Non Standard ATC Phraseology
Old November 24th 04, 11:08 AM
Cub Driver
On Mon, 22 Nov 2004 23:36:07 -0700, "Jay Beckman"
Dunno about John Galiban, but I can't remember Chandler ever giving me a
base entry without requesting that I report at "X miles."
Funnily enough, Chandler is the only towered field I've ever flown
from. (I have a recreational certificate and until September had to be
endorsed for each ATC field individually.) It drove me crazy because I
regularly had to deal with three frequencies, and the plane of course
had but two radios.
I'd be taking off and instructed to make a turn at 400 feet, much too
low by my way of thinking, and simultaneously to change freqs. I'd
scramble and scramble and finally breathlessly say: Six Two Echo is
with you! and behold! the same voice would come back. Why was I
changing freqs if I wasn't changing controllers? I found the radio
work more exhausting than the aerobatics!
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
the blog www.danford.net
Old November 19th 04, 01:35 PM
Nathan Young
On Thu, 18 Nov 2004 17:00:56 -0700, "In Soo"
Hi pilots, I am new to the group and wanted to see if you guys hear
Non-standard ATC phraseology around places where you fly.
Our tower at Chander, AZ usually request us to report 2 mile base when
entering a traffic pattern. I thought the standard pattern entry was 45 to
downwind or final. If you have any non-standard phraseology or clearance,
can you please let the group know?
It is definitely common to have a tower controller ask you to join the
pattern on a base, and report X miles out. Very common at class Ds
without radar.
Old November 19th 04, 07:59 PM
Andrew Gideon
without radar.
For example, consider CDW. If they're using 22, and you're coming in from
the north...
If it is very quite, you'll get a straight-in.
If it is a little busy, you'll get a base.
If it is very busy, you'll be told to join the downwind.
- Andrew
Old November 19th 04, 09:07 PM
Kyler Laird
"In Soo" writes:
Which standard? ICAO standards are routinely ignored around here (USA).
--kyler
Old November 19th 04, 09:25 PM
John Galban
"In Soo" wrote in message news:WIand.17773$233.12391@okepread05...
I fly out of Chandler and get that request often (coming in from the
South to runway 4). The phraseology is fine. I believe you're
applying the recommended 45 degree entry at uncontrolled airports to a
towered field. At KCHD, they will ask you to join the pattern in
whatever way is most convenient for you and them. For example, when
runway 4 is in use, you will almost always get a straight-in approach
(with a request to report 2 miles out), if you initially report from
the southwest. This is quite standard procedure for a tower.
One thing to keep in mind, inbound traffic from the north or south
and asked to enter a downwind, they expect you to fly a 45 to the
downwind. I don't know if this is a standard procedure, but it is
often published in the "Tower Talk" section of the airport newsletter.
Old November 19th 04, 10:05 PM
Newps
That would be a local thing. At the two places I have worked, one being
where UND lives, if I ask you to enter a right downwind you better not
have been flying outside the old ATA to suddenly come zipping in at
midfield. If I want you at mid field I will tell you to enter a
midfield downwind.
Old November 20th 04, 11:35 AM
Cub Driver
midfield downwind.
And this is an instruction to cross the field at pattern altitude?
Warbird's Forum
Old November 20th 04, 02:43 PM
Newps
midfield downwind.
No, enter the pattern by flying right at midfield then turn downwind.
Old November 20th 04, 03:22 PM
Rosspilot
This thread has nothing to do with phraseology.
www.Rosspilot.com
Why is a standard hold right turns? Roy Smith Instrument Flight Rules 51 August 28th 04 06:09 PM
Standard rate turn in Boeing 757? Garyurbach Piloting 43 June 17th 04 11:04 PM
Pavehawk: Is this helicopter "standard"? miso Military Aviation 2 November 19th 03 03:10 PM
Phraseology Thomas Myers Instrument Flight Rules 13 July 20th 03 01:56 PM
Vertex Standard 700 opinions?? EGWW Owning 3 July 15th 03 01:43 PM
