![]() "John Galban" wrote in message om... Thomas Borchert wrote in message ... Are we talking about the Garmin 340 audio panel? That's a known problem - and there's a work-around and a fic by Garmin. If you're interested in the details, I'll provide them. No. I've tried this on Softcomm and Flightcom portable intercoms and a Flightcom 2 place panel mount. I've also tried using several audio sources. The only luck I've had is with older devices that were originally designed to drive a real speaker. It's really looking like a power (output wattage) issue. John Galban=====N4BQ (PA28-180) I think it is an impedance match issue... |
![]() "John Galban" wrote in message om... Thomas Borchert wrote in message ... Are we talking about the Garmin 340 audio panel? That's a known problem - and there's a work-around and a fic by Garmin. If you're interested in the details, I'll provide them. No. I've tried this on Softcomm and Flightcom portable intercoms and a Flightcom 2 place panel mount. I've also tried using several audio sources. The only luck I've had is with older devices that were originally designed to drive a real speaker. It's really looking like a power (output wattage) issue. John Galban=====N4BQ (PA28-180) How about cannibalizing one of those stand alone powered speakers that are supposed to hook onto the earphone jack of a walkman? Toss the speakers, put on an output jack, get a small experiment enclosure from rat shack, and let the inside goodies drive the intercom. Should be do-able for about 25 or 30 bucks. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.794 / Virus Database: 538 - Release Date: 11/10/2004 |
John,
ok. It is an impedance mismatch. Here's what Dave Katz posted two years ago. I did this using a photo film box, and it works real well. If you have any soldering skills, pick up a couple of 8/1000 ohm matching transformers and a male/male mini-plug cable from Radio Shack. It's a minor impedance mismatch problem. I put one together for my Cirrus and it boosts volume by more than enough, and it's completely passive so there's no batteries or other stuff. One of my fellow Cirrus brethren came up with a great packaging hack--a small prescription pill bottle is big enough to hold everything. Drill a hole in the bottom and in the lid, tie knots for strain relief, and it's all quite tidy, if a mite funny looking. One transformer for each side if you want stereo. The low impedance side (red/white) goes to the audio device, and the high impedance side (green/blue) goes to the intercom. You can snip off the black center tap on the high side. I hooked the white and green leads to the common (sleeve) connections on each side, but I don't suppose that it matters so long as you're consistent (so you don't phase-reverse one side.) They were the only transformers for sale at the Radio Shack at which I got mine. They may just be called "audio transformers" or somesuch, but it'll say 8 ohm/1000 ohm on the packaging. -- Thomas Borchert (EDDH) |
I've got a Garmin 340 and plug my iPod in. Works like a charm. Better than
I would have expected. Listening thru a set of Peltor ANRs (which I would not recommend - does ANR slowly wear off?!!!) "Thomas Borchert" wrote in message ... John, When I plug one of these into the input jack of the intercomm, I have to crank the volume on the player up to maximum and it's barely audible over the background noise in flight. Are we talking about the Garmin 340 audio panel? That's a known problem - and there's a work-around and a fic by Garmin. If you're interested in the details, I'll provide them. Also, yes, this can be a problem. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
Jens, well, one solution might be to buy a headset that has a music interface - and the ANR you always wanted. I'm very happy with my Bose X, so on that end I'm covered. Best Headset ever, and I've tried a lot (IMO of course). You'll need a stereo headset with decent sound quality anyway. Strikes me as more cost efficient than the 200-$-add-on-boxes as they come from PSE. Lightspeeds would be my first recommendation. Personally I don't like the Lightspeeds, and I've tried them almost all, via former students and friends. My Bose have now "logged" over 2000 hrs and are quite scratched and all but still work flawlessly. In my experience they are on par qualitywise with the DCs I had before. Even with the Koss In-Ear buds I'm using right now, the sound quality coming from the iPod is excellent. It has very thin wires so the Bose seals very well, I almost don't hear the engines over the music and the volume isn't set very high. It's just that I want to get rid of the extra cables. I don't need auto-muting or intercom, since I'm listening to music only if I'm not talking to ATC anyways. And since I'm flying single-pilot I don't need (or even have) an Intercom in the plane. There must be something plane jane out there.... :-\ Cheers, Jens -- I don't accept any emails right now. Usenet replys only. |
Jens,
Best Headset ever, and I've tried a lot Well, be that as it may, but they just seem to be lacking a music input, don't they? Which the Lightspeeds happen to have, for way less money, don't they? gd&r -- Thomas Borchert (EDDH) |
Jens, Best Headset ever, and I've tried a lot Well, be that as it may, but they just seem to be lacking a music input, don't they? Which the Lightspeeds happen to have, for way less money, don't they? gd&r I've got an older Lightspeed without the music input, but still a very nice headset. My own taste - which is not something I'd force on others - is not to have music. However, my wife likes the music, we bought her an ANR headset from AvShop that's got a music input. It's a good headset, a little cheaper than the Lightspeed one. Works fine, although I prefer the Lightspeed ANR control box. Sure, a Bose would be really nice to have. But, a Lightspeed is about 1/2 to up to 1/4 the $990 Bose cost right? And works well too. Sounds like a worthwhile trade off to me, $500 is about 5.5 hours of flying time after all. Buy what you want, but don't be afraid of buying a Lightspeed or an AvShop ANR headset. I do strongly prefer an ANR headset though. -Malcolm Teas |
Malcolm,
It's a good headset, a little cheaper than the Lightspeed one. AFAIK, they are actually LightSPEED QFR CrossCountries, but branded for AvShop. Those now also have cellphone capability - at least from LightSpeed -- Thomas Borchert (EDDH) |
My Lightspeed 30G ANR headset has an input plug in the battery box for
an audio device. It automatically mutes the music when a radio transmission (in or out) occurs, and the stereo sound is fabulous. |
Distortion in headset - advice wanted | Andrew Sarangan | Piloting | 3 | August 21st 04 02:15 PM |
Headset music | Neil Bratney | Piloting | 23 | April 27th 04 12:59 PM |
Bose makes good on my wife's headset. | Kyler Laird | General Aviation | 3 | March 10th 04 02:08 PM |
Bose makes good on my wife's headset. | Kyler Laird | Piloting | 3 | March 10th 04 02:08 PM |
Music input into intercom and IPOD | Paul Tomblin | Owning | 1 | August 7th 03 07:03 PM |
