling
down the surface.
When you are going into the wind, the hull speed is not tough to get to, if
the wind is strong enough. The maximum angle needs to be about 15 degrees
or more away from straight into the wind. (again, generalities) The sail is
acting like a wing, and airflow is accelerated around it to pull the boat
into the wind, just like an airplane wing provides lift. The boat slips
sideways, due to the wind pushing against the sail, which pushes sideways on
the water, through the keel and rudder. That is what gives the drift.
What is the difference between your visualisation and mine? Not many
boats that I have sailed can get within 15 degrees of the true wind and
there is no chance of them getting to their maximum speed while doing
it. Maximum speed is on a reach when I could get up to 12-15 knots while
planning. In stronger winds I could have gone faster but I was not
usually brave enough. Incidentally the keel and the hull are also acting
like a wing but in the water. Hence the sideways 'slip' but worded
differently.
What kills downwind speed, is the fact that the sail is only acting as a
barn door, or flat plat, using the wind pressure, and does not have lift in
addition. Those are the main factors limiting down wind speed.
Because you cannot effectively tack downwind you are forced to do that.
In the case of ice boats and land boats, the lower friction removes the hull
speed limitation.
i.e. lowers the drag
The craft continues to accelerate, until a wind that
*was* coming from the side or partway from behind, now with increased hull
speeds, will appear to come from the front of the craft, now called apparent
wind. The sail can then act like a wing again, and use the lift to continue
to go faster and faster. Problem is now, you can only go around 45 degrees
into the wind, without slowing way down again.
I agree at last - more or less.
I hope I have made this all clear enough.
It made no difference. Just because you find somebody expresses things
in slightly different terms from yourself please don't automatically
assume you have to disagree with them. The drag law for boats is
different from aircraft but it is still drag as far as I am concerned.
David CL Francis
Old November 10th 04, 12:51 AM
Robert M. Gary
"John Bell" wrote in message m...
2. We know it's possible for an aircraft to fly at angle to the
direction in which it's pointing. Does anyone know why does such a
thing not happen in boats or ships? After all, both ships and
aircrafts use media to float on... any sailors here could answer that,
I guess
In addition to the issue of boats traveling through water with a current,
there is actually the issue of sailboats traveling through the water at a
different angle from which they are pointed due to the push on the sail.
This slip angle creates an angle of attack on the centerboard, daggerboard,
or keel to provide an opposing force.
As a sail boat buys I take issue with the comment "push on the sail".
"Pushing" on the sail is your last choice and used only when sailing
directly away from the wind. However, this is the way the old 1400's
sailer did it. Today we have sails that are airfoils so the air
"sucks" us around. In fact you will move MUCH faster when sailing up
wind than when sailing down wind.
-Robert
Help me write 25 Aviation Trivia Questions! Jay Honeck Piloting 92 January 17th 04 06:43 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide General Aviation 1 January 13th 04 08:26 PM
MSNBC Reporting on GA Security Threat Scott Schluer Piloting 44 November 23rd 03 02:50 AM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
