Many, if not most, turbine airplanes have this but it requires an airdata
computer system. You can set it to arrive at a particular point at a specific altitude. You need an airdata system as long as you are climbing or descending to a pressure altitiude. WAAS could only guide you to a GPS altitude. Mike MU-2 "Andrew Gideon" wrote in message online.com... I was staring at the VOR-head during a flight a while back, and started wondering why we only use half of it most of the time. Whether by GPS or VOR, the CDI provides us with lateral navigation. But the glide slope needle sits unused until the very end of the flight (if then {8^). Why? Using older technology, why not have an altitude bug and let the bug and altimeter feed the GS needle, providing VNAV information en route? Will WAAS-ified GPSs be able to drive the GS needle en route? Curiously... Andrew |
k.net... Many, if not most, turbine airplanes have this but it requires an airdata computer system. You can set it to arrive at a particular point at a specific altitude. You need an airdata system as long as you are climbing or descending to a pressure altitiude. WAAS could only guide you to a GPS altitude. Does it really drive the glideslope needle? Some of the more sophisticated GPSs have VNAV functionality, and turbine aircraft FMSs almost certainly do too, based on a barometric altitude input. But I always thought there was a reluctance to put the information on the GS needle because the glideslope of an ILS is generally associated with a trajectory with terrain clearance -- something that simple VNAV can't guarantee. Julian Scarfe |
It drives the flight director and the autopilot follows the flight director.
I don't know for certain if it drives the GS needle. I am pretty sure it does. Mike MU-2 "Julian Scarfe" wrote in message ... "Mike Rapoport" wrote in message k.net... Many, if not most, turbine airplanes have this but it requires an airdata computer system. You can set it to arrive at a particular point at a specific altitude. You need an airdata system as long as you are climbing or descending to a pressure altitiude. WAAS could only guide you to a GPS altitude. Does it really drive the glideslope needle? Some of the more sophisticated GPSs have VNAV functionality, and turbine aircraft FMSs almost certainly do too, based on a barometric altitude input. But I always thought there was a reluctance to put the information on the GS needle because the glideslope of an ILS is generally associated with a trajectory with terrain clearance -- something that simple VNAV can't guarantee. Julian Scarfe |
Mike Rapoport wrote:
Many, if not most, turbine airplanes have this but it requires an airdata computer system. You can set it to arrive at a particular point at a specific altitude. You need an airdata system as long as you are climbing or descending to a pressure altitiude. WAAS could only guide you to a GPS altitude. Perhaps I'm missing something basic, but don't we specifically adjust the kollsman window to convert values provided by a barometric altimeter to a true altitude (at least below 18,000')? Of course, you're quite right that the GPS would need "correction" to yield the pressure altitude used above 18,000 (which I didn't consider because I've never flown there myself {8^). - Andrew |
![]() "Andrew Gideon" wrote in message online.com... Mike Rapoport wrote: Many, if not most, turbine airplanes have this but it requires an airdata computer system. You can set it to arrive at a particular point at a specific altitude. You need an airdata system as long as you are climbing or descending to a pressure altitiude. WAAS could only guide you to a GPS altitude. Perhaps I'm missing something basic, but don't we specifically adjust the kollsman window to convert values provided by a barometric altimeter to a true altitude (at least below 18,000')? Of course, you're quite right that the GPS would need "correction" to yield the pressure altitude used above 18,000 (which I didn't consider because I've never flown there myself {8^). - Andrew You are right and as Julian points out, I should use the term barometric altitude. Barometric altitude (with the correct kollsman setting) is only correct if the temperature lapse rate is 2C/1000'. It is also affected by airflow over mountains and can be off by 1,000' in extreme conditions (I've read). My point is that there is no way to "convert" GPS altitude to barometric altitude since the barometric altitude is subject to a host of errors. Everybody needs to be on the same "system" and that is barometric. Mike MU-2 |
It would require extensive (read expensive) modifications to achieve what
you wish. First of all the CDI is driven by a VHF omni range or Localizer signal while the GS indicator is driven by a UHF signal from the glide slope transmitter. In the beginning use of ILS there were 2 separate receivers to be tuned.... one for the Localizer VHF frequency and one for the GS UHF frequency. Then they paired up LOC/GS frequencies so that tuning the localizer automatically tunes for the GS. Much the same way that tuning in VHF VOR stations automatically tunes the paired UHF tacan DME receiver for VOR stations that have DME. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Andrew Gideon" wrote in message online.com... I was staring at the VOR-head during a flight a while back, and started wondering why we only use half of it most of the time. Whether by GPS or VOR, the CDI provides us with lateral navigation. But the glide slope needle sits unused until the very end of the flight (if then {8^). Why? Using older technology, why not have an altitude bug and let the bug and altimeter feed the GS needle, providing VNAV information en route? Will WAAS-ified GPSs be able to drive the GS needle en route? Curiously... Andrew |
Route Advice? KGEU (Phoenix) -> KEMT (Los Angeles) | Eclipsme | Piloting | 4 | August 13th 04 04:15 AM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
filing IFR plan for VFR flight conditions | Paul Safran | Instrument Flight Rules | 53 | May 11th 04 03:07 AM |
Angle of climb at Vx and glide angle when "overweight": five questions | Koopas Ly | Piloting | 16 | November 29th 03 10:01 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
